Receptor simplu CB/NBFM
Mark S
La 25.06.2023 la 8:57, FLY a spus:
Pinul 3 al TDA7000 este de la blocul intern al integratului numit "Noise Source", nu are legatura cu frecventa intermediara de 70KHz Wide FM sau 15KHz NBFM.
Cum s-a spus anterior, IC-ul demoduleaza NBFM si cu FI 70KHz dar cu volum mai scazut.
"TDA7000 Values
As as I wrote at the outset, the 5kHz IF recommended by Philips was found to be quite impractical, so I adjusted the capacitor values a little to center the IF on 10kHz. This still allows the receiver to give a reasonable output with +/-2.5kHz deviation (NBFM). Excessive deviation causes the MUTE circuit to close the receiver. There is no reason why you should use this project for WBFM, except perhaps to have a more stable receiver. But here are the capacitor values. I have indluded the Philips recommended values, just in case you want to have a fiddle.
Table of TDA7000 Capacitor Values
Capacitor WBFM (IF=70kHz) NBFM (IF=10kHz) NBFM (IF=5kHz)
C1 150n 150n 150n
C2 1n8 100n 2n7
C3 22n - -
C4 10n 4n7 4n7
C5 10n 100n 100n
C6 - - -
C7 47n 100n 100n
C8 330p 2n2 2n2
C10 10n 100n 4n7
C11 3n3 47n 100n
C12 150p 2n2 3n3
C13 2n2 1n0 1n0
C14 10n 1n0 1n0
C15 100n 10u 4u7
C17 330p 2n2 4n7
C18 220p 2n2 2n9
Note that C6, C9, and C16 do not exist because the capacitor numbers have been chosen to follow the TDA7000 pin numbers. The middle column above is the one I used to get the project working. C3 has been omitted to disable the internal noise generator, to give "silent tuning". Atunci and am afirmat ca acel C3 are legatura si cu NBFM am avut in vedere si acest tabel a lui  sm0vpo.
Bate vantul, bata-l vina, precum cucu-n Bucovina. Odata cu "plecarea" mea, sectiunea asta a devenit pustie. Si odata cu mine, au plecat mai multi....din pacate, unii din noi, de tot. Politica fals-elitista a dus aici unde suntem acum.
Poate ca daca eram mai putin "atotstiutori" am fi colaborat mai mult. Pentru ca inainte de elitism, ar fi trebuit sa existe o pasiune pentru ceea ce facem.
De curiozitate, il intreb pe domnul YO9HRB de ce i-au trebuit cele 3 antenute active "MagicBon" odata ce nu stie sa le foloseasca ?
Sunt intrebari retorice, si da...oarecum fara sens. Pacat de ce am fost odata pentru ca nu am stiut sa intretinem.
Felix Cordonasu, Manzalesti, Buzau, Romania.
Acum 3 ore, millw0rm a spus:
De curiozitate, il intreb pe domnul YO9HRB de ce i-au trebuit cele 3 antenute active "MagicBon" - de curiozitate
odata ce nu stie sa le foloseasca ? - de unde ai dedus asta?
Sa-mi dai o adresa ca sa le trimit inapoi.
Acum 19 ore, millw0rm a spus:
Heheeee, bine ai (re)venit. Mie chiar mi-ai lipsit.
Ti-am citit si cateva dintre comentariile de pe facebuci. Stilul combativ este inconfundabil  :rade:
Astept sa vina lumina ... 1KW de lumina ...
