litrometru pic 16f 676
kinderu56
  • Răspunsuri 23
  • kinderu56
    11
  • Elison
    5
  • mars01
  • Mircea
Nu are sursa acolo. Numai HEX-uri. Cateva, banuiesc ca poti incerca sa vezi care merge. Poate ala Blink?
Cel mai bun simulator e o placuta de test (breadboard).
In acel folder, de fapt este un proiect mikroPascal for PIC complet, cu fisier sursa.
Fisierul sursa este urmatorul:
program bakometr;
const
   stNormal : byte = 1;
   stCalibr : byte = 2;
   AdrHi : byte = 2;
   litr : array [0..AdrHi] of byte = (0, 127, 255);
var
    C1 : sbit at porta.2;
    C2 : sbit at porta.5;
    C3 : sbit at porta.1;
    SW : sbit at porta.3;
    i, j, cc: byte;
    V : word; absolute 0x40;
    Vhi : byte; absolute 0x41;
    VLo : byte; absolute 0x40;
    V100 : word;
    L100, L10, L1 : byte;
    dat : array [0..AdrHi] of byte;
    mode : byte;
    calibrN : byte;
    sign : byte;
procedure Razr(V : integer);
begin
  sign := V < 0;
  sign := 0;
  L100 := V div 100;
  V100 := V mod 100;
  L10:= V100 div 10;
  L1 := V100 mod 10;
end;
procedure Led(i: short);
begin
  if I=0 then begin
    portc:=$04;
    porta.4:=0;
  end;
  if I=1 then begin
    portc:=$2D;
    porta.4:=1;
  end;
  if I=2 then begin
    portc:=$22;
    porta.4:=0;
  end;
  if I=3 then begin
    portc:=$28;
    porta.4:=0;
  end;
  if I=4 then begin
    portc:=$09;
    porta.4:=1;
  end;
  if I=5 then begin
    portc:=$18;
    porta.4:=0;
  end;
  if I=6 then begin
    portc:=$10;
    porta.4:=0;
  end;
  if I=7 then begin
    portc:=$0D;
    porta.4:=0;
  end;
  if I=8 then begin
    portc:=$00;
    porta.4:=0;
  end;
  if I=9 then begin
    portc:=$08;
    porta.4:=0;
  end;
end;
procedure delay10;
begin
  delay_ms(10);
end;
procedure ReadData;
begin
  for i := 0 to AdrHi do dat[i]:=EEPROM_Read(i);
end;
begin
  porta := %00000000;
  trisa := %11001001;
  portc := %11111111;
  trisc := %00000000;
  wpua  := %00000001;
  cmcon := %00000111;
  ansel := %00000001;
  adcon0:= %00000000;
  adcon1:= %00110000;
  mode:=stNormal;
  ReadData;
  ADC_Init;
  i := 0;
  while true do
  begin
    inc(I);
    if mode = stNormal then
    begin
      {if (i.7) and (V<22) then
      begin
        C1:=0;
        C2:=0;
        C3:=0;
      end; }
      if i=0 then
      begin
        V:=ADC_Read(0);
        V:=V shr 2;
        if V<=dat[AdrHi]
          then V:=litr[adrHi]
          else begin
            if V>=dat[0]
              then V:=litr[0]
              else begin
                for j:=0 to AdrHi-1 do
                  if (V<=dat[j]) and (V>dat[j+1]) then cc:=j;
                if cc=AdrHi
                  then V:=Litr[AdrHi]
                  else begin
                    V:= (dat[cc]-V);
                    j:=(Litr[cc+1]-Litr[cc]);
                    V:= V * j;
                    j:=(dat[cc]-dat[cc+1]);
                    V:= V / j;
                    V:= V + litr[cc];
                  end;
              end;
          end;
        Razr(V);
        sign := V < 0;
        L100 := V div 100;
        V100 := V mod 100;
        L10:= V100 div 10;
        L1 := V100 mod 10;
        //L10 := V div 10;
        //L1  := V mod 10;
        if (SW = 0) then
         begin
         delay_ms(3000);
          begin
           C1 := 1;
           C2 := 1;
           C3 := 1;
           portc := $3B;
           porta.4 := 1;
           calibrN := 0;
           mode := stCalibr;
           delay10;
           repeat until SW = 1;
          end;
          delay10;
        end;
      end;
    end;
    if mode = stCalibr then
    begin
      Razr(litr[calibrN]);
      //sign := litr[calibrN] < 0;
      L100 := litr[calibrN] div 100;
      V100 := litr[calibrN] mod 100;
      L10  := V100 div 10;
      L1   := V100 mod 10;
      if i > 127 then
      begin
        C1 := 0;
        C2 := 0;
        C3 := 0;
      end;
      if SW = 0 then
      begin
        delay10;
        delay10;
        V:=adc_read(0);
        V:=V shr 2;
        EEPROM_Write(calibrN,VLo);
        inc(calibrN);
        if calibrN>AdrHi then
        begin
           mode:= stNormal;
           CalibrN:=0;
           delay10;
           delay10;
           delay10;
           delay10;
           ReadData;
        end;
      end;
    end;
    delay10();
    cc := i mod 3;
    if cc = 2 then begin
      C1 := 0;
      C2 := 0;
      {if sign then begin
        portc := $3B;
        porta.4 := 1;
      end else }
        Led(L100);
      C3 := 1;
    end else if cc = 1 then begin
      C1 := 0;
      C3 := 0;
      Led(L10);
      C2 := 1;
    end else
    begin
      C2 := 0;
      C3 := 0;
      Led(L1);
      C1 := 1;
    end;
  end;
end.
