Den Postat Iunie 30, 2017 Partajează Postat Iunie 30, 2017 Nota.Plata se face in cont,metoda transport la alegere1.Unitate pc /kit calculator:-placa de baza MSI MS-7501 VER 3.1-procesor dual core Amd Athlon X2 7750 BE 2 x 2.7Ghz-ram 4Gb ddr2-Placa video Ati Hd4550 128Mb ddr3 /hyperMemory to 512MB dvi+vga+hdmi-dvdwriter-cititor carduri+esata-sursa FSP 300/350W-hdd 160Gb /pataPerfect functional,silentios.Pret 180lei+transport calculatorul completPret 100lei+transport (placa de baza+procesor+4gb ram+cooler)http://i.imgur.com/LcdY7wm.jpg2.Unitate pc /calculator dual core HP Dc7700sff-procesor pentium dual core e5300 2 x 3.45Ghz (modificat prin bsel mod,independent de bios)-ram 4Gb ddr2-dvdwriter-hdd sata 40gb (mai accepta inca 1buc. hdd)-video integrat intel gma3000.Suporta placa video tip low profile.Pret 100lei+transporthttp://i.imgur.com/DGZqI6t.jpg3.Unitate pc /kit calculator:-placa de baza Asrock N68C-S-procesor dual core Amd Athlon2 X2 220 BE 2 x 2.8Ghz-ram 2Gb ddr3-Placa video nvidia 9600gso 384mb ddr3/256bit-dvdwriter-cititor carduri+esata-hdd 40Gb /pataPerfect functional,silentios.Pret 150lei+transport calculatorul completPret 90lei+transport (placa de baza+procesor+2gb ram+cooler)http://i.imgur.com/yNYvb2b.jpg4.Placa de baza socket 478 biostar P4VTB +512mb +procesor celeron 2.4ghzTestata,functioneaza bine.Nu am shield la eaPret 15lei+transporthttp://i.imgur.com/8SZiH1Q.jpg5.Kit memorie ram ddr3 2 x2Gb (4Gb)Pret 60lei+transport6.Kit memorie ram ddr1 2 x 1Gb (2Gb)pret 20lei+transport7.memorii ram desktop 1GB ddr3 Kingston pc3 10600uPret 15lei+transport/buc./ sau 25lei+transport 2 buc.8.Memorii ram ddr2-3 x 1gb ddr2 /pret 35lei+transport-6 x 512mb ddr2 /pret 20lei+transport-1Gb ddr2/pret 10lei buc. +transport9.Placa de baza lga775 ms7204 +procesor pentium d 820 +placa sunet-are cipul de sunet scos/perfect functionala.Nu suporta decat pentium d.Format MBTX.Pret 20lei+transport10.Procesoare:socket lga755:-pentium 4 631 3Ghz/2m/800fsb pret 5lei-pentium 4 641 3.2Ghz/2mb/800fsb pret 10lei-pentium D820 2x2.8Ghz/2mb/800fsb pret 10lei-pentium D830 2x3Ghz /2mb/800fsb pret 20lei-Pentium E2160 2x1.8Ghz/1mb/800fsb pret 5lei-Celeron E3400 2x2.6Ghz/1mb/800fsb pret 5lei-core2duo E6300 2x1.8Ghz/2mb/1066fsb pret 5lei-core2duo E4500 2x2.2ghz/2mb/800fsb pret 10lei-pentium E5800 2x4.1ghz/2mb/1066fsb pret 30lei (modificate,pt sistemele dell si o parte din hp care suporta 45nm,ecs/biostar.etc)socketAm2-sempron Le1100 pret 5lei-sempron 3400+ pret 0lei-sempron 3600+ pret 0lei Link spre comentariu
Den Postat Iulie 2, 2017 Autor Partajează Postat Iulie 2, 2017 (editat) 11. Rack extern /adaptor hdd 3.5 /interfata sata /packard bell Perfect functional.Se da fara cablu (usb 2.0) si fara alimentator (12v/2A). pret 45lei+transport Editat Iulie 2, 2017 de Den Link spre comentariu
Den Postat Iulie 4, 2017 Autor Partajează Postat Iulie 4, 2017 12.Radiator mbtx /4 heatpipesPret 10lei+transporthttp://imgur.com/x3ZlQZ5 Link spre comentariu
Den Postat Iulie 5, 2017 Autor Partajează Postat Iulie 5, 2017 13.Set 3 radiatoare al/miez cupruPret 20lei+transport (bonus cel din stanga jos)14.Cooler socket 939 / 4 heatpipesPret 20lei cu ventilator 4 fire (pwm) sau 15lei cu ventilator 3 firehttp://imgur.com/7WPddtq15.set 2 coolere socket lga 775Pret 15lei+transport (cel din dreapta cu prindere suruburi)16.Cooler socket AM2/Am3 /Fm1/2 /etc / tdp 120WPret 20lei+transport cel din stanga (ceva zgarieturi pe talpa)/Pret 25lei+transport cel din dreaptahttp://imgur.com/84nil4Q17.Set 3 ventilatoare 4 fire (control pwm)Pret 25lei+transport18.Set 9 ventilatoare 12vPret 10lei+transport (cel mic din stanga e pe 5v -Nidec-)19.Hdd sata 250gb samsung sp2504c -functional,tin un windows pe el.pret 25lei+transport sau se poate lua in combinatie cu pct 11 la 50lei+transport Link spre comentariu
