Ovidanie vinde:
Ovidanie
e8b8a71f-bea8-44d5-a21a-a16708533c22_zps
http://www.tecratools.com/pages/datacom/37198.html
Link – Determine whether the drop is active, identify its speed, duplex capabilities and service type. 10/100/1000 Mbps
Ping – Verify connectivity to key devices.
Cable verification – Multiple tests help you quickly determine if cable is the problem.
Cable identification – Document unmarked segments, saving you hours of troubleshooting time.
Improved efficiency – Speed up the escalation process by identifying physical or link layer problems.
98d249e2-98bd-4a47-a3fa-9f6a6817e8f9_zps
Model # MT-8200-46
  • Inductive plastic tip with non-conductive tip (prevents accidental shorts)
  • Traces and identifies wire or cable in a bundle or group without damaging cable insulation
  • Works with any tone generator
  • Adjustable volume control and a LED indicator - great for noisy work environments
  • Lightweight and ergonomic
  • Low-battery indicator
350 lei + transport.
Editat de Ovidanie
Cutitele masoara 225mm * 22mm iar grosimea unul de 5mm altlul de 7mm. Ascutite la 22 grade (aproximativ). Provin dintr-un laborator fotografic Noritsu. Suficient de solide sa taie cablaj sau tabla de 0,5mm. Motorul mecanismului este foarte slab, nu are suficienta forta sa taie un plastic mai gros, gen card bancar.
Vand cutitele cu 50 lei+ transport. Restul mecanismului este bonus.
Editat de Ovidanie
La 5 respectiv 7mm grosime sunt suficient de solide pentru cablaj dar trebuie sa construesti o ghilotina... instalatia din care provin nu e suficient de solid construita pentru taiat cablaje.
Le mai vrei?
Adaptec Serial ATA RAID 2410SA pe langa RAID stie JBOD adica puteti conecta patru HDD-uri de aceeasi capacitate sau de capacitati diferite si pot fi configurate ca o singura partitie de capacitate echivalenta. Sau daca doriti puteti imparti in cate partitii logice vreti.
Editat de Ovidanie
Antena a functionat undeva la 174MHz, pentru 144MHz trebuie lungiti elementii, foarte simplu, cu ajutorul piulitelor de conexiune si 5 cm tija filetata. Pret 50 lei + transport. Pentru foto suplimentare contactati-ma pe P.M.
Filetanta Hitachi DS18DVF3 cu incarcator UC18YG si doi acumulatori EB1814SL obositi. Filetanta chiar daca arata rau este perfect functionala, este modelul cu doua trepte de viteza. Pret 100 lei plus transport.
Editat de Ovidanie
Filetanta vanduta
Emitator si receptor, transmite pe firele retelei electrice. Testate, functioneaza dar aud frecventa retelei. Acum 10 ani au functionat perfect, cred ca e vorba de condensatori uscati. Pret 50 lei cu transport inclus. (Posta RO)
Doua difuzoare (4 ohm, 2,5W) vintage in stare foarte buna, diametrul total 185mm. Bucata de material textil masoara 60*24cm, are o gaura unde a fost ochiul magic. Pret 40 lei.
Editat de Ovidanie
Nu mai sunt disponibile.
E mare cat un magnetofon Kashtan. Cu antena extinsa complet masoara 180 cm.
Leningrad 002, introduced in 1975, was the first USSR designed and manufactured portable transistor radio receiver of a "supreme class" (USSR electronics was split into five "groups/classes": 4th "class" being the simplest in design and cheap in manufacturing, then 3rd, 2nd, 1st and the supreme class being of the highest quality in engineering, design and manufacturing. Paul). The receiver provides high-fidelity reception in all consumer bands: LW, MW, SW and UltraSW (FM), including Amateur Bands. It can be pre-set with up to 3 stations in UltraSW. It has treble and bass tone controls, speech/solo switch, signal strength and battery indicators, two tuning dials. In addition, it has connectors for a tape recorder hookup, external antenna, ground and headphones. The receiver is assembled using 36 transistors and one IC, It's wooden case is veneered with rare woods, front and back panels are made out of Polystyrene. Weight without batteries is 19lb. Retail price in 1975: 200 rubles (almost two times average engineer monthly salary - my wife's comment).
The radio was manufactured in the city of Leningrad (hence the name), now St.Peterburg, at "Radiopribor" factory
La marimea lui o sa am de lucru sa-l ambalez. Super-pret, 100 lei plus transport. Pe net mai este unul de vanzare la 700 lei.
  • 3 săptămâni mai târziu...
Kenwood mdx-j3. Adus din Japonia. UUS in norma asiatica, din cate-mi amintesc pan la 97 Mhz, nu are toata banda 88-108. CD-ul functioneaza da se intrerupe la cea mai mica atingere, casetofonul functioneaza dar trebuie schimbata cureaua, minidiscul nu am cum sa-l verific ca nu mai am. Ultimii 10 ani a functionat sporadic pe unde medii.
Pret 60 lei plus transport, tot ce se vede in foto.