Editat de mars01
nu am timp astazi sa merg sa cumpar picul daia am incercat sa vad daca merge in proteus sa nu le cumpar degeaba sa stea aruncate prin sertar, mam gandesc ca am eu geva probleme cu proteusul si nu functioneaza
Editat de kinderu56
Din cate se pare, da.
16F684 are mai multa memorie (flash si SRAM) cat si mai multe module.
Dar va trebui sa deschizi proiectul mikroPascal, sa modifici in proprietati registrii CONFIG (s-ar putea sa fie la fel dar nu este sigur) cat si sa schimbi numele uC-ului vechi cu cel nou. In programul efectiv trebuie dezactivat comparatorul suplimentar care se gaseste in 16F684.
Apoi recompilezi si folosesti fisierul .HEX generat.
Editat de mars01
Aproape de fiecare data cand cineva vine si zice ca programul ii merge simulat in Proteus dar nu merge in realitate, este o problema de configurare registri ...
Poate ai noroc si functioneaza si in realitate, dar nu este o garantie.
Programul modificat pentru 16F684.
A trebuit umblat la comparatoare, registrul CMCON a devenit CMCON0 si CMCON1 pentru ca 16F684 are 2 comparatoare spre deosebire de 16F676 care are doar unul singur.
Acestea sunt singurele modificari (in afara de modificarea registrilor CONFIG din meniul mikroPascal de configurare a proiectului).
program bakometr;
const
   AdrHi : byte = 2;
var
    i, j, cc: byte;
    V100 : word;
    mode : byte;
    calibrN : byte;
    sign : byte;
begin
  sign := V < 0;
  sign := 0;
  L100 := V div 100;
  V100 := V mod 100;
  L10:= V100 div 10;
  L1 := V100 mod 10;
end;
begin
  if I=0 then begin
    portc:=$04;
    porta.4:=0;
  end;
  if I=1 then begin
    portc:=$2D;
    porta.4:=1;
  end;
  if I=2 then begin
    portc:=$22;
    porta.4:=0;
  end;
  if I=3 then begin
    portc:=$28;
    porta.4:=0;
  end;
  if I=4 then begin
    portc:=$09;
    porta.4:=1;
  end;
  if I=5 then begin
    portc:=$18;
    porta.4:=0;
  end;
  if I=6 then begin
    portc:=$10;
    porta.4:=0;
  end;
  if I=7 then begin
    portc:=$0D;
    porta.4:=0;
  end;
  if I=8 then begin
    portc:=$00;
    porta.4:=0;
  end;
  if I=9 then begin
    portc:=$08;
    porta.4:=0;
  end;
end;
procedure delay10;
begin
  delay_ms(10);
end;
procedure ReadData;
begin
end;
begin
  porta := %00000000;
  trisa := %11001001;
  portc := %11111111;
  trisc := %00000000;
  wpua  := %00000001;
  cmcon0 := %00000111;
  cmcon1 := %00000111;
  ansel := %00000001;
  adcon0:= %00000000;
  adcon1:= %00110000;
  mode:=stNormal;
  ReadData;
  ADC_Init;
  i := 0;
  while true do
  begin
    inc(I);
    begin
      begin
        C1:=0;
        C2:=0;
        C3:=0;
      end; }
      if i=0 then
      begin
        V:=ADC_Read(0);
        V:=V shr 2;
        if V<=dat[AdrHi]
          then V:=litr[adrHi]
          else begin
            if V>=dat[0]
              then V:=litr[0]
              else begin
                if cc=AdrHi
                  then V:=Litr[AdrHi]
                  else begin
                    V:= (dat[cc]-V);
                    V:= V * j;
                    V:= V / j;
                    V:= V + litr[cc];
                  end;
              end;
          end;
        Razr(V);
        sign := V < 0;
        L100 := V div 100;
        V100 := V mod 100;
        L10:= V100 div 10;
        L1 := V100 mod 10;
        //L10 := V div 10;
        //L1  := V mod 10;
        if (SW = 0) then
         begin
         delay_ms(3000);
          begin
           C1 := 1;
           C2 := 1;
           C3 := 1;
           portc := $3B;
