Ovidanie vinde:
Ovidanie
64.  20 lei:  Bobine  din litz wire gros, recuperate dintr-un filtru de retea, duc lejer 2A la 50Hz    https://i.ibb.co/JySH5cX/20230219-203430.jpg
65.   Condensatori de trecere,  20 lei toti https://i.ibb.co/r7SjXcN/20230219-203443.jpg
66.  Transformator, 150 lei:       https://i.ibb.co/nRvXcBq/20230219-203637.jpg
(1) - borne  1-2,    Φ0,62  305sp,   1+2=220V
(2) - borne 3-4,    Φ0,62  305sp,  1//2+3=120V
(3) - borne 5-6,    Φ0,62  305sp,  1+2+3=230V
(4) - borne 7-8,    Φ0,35  810sp,   270V 0,19A
(5) - borne 13-14, Φ0,3    151sp,   52V  0,1A
(6) - borne 11-12, Φ0,58    18sp,   6,3V 0,7A
(7) - borne 9-10,  Φ1,2       18sp,   6,3V 2,2A
(8) - borne 15-16-17,  Φ1,2   29+29sp,  10+10V 2A
1.  Diverse integrate, 30 lei toate, noi+recuperate.        https://imgbox.com/elyhDqv4
2.  CA3083, arie tranzistori, 7 buc recuperate din echipament functional, 30 lei toate.  https://imgbox.com/Uf2oFaOG
5.  40 lei Carcasa plus luminator IR pentru videocamera.  https://imgbox.com/LRmp6yK6   https://imgbox.com/scXxNNIc    https://imgbox.com/gpRxYNq9
6. condensatori trimmer, 27buc, 40 lei totul      https://imgbox.com/2z0wvhCt
7. Condensarorul de sus 15 lei, ceilalti 10 lei.   https://imgbox.com/VnfHtV2C
10.  Doar cel din stanga, 2x10,5V 1A, 15 lei.    https://imgbox.com/LhQ6DpCo
11. Pret 25 lei, Integratul din dreapta sus este  ICL8013CCTX, "1MHz, Four Quadrant Analog Multiplier"   https://imgbox.com/lkOJbJW8    https://imgbox.com/gk9fN7F9
13. Pret  25 lei cablajul,  D2 este o referinta de tensiune de 5V   https://imgbox.com/ldymVSHf  https://imgbox.com/2sLmeUtq  Disponibile doua cablaje.
14.  Disponibile 3 buc la 25 lei buc.  https://imgbox.com/AnfpkV6w   https://imgbox.com/k2UCuGuR
16.  Pret 130 lei, Atari 2600 cu accesoriile originale si 33 jocuri.  https://imgbox.com/OPTCOvg7
17. https://imgbox.com/W2Uw4LMR    Preț. 40 lei, sursa de sus, livrează 5V la 5-6A si separat galvanic +/- 15V. Tensiunea pozitivă de 15 V e la un curent de 3A si cea nrgativă 1A. Preț 40 lei.
18.  Pret 40 lei      https://ibb.co/BZf3vDQ   https://ibb.co/Vqd0Y2B   https://ibb.co/8m7MHBk. Partea de jos este din aluminiu, cred ca are 10mm grosime. Perfecta ca radiator. Dispoibile mai multe carcase.
19.  25 lei , carcasa din AL are dimensiunile21*95*55   https://ibb.co/Ryh82Lb   https://ibb.co/chNQSR3
21.  Cel din stanga livreaza 2*14,5V, 50W celalalt 16,2V, tot 50W Provin din incarcatoare pentru acumulatori Ni-Cd. 25 lei bucata.   https://ibb.co/Tt5pdMJ
26.  Filtru 3 linii 600V DC, 40A  https://ibb.co/VgHkK6x   https://ibb.co/h10wMfn  Poate fi demontat de pe suport. De unde l-am demontat eu , izola intre ele  mai multe echipamente conectate la aceeasi baterie de acumulatori. Pret 20 lei
30. Frecventmetru E0204, prescaler cu BFY, baza de timp termostatata. Cumva functioneaza, din ce am observat nu se aprind ledurile KHz si MHz. Nu mi-a trecut prin cap sa las frecventmetrul sa intre in regim termic, probabil are precizie mai buna. Pret 200 lei.
