Miniscope v2f
Freaka666
  • Răspunsuri 4
  • Freaka666
  • puriu
Zile populare
A revenit site-ul dar am atasat oricum schema si cam asta spune tipul polonez care a conceput jucaria(care sunt sigur ca este mai buna decat "osciloscoapele pe placa de sunet"):
Quick specification
  • follows miniscope v2a-d idea: very simple device streaming data in real time to PC; DLL and GUI (Win32) are handling all the functionality,
  • sampling: 480 kSps, 8 bit, streaming via USB FS with libusb (32/64bit) used as driver,
  • 8 voltage ranges (0..30V, 15V, 7.5V, 6V, 3.75V, 3V, 1.87V, 0.94V - PGA x1, x2, x4, x5, x8, x10, x16 and x32 respectively),
  • input resistance: 1MOhm,
  • noise: ~23mVpp (visible at two gain ranges with high sensitivity),
  • record length: 4k to 1M defined in DLL (single screen); up to 512M samples (continuous!) when recording to file,
  • firmware loading via USB (DFU bootloader embedded in ROM),
  • low component count: MCU, voltage regulator, mini-USB and few passive SMD components on single-sided PCB.
Am imaginat si construit si "jucarii" mai simple, dar pentru aplicatii concrete, de exemplu un cardiograf cu 4 canale cu un PIC12F675.
Multe idei se pot gasi pe Google cu "A poorman's oscilloscope".
Pentru aplicatii generale, hobby, trebuie ceva mai bun, cu toate facilitatile unui osciloscop, chiar daca este mic si digital.
