Ce capacitate are acest condensator ?
david alin
Ar putea fi vorba de un condensator capabil să stocheze tensiuni înalte, dar folosind ca dielectric mica, nu va putea avea o capacitate foarte mare, evident vorbind de niște dimensiuni fizice rezonabile.....
Off topic:
The surface of the Earth is negatively charged, carrying 500,000 Coulombs © of electric charge (500 kC),[2] and is at 300,000 volts (V), 300 kV,[3] relative to the positively charged ionosphere. There is a constant flow of electricity, at around 1350 amperes (A) [approximately 1100 A][3], and resistance of the Earth's atmosphere is around 220 Ohms.[3] This gives a power of around 400 megawatts (MW). There is no feasible means to harvest this power, which in any case averages a mere 0.8 microwatts per square metre of the earth's surface (compare solar radiation which is one billion times as large).
The charge is maintained by the stream of charged particles from the Sun. This process affects the ionosphere, as well as the troposphere, possibly causing thunderstorms. The electrical energy stored in the Earth's atmosphere is around 150 gigajoules (GJ).
The Earth-ionosphere system acts as a giant capacitor, of capacity 1.8 Farads.
The Earth's surface carries around -1 nC of electric charge per square meter.
Credeti-ma,am ajuns sa citesc manuale avansate de electrotehnica electronica,de specialitate...I tot nu am reusit sa inteleg cum e cu nenorocita asta de capacitate electrostatica a condensatorului...Daca zicea capacitate electrica,intelegeam ca e vorba de o tensiune cat mai mare pe care sa o suporte condensatorul...
Dl Validae,cu dielectricul o rezolv eu cumva,am tabel cu valorile dielectricelor..mica e destul de buna ,se strapunge destul de greu,chiar Tesla o folosea la condensatoarele lui si o recomanda,pus si in vid e exceptional dupa teoria lui..insa pot pune ulei de transformator si as mari considerabil capacitatea dielectrica a izolatorului dintre armaturi...
Ce o fi domle capacitatea electrostatica a unui condensator??
Miticamy,bun de stiut !Dar probabil extraterestrii beneficiaza din plin de ofertele electrice oferite de univers..noi pamantenii inca ne confruntam cu revolutia si criza electrica:-)))dar si de electroni..
Editat de david alin
Sunt doua feluri de capacitati electrice. Unul este capacitatea proprie a unui conductor izolat in spatiu si depinde de forma si dimensiunile acestuia. Se masoara, traditional, in cm. O sfera conductoare cu raza de 1 cm are capacitatea proprie de 1 cm, aproximativ 1 pF. Pamantul are capacitatea proprie de cca. 0,65 F si poate avea orice potential electric. Al doilea este capacitatea relativa dintre doi conductori apropiati in spatiu, cazul condensatoarelor electrice. Diferenta de potential (tensiunea) dintre electrozi este limitata de grosimea si calitatea izolatiei.
Realizarea unui condensator la tensiuine mare nu pune probleme. Dielectricii solizi si lichizi rezista la 20 - 40 kV/mm. Problema incepe acolo unde se termina condensatorul, in aer. Aerul se strapunge usor, mai ales la presiune mica sau in apropierea unui conductor subtire ori ascutit. Intre doua sfere de mari dimensiuni si la presiune normala aerul se strapunge la 3 kV/mm.
Condensatoare usor de facut si de buna calitate sunt cele cu hartie. Intre electrozii sub forma de folie se aseaza unul sau mai multe straturi de hartie poroasa impregnata cu un dielectric lichid, de exemplu ulei de transformator. Parafina nu este buna, deoarece isi modifica volumul cand se solidifica sau se topeste si poate crapa la frig. Hartia (de condensator) este doar suportul dielectricului. Important este sa nu ramana deloc aer in condensator.
Tesla nu era prost, dar in 1901 nu se stia mai nimic despre natura cuantica a undelor electromagnetice. De-abia in 1905 Einstein a publicat prima lucrare serioasa despre efectul fotoelectric extern, pentru care a si luat premiul Nobel in 1921.
Da,m-am documentat despre aportul lui Heinrich Hertz si Wilhelm Hallwachs(1888-1889 , descopera efectele fotoelectrice),Phillip Lenard (1905 unde ia premiul Nobel pt descoperirea legilor efectului fotoelectric) cat si a lui Albert Einstein (1921 luand si el premiul Nobel pt explicarea efectului fotoelectric)mentionat de dl Puriu..
Cu toate acestea,paradoxal Tesla nu doar ca era un geniu,insa daca ne uitam chiar si la brevete ,vedem clar ca si el stia de efectul fotoelectric extern si se folosea acest efect in experimente..Aplicand cu succes si recomandand folosirea
luminii ultraviolete pt a facilita descarcarea electrica...deci stia de efectul fotoelectric extern si mr Tesla...
Bun,problema condensatorului pe undeva am cam inteleso,trebuie izolat foarte bine,vidat bine si construit bine..Exista condensatori vidati care au si mica??
Expresiile ca "electrostatic" si electrodinamic" vin din asemanarea sarcinilor electrice cu fluidele (apa de exemplu). Practic, daca se echivaleaza potentialul (diferenta de potential intre doua puncte, tensiunea electrica sau voltajul) sau cu presiunea, curentul electric cu debitul si sectiunea conductei cu sectiunea conductorului se poate face o explicatie educata despre ce este curentul electric si manifestarile acestuia.
Acum, "presiunea statica" ar echivala cu "electrostatica" sau potentialul in care nu se produce lucru mecanic (generator Van Der Graaff, cresterea potentialului sau a tensiunii), iar "electrodinamica" ar fi "curgerea" curentului electric (circuite cu baterii, generator electric, conductoare si consumatori) prin conductoare si efectele acestuia.
Ceva de genul acesta.