           porta.4 := 1;
           calibrN := 0;
           mode := stCalibr;
           delay10;
          end;
          delay10;
        end;
      end;
    end;
    begin
      L10  := V100 div 10;
      L1   := V100 mod 10;
      if i > 127 then
      begin
        C1 := 0;
        C2 := 0;
        C3 := 0;
      end;
      if SW = 0 then
      begin
        delay10;
        delay10;
        V:=adc_read(0);
        V:=V shr 2;
        inc(calibrN);
        begin
           mode:= stNormal;
           CalibrN:=0;
           delay10;
           delay10;
           delay10;
           delay10;
           ReadData;
        end;
      end;
    end;
    delay10();
    cc := i mod 3;
      C1 := 0;
      C2 := 0;
      {if sign then begin
        portc := $3B;
        porta.4 := 1;
      end else }
        Led(L100);
      C3 := 1;
      C1 := 0;
      C3 := 0;
      Led(L10);
      C2 := 1;
    end else
    begin
      C2 := 0;
      C3 := 0;
      Led(L1);
      C1 := 1;
    end;
  end;
end.
Proiectul incluzand is fisierul .HEX este aici.
Editat de mars01
cel cu leduri sigur functioneaza si fizic osa il incerc si pe o placa test , iar cea cu digiti, asta nu functioneaza nici in proteus
la prima pornire in proteus se aprind segmentele G de la ambi digiti si dupaia ramane aprins doar digiti 1 si afiseaza litera U si asa ramane sa vad daca am timp sa il arunc si pe o placa test dar banuiesc ca se comporta la fel
Afisajul este cu anod comun, in simularea ta este cu catod comun.
Sunt mai multe scheme in folderul atasat de tine, in una butonul de calibrare este pus pe pinul 4, in alta pe 13 si probabil ca trebuie gasit hexul corespunzator schemei.
Proiectul testat de mine,care afiseaza corect, este cel slavat cu denumirea ok 2, cu hexul de pe calea "Litrometru\New folder\bakometr 2\bak2.hex" din arhiva atasata la postarea #1 si cu afisaj cu anod comun.
Calibrarea se face din buton, zero insemnand cea mai mare tensiune de pe intrarea analogica si 40l corespunde celei mai mici tensiuni.
Pe intrarea analogica am pus un potentiometru de 10k conectat la 5V.
DA este ok acuma functioneaza ,nu am fost eu atent la tipul de lcd, cu anod comun referitor la hexul pentru pic 16f684 acesta tot nu functioneaza am incercat si cu lcd cu anod comul si cu catod comun si face la fel doar ca pe celalalt digit , ce nu integ eu prea bine este partea cu calibrarea ,potentiometrul lai pus pe pinul 12 ,ce rol are mai exact?
Nu stiu daca pentru mine era intrebarea, insa o sa-ti spun ca potentiometrul din simulare reprezinta sonda de nivel din rezervorul de benzina.
Pentru o indicatie cat mai aproape de realitate, trebuie facuta calibrarea.
In functie de versiunea de hex, ea se face pentru fiecare doi sau patru litri de combustibil adaugati in rezervor.
Calibrarea se face la montarea dispozitivului pe masina sau in cazul in care se inlocuieste sonda de nivel.
Cand rezervorul este gol, se apasa butonul de calibrare, apoi se aduga doi litri de combustibil si se apasa din nou butonul, pe afisaj la fiecare apasare este afisata cantitatea de combustibil pentru care se face calibrarea la acel moment.
Valorile citite de pe intrarea analogica pentru fiecare apasare de buton sunt retinute in eprom, iar asta inseamna ca daca calibrarea este corect realizata, la urmatoarea alimentare a montajului (folosire) nu mai este nevoie de calibrare.
Calibrarea este incheiata cand se ajunge la 40 de litri.
Se pare ca exista prin arhiva si hexuri pentru rezervoare mai mari.
Editat de Elison