34. Sase tranzistori cu germaniu, radiatorul are 4mm grosime.  25 lei https://i.ibb.co/DKNrCJp/20221220-091328.jpg
36.  "Antene pentru traficul de radioamatori"  25 lei,   "Constructii pentru amatori" 15 lei, "Radioreceptoare de buzunar" nu mai este.    https://i.ibb.co/kqWCV7X/20230106-152504.jpg
38.  Ecranaj pentru tub electronic,din material feros, 10 lei.   https://i.ibb.co/YN3KdSq/20221216-170717.jpg
41.  EC360, EL83, D3a, ECC82, plus un ECC85 bonus. 160 lei toate   https://i.ibb.co/4R9WytL/20230107-194711.jpg  Tuburile  sunt OK, in ultimul an am facut cateva teste cu GM70, am incercat diferite drivere pt acest tub.
42. E81L, E83F, E180F   80 lei toate 3. Nu am foto.
44.    mosoare plastic, diametru exterior 15,5mm, inaltime 16mm diametrul mosorului 8mm, gaura strapunsa 6mm, https://i.ibb.co/tQjYsDH/20230108-134945.jpg  30 lei toate
59.   Atenuator. 35 lei.
Este vorba de comutatoarele P2-1 ...P2-4 din schema urmatoare:   https://i.ibb.co/0VtP07x/20221209-232301.jpg
https://i.ibb.co/MDT5Dds/20230211-111918.jpg      https://i.ibb.co/1fymrrs/20230211-111955.jpg      https://i.ibb.co/CVrGntN/20230211-111843.jpg
Este fabricat din material nemagnetic, probabil alama cositorita. Contine vreo 40 suruburi, tot din alama cositorita.
60.  O carte despre vechile magnetofoan cu lampi fabricate in Rusia. Sunt cateva scheme care folosesc tubul 6j1p  25 lei :https://i.ibb.co/FYJsPDB/20230212-184049.jpg     https://i.ibb.co/72ntR53/20230212-184031.jpg     https://i.ibb.co/56CC20N/20230212-184012.jpg     https://i.ibb.co/fdcppm4/20230212-183950.jpg
Pozitia 64+65, 30 lei ambele.
61.     Reducere la 40 lei.
Placa de baza Maverick/Silverado dintr-un un server HP DC7700, echipata cu procesor Intel Pentium D Processor 945
4M Cache, 3.4 GHz, 800 MHz FSB,   4 memorii a 1Gb bucata, total 4 Gb, incluse in preț.
Placa perfect functională,  testată.  Voi schimba eu cei 2 electrolitici defecti și pasta procesorului.
https://i.ibb.co/5hQK8B3/20230216-134920.jpg
62.  Sarcina artificiala activa, Kikusui PLZ 300 W. Capabila de teste dinamice, max. 60V, ma. 60A, max. 300W.
Manualul se gaseste pe net, puteti vedea cum poate fi comandata extern, chiar cu semnal audio.
https://i.ibb.co/4SyfYQz/20230217-124554.jpg     https://i.ibb.co/C6g9PjP/20230217-124439.jpg
https://i.ibb.co/G5zwLgq/20230217-124420.jpg     https://i.ibb.co/n7J7ynN/20230217-124357.jpg
Tineti cont ca exista cadere de tensiune pe firele de conexiune:
https://i.ibb.co/djC35Yq/20230217-130109.jpg
Ma gandesc ca ar valora vreo 200 euro dar sunt deschis la oferte, in privat.