Den Postat Iulie 6, 2017 Autor Partajează Postat Iulie 6, 2017 20.Set 3 bucati ventilator 12v 120mm pret 20lei+transport Link spre comentariu
Den Postat Iulie 11, 2017 Autor Partajează Postat Iulie 11, 2017 Nu mai sunt valabile punctele 2,3,6,11 si 19. Link spre comentariu
Den Postat Iulie 12, 2017 Autor Partajează Postat Iulie 12, 2017 21.Laptop Asus X52J-procesor i5 M480-ram 4Gb ddr3-hdd 500gb-video hd6370 1Gb1.Bateria este defecta.2.Problema cu cablu lvds,face figuri cand se misca ecranul.In pozitia normala de vizualizare este ok.3.Sunet slab,se intrerupe la vol maxim,posibil driver,iesire buna.Nu l-am desfacut.Pret 350lei +transporthttp://imgur.com/jWK2A5e Link spre comentariu
Den Postat Iulie 13, 2017 Autor Partajează Postat Iulie 13, 2017 22.Unitate pc /calculator dual core-placa de baza Gigabyte GA-M68M-S2P-procesor Amd Athlon 2 250 2 x 3GHZ-ram 2 gb ddr2-placa video nvidia 9600GSO 348Mb ddr3/256bit-hdd sata 160Gb-dvdwriterPret 170lei+transport -completPret 120lei+transport -fara placa videoPret 90lei+transport -placa de baza+procesor+2gb ram+coolerhttp://imgur.com/1l7U4KH Link spre comentariu
Den Postat Iulie 14, 2017 Autor Partajează Postat Iulie 14, 2017 22.Unitate pc /calculator dual core -nu mai este valabil. Link spre comentariu
Den Postat Iulie 19, 2017 Autor Partajează Postat Iulie 19, 2017 23.Memorie ram desktop 2Gb ddr2 samsung pc2-6400uPret 35lei+transport24.Hdd desktop /pe verde-160gb interfata pata/ide pret 30lei+transport /WD-160gb interfata sata pret 35lei+transport /seagate-320gb interfata sata pret 55lei+transport-500gb interfata sata pret 75lei+transport /hitachi-500gb interfata sata pret 90lei+transport /seagate pipeline hd Link spre comentariu
aluneanu Postat Iulie 19, 2017 Partajează Postat Iulie 19, 2017 salut ,pentru punctul unu as dori sa discutam in privat ,dar nu reusesc ! Link spre comentariu
Den Postat Iulie 19, 2017 Autor Partajează Postat Iulie 19, 2017 Vezi daca iti functioneaza acum,daca nu, fa un post util pe forum (cu exceptie divertisment/diverse) si iti apare mesageria. Link spre comentariu
Den Postat Iulie 24, 2017 Autor Partajează Postat Iulie 24, 2017 (editat) 1.Calculator dualcore Medion-procesor dual core Amd Athlon II X2 220 2 x 2.8GHZ-ram 4Gb ddr2-Placa video Nvidia 9600GSO 384Mb ddr3/256bit-hdd sata 250Gb-dvdwriter-cititor carduri+esataPerfect functional,silentios. Pret 180lei+transport Editat Iulie 24, 2017 de Den Link spre comentariu
Den Postat Iulie 27, 2017 Autor Partajează Postat Iulie 27, 2017 25.Tastatura gaming iluminata MYRIA HK-880iPret 20lei+transporthttp://imgur.com/9RHqufZ Link spre comentariu
FLORIN IORDACHE Postat Iulie 27, 2017 Partajează Postat Iulie 27, 2017 (editat) 25.Tastatura gaming iluminata MYRIA HK-880i Pret 20lei+transport http://imgur.com/9RHqufZ Aceasta tastatura functioneaza complet ??? Si a-si mai dori sa mai stiu ce mufa are,adica ps2 sau usb. MULTUMESC !!! Astept raspuns !!! Editat Iulie 27, 2017 de FLORIN IORDACHE Link spre comentariu
