Comenzi mikcroC
catalin004
Salutare...am intrebat intr-un topic anterior, daca se poate shift-a scrisul pe un singur rand, sau daca exista o singura comanda de blinking pe display(adica sa apara/dispara scrisul) in afara de ajutorul delay-ului impeuna cu comenzile Clear si LCD-out intermitente....
  • Răspunsuri 1
  • catalin004
  • mars01
Zile populare
mikroC help:
Available Lcd Commands
Lcd Command                 Purpose
_LCD_FIRST_ROW              Move cursor to the 1st row
_LCD_SECOND_ROW             Move cursor to the 2nd row
_LCD_THIRD_ROW              Move cursor to the 3rd row
_LCD_FOURTH_ROW             Move cursor to the 4th row
_LCD_CLEAR                  Clear display
_LCD_RETURN_HOME            Return cursor to home position, returns a shifted display to its original position. Display data RAM is unaffected.
_LCD_CURSOR_OFF             Turn off cursor
_LCD_UNDERLINE_ON           Underline cursor on
_LCD_BLINK_CURSOR_ON        Blink cursor on
_LCD_MOVE_CURSOR_LEFT       Move cursor left without changing display data RAM
_LCD_MOVE_CURSOR_RIGHT      Move cursor right without changing display data RAM
_LCD_TURN_ON Turn           Lcd display on
_LCD_TURN_OFF Turn          Lcd display off
_LCD_SHIFT_LEFT             Shift display left without changing display data RAM
_LCD_SHIFT_RIGHT            Shift display right without changing display data RAM
Pentru deplasarea unei singure linii trebuie sa iti faci propria functie folosindu-te de LCD_cursor().
Editat de mars01
