Pompa submersibila / panou solar
jeltopop pop
Salut,
Vreau sa scot apa dintr-un put de la adancimea de 3 metrii.
Apa este utilizata la irigat. Necesarul de apa este aprox. de 100l/zi pentru 1 ora,
Ce tip de pompa,bazin si sistem panou solar credeti ca pot utiliza?
Daca are cineva experienta , va rog un sfat.
Pop.
cred ca omul cauta asa ceva
http://www.lpelectric.ro/ro/applications/applications_pump_ro.html
mi se pare cam scumpa, dar asta am gasit la repezeala. se poate gasi pompa de 12-24 V si un panou, care sa functioneze doar pe timp de zi. trebuie avut in vedere si faptul ca la cei 3 metri de apa se mai adauga vreo 4-5 metri pana la inaltimea bazinului.
sau asta
https://fr.aliexpress.com/item/New-24v-high-pressure-brushless-DC-pump-for-rockery-fountain-cooling-circulation-system-100-waterproof-submersible/32743924836.html?spm=2114.01010208.3.11.tqRxMC&ws_ab_test=searchweb0_0%2Csearchweb201602_6_10000073_10065_10068_10501_10000074_10000132_10000033_10503_10000030_119_10000167_10000026_10000175_10000126_10000023_10000129_10000123_432_10000069_10000068_10060_10062_10056_10055_10054_10000063_10059_10000120_10099_10000020_10000156_10000158_10000013_10000117_10103_10102_10000016_10000114_10096_10000111_10052_10053_10050_10107_10051_10106_10000097_10000094_10000090_10000147_10000091_10000144_10084_10000150_10000101_10083_10000100_10080_10000153_10000104_10082_10000045_10081_10110_10000108_10111_10000191_10112_10113_10000197_10114_10000089_10000086_10000179_10000083_10000042_10000135_10000080_10078_10079_10000039_10073_10000140_10070_10000036_10122_10123_10126_10124_10000187-10503_10501%2Csearchweb201603_9%2Cafswitch_1%2CppcSwitch_5%2Csingle_sort_2_default&btsid=cd6f7467-2596-4ef1-8c70-d57281757e7d&algo_expid=02ca6836-5861-4269-9ee6-333d4f193708-1&algo_pvid=02ca6836-5861-4269-9ee6-333d4f193708
Ca rezervor se poate folosi un butoi din plastic cu cu 2 senzori de nivel, unul jos si unul sus, cere singur apa cand este
atins nivelul de minim si se opreste cererea cand este actionat senzorul de sus.
Cele mai eficiente ar fi pompele dc in sistemele cu panouri fotovoltaice dar sunt si scumpe.
O varianta mai accesibila ar fi o pompa ruseasca vibratoare de mici dimensiuni: http://micul-gospodar.ro/pompa-submersibila-ruseasca-bosna consuma 250W si se poate alimenta dintr-un sistem fotovoltaic a carui configuratie depinde de buget.
Doua panouri de 100W + un controler ieftin + ups sinus pur SH + o automatizare care sa tina totul sub control.
Robinetul de golire de la butoi poate fi tinut permanent deschis daca automatizarea taie pofta de apa a butoiului in perioada
cand nu trebuie udat sau poate fi montat un automat programabil de udare la gura lui.
Am ceva de acest gen construit acum cativa ani, pompa se afla la 18m si are doi senzori de nivel, unul imediat deasupra ei si altul la 1m mai sus. Este un put mai "lenes" care n-a fost folosit ceva timp si a trebuit sa fac asta pentru protectia pompei.
Cand este senzorul de jos fara apa taie alimentarea pompei si o repune cand este atins cel de sus. Senzorii sunt monitorizati permanent si stiu cand cablul lor este intrerupt sau in scurt, in caz de defect se opreste automat tot.
In plus, am pus si un senzor de temperatura la exterior si cand am 2 grade afara o electrovalva situata la 3 m sub nivelul pamantului goleste coloana de apa de deasupra astfel incat sa pot folosi pompa si iarna in caz de nevoie.
Nu ne-ai spus daca faci asta pentru economie de energie sau nu ai curent in acel loc.
Mutumesc pentru raspunsuri.
Am ales sa incerc asa ceva pentru ca nu am curent in locul respectiv.
Am cautat si eu pe net diferite tipuri de pompe la 12-24V si panouri.
Cred ce pentru 3m in fantana + 3 m inaltime pina la bazin, 250W sunt peste necesar. Nu?
Nu-mi trebuiesc mai mult de 100-200L / zi.
Poate mai sunt si alte persoane care au experimentat asa ceva.
Mai astept si alte pareri.
Daca trebuie sa cumperi toate componentele, cu regret te anunt ca este mai ieftin si mai rentabil sa utilizezi o motopompa. Cind termini, o demontezi si o pui la loc sigur. Sistemul cu panouri este elegant si ecologic dar atrade atentia.