63.  Convertoare DC/DC 25 lei bucata.
https://i.ibb.co/KL9rycg/20230217-152631.jpg
67.  25 lei: Doua stabilizatoare, cel de sus cu 723 si BD241, comanda 3 buc 2N3055 pe radiator. Pe aceeasi placa se afla  un alt stabilizator cu  7824.  https://i.ibb.co/j5LHFfW/20230219-165933.jpg
68. 30 lei. Cel de jos, satabilizator cu LA200, Cei trei cndensatori din dreapta placii sunt un redresor separat, 10 000 micro la 25V, Nitsuko   https://i.ibb.co/j5LHFfW/20230219-165933.jpg
69.   30 lei.  Condensator variabil cu trei sectiuni.     https://i.ibb.co/8MPZrYJ/20230220-143446.jpg    https://i.ibb.co/87TqQzz/20230220-144008.jpg
70.  Condensator variabil cu o sectiune  15 lei. https://i.ibb.co/5K4LqXN/20230220-142927.jpg       https://i.ibb.co/TgYkn8d/20230220-143004.jpg
71.  25 lei.   Mufa mama de panou +tata pe cablu, cu 5 pini, marcata 500/1500V,2A.  Excelenta pentru un amplificator cu lampi,cand se vrea alimentarea separata.   https://i.ibb.co/S5wJ6wz/20230220-145029.jpg       https://i.ibb.co/QFz3C7f/20230220-144909.jpg
72. 20 lei mufa tata, soclul cu 9 pini 15 lei. Ambele made in Japan.  https://i.ibb.co/tYVcxcV/20230220-151246.jpg
73. 30 lei tot sistemul: https://i.ibb.co/jZWVCyp/20230220-151400.jpg
74. 15 lei bucata,  soclu octal este perechea acestor mufe.   https://i.ibb.co/9W0cbZF/20230220-151731.jpg
75.  10 lei:  https://i.ibb.co/ftVT12f/20230220-151925.jpg
76. 10 lei:  https://i.ibb.co/WB4sdq1/20230220-151941.jpg
77.  15 lei   https://i.ibb.co/RDjpCSY/20230220-152012.jpg
78.  10 lei:   https://i.ibb.co/MVQfrCG/20230220-152032.jpg
79.  5 lei bucata https://i.ibb.co/gdR5dgh/20230220-152105.jpg
80.  5 lei bucata  https://i.ibb.co/8X5cGJK/20230220-152214.jpg
81.  20 lei ambele. 10 pini, mufa tata este pe cablu. https://i.ibb.co/phJ4nZn/20230220-170313.jpg
Editat de Ovidanie
Acum 53 minute, Ovidanie a spus:
69 si 70 le-as dori daca sunt inca disponibile
Rog eu:
Editat de hamatdumitru
Revine la vanzare:
81.  20 lei ambele. Corectie, au 11 pini, mufa tata este pe cablu. https://i.ibb.co/phJ4nZn/20230220-170313.jpg
Valoare minima colet 50 lei.
Colegii care vor sa rezerve un produs, trebuie, tot in acea zi,  sa achite integral, in cont, pretul produsului plus 10 -20 lei transportul cu Posta RO.
Daca pretul achitat depaseste 60 lei, dupa trei saptamani expediez automat coletul.
Daca pretul achitat este sub 60 lei, dupa patru saptamani banii raman la mine si produsele revin la vanzare.
Ce m-a determinat sa inventez cele scrise mai sus: momentan am vreo sase colete in asteptare, cel mai vechi are lejer 3 luni, toti justifica in felul urmator: "Mai astept sa vad ce apare la vanzare" Au fost perioade cand aveam si cate 10 colete in asteptare...ma tot incurca prin atelier.
Acum 2 ore, doru3160 a spus:
Seamana cu cel din Belcanto. Daca e asa, sigur e aluminiu.
Da, dar cel de Belcanto nu are 4mm. Eu l-as vrea ca placa de sasiu pt. un amplificator pe lampi.
@hamatdumitru: daca vreti sa-l folositi ca radiator, pot sa va ofer la schimb 1-2 radiatoare pt. audio, cu suprafata de racire si aspect mult mai bune. Am vazut tarziu grosimea placii...pe mine ma intereseaza pt. rezistenta mecanica. Posibil si ca gaurile pt. TO3 sa coincida cu cele pt. soclurile octale de sasiu, n-am verificat asta inca...
66.    OT100  9 buc. disponibile.  250 lei bucata, usor negociabil cine cumpara toate 9.
https://i.ibb.co/3dvkMwW/20230224-172619.jpg
https://i.ibb.co/ZmWSbrf/20230224-172257.jpg
https://i.ibb.co/z8j82M5/20230224-172206.jpg
https://i.ibb.co/cX2bkgC/20230224-172202.jpg
67.  Z560 M TGL200-8144     70 lei bucata.   Disponibile mai multe buc.
https://i.ibb.co/M5sdsgC/20230224-173154.jpg
https://i.ibb.co/qsTw7jQ/20230224-173032.jpg
Editat de Ovidanie