Cu asta spal eu masina. Merge la 12v, consuma cam 3-4 A si imi goleste o galeata in 3-4 hai 5 minute. Tie daca iti merge o ora iti e de ajuns. Iei o baterie de 12v 7Ah si vii cu ea incarcata de acasa. O incarci seara pe redresor sau panouri daca vrei sa te complici. Am un furtun de 6m. Daca nu iti impinge suficient apa, mai pui o pompa identica.
Daca ai plantele pe randuri, uzi direct cu ea, nu mai pui nici butoi.
Editat de Vizitator
Intervine din nou in discutie , creearea unui sistem de irigare cu ajutorul panourilor solare fotovoltaice , pentru zonele unde nu exista alimentare de la retea .
Chiar in acest moment am in constructie un sistem de irigare tot dintr-un bazin de acumulare care are aproximativ 5m adancime , si care va scoate apa din el , si o va urca intr-un rezervor de 1000 l din acela de se punea in el lac electroizolator , cumparat , spalat si aranjat , pentru a nu iriga direct cu apa rece . Astfel pe timp de zi se urca apa acolo in bazin , se incalzeste si pe seara dupa ce am scapat de arsita , un controller da drumul la apa din bazin si gradina de legume se iriga.
Acum incepe partea interesanta sa spun asa , a discutiei , ... in sensul in care eu voi alimenta pompa din reteaua de energie electrica , dar am ales-o special ca putere , pentru ca ulterior cand se va dori sistemul sa poata fi eficient convertit pentru alimentare cu ajutorul unui sistem solar fotovoltaic.
Bun deci poate incepe analiza : cost-eficienta.
Am ales pentru sistemul meu , o pompa , care se preteaza foarte bine si in cadrul sistemului dumneavoastra , si este vorba despre o pompa submersibila cu electromagnet si pe care o puteti vedea detaliata alaturi de alte poze la acest link : https://drive.google.com/open?id=0B11Lv8LBH8yCS1lCTWpKNkZQZXM
Ea are un consum de (210w dar se duce la 250w/h ), iar eu am mai avut ocazia sa apreciez calitatea unui alt model de pompa cu electromagnet , Bosna LG Taifun 2 sau Vosna , se cunoaste faptul ca B in rusa este V , o pompa cu un consum ceva mai mare (250w da se duce la 300 ) , si cu un volum evident mai considerabil tot cu electromagnet , ce scoate apa dintr-o fantana la 37 m de 3-4 ani de zile fara probleme . Ideea e ca pe piata circula mai multe tipuri , si trebuie sa aveti mare atentie la comerciant , pentru ca daca este un fals pompa , statorul va fi bobinat cu sarma de aluminiu deci nu cu sarma de cupru , cum este modelul original .
Am prezentat pompa , si ma refer exclusiv la cea din poze , pentru ca o asemenea pompa ar fi indicata si pentru dumneavoastra , pentru ca aveti o adancime foarte foarte mica .deci nu la Bosna ma refer , ca in poze nu-i acest model ci altul , nu stiu sa vil spun pentru ca e scris in rusa , dar am gasit un model asemanator cu ce am achitionat eu la un pret rezonabil pe un site ce ofera si garantie normal la 140 lei . Din considerente legate de regulamentul forumului nu va pot da link cu magazinul aici pentru a nu creea publicitate dar putem sa vb in privat.
Acum mai intervine un aspect , crucial pentru acest proiect , ok am pompa si de unde o alimentez.
Am gasit , si am achizitioant , nu de mult 2 module fotovoltaice cu celule solare monocristaline de 250w fiecare la pretul de 600 ron fiecare , dar exista si varianta de sistem soalr cu celule policristaline de 250w la 570 ron / buc , si sunt preturi nu acceptabile , in opinia mea , uluitoare in conditiile in care un modul monocristalin de 250w ajunge la 1500 ron si nu scade sub 1200 , iar unul policritalin de aceeasi putere se duce la 1200 ron si nu scade sub 1000 ron.
Asa am vorbit putin de ce pompa ar fi buna , ok , ce panou sa iau ca idee , si acum practica ....
In practica las la latitudinea dumneavoastra sa apreciati , cat de fezabila va este o astfel de investitie ...
in sensul in care pompa consuma 250-300w/h in 220v AC nu puteti s-o alimentati de la un modul de 250w pentru ca panoul are si el pierderi , exprimate prin nivelul de eficienta al modulului si 250w la 24v nu pot fi convertiti tot in 250w la 220v AC deci va trebuie din start 2 module a cate 250w fiecare , pentru a alimenta pompa ...
ok ok , am si aceste 2 module sa zicem , dar cum fac sa duc tensiunea in 220v ? aici sunt 2 variante mari si late ...
1) cu un inverter on grid
2)cu sistem de stocare in baterii si invertor de ridicare in 220v
Varianta 1 implica sa achizitionati un inverter care ridica direct din panouri puterea debitata de acestea in 220v , luati panourile le legati in paralel ca se incadreze in plaja de tensiune suportata de inverter , si le conectati la inverter si aveti 220v cu vreo 400w oriunde pe camp , cand e soare , toate bune si frumoase pana va spun cam cat costa o chinezarie de invertor care face asta , pai in jur de 700 lei o chinezarie cu MPPT , nu detaliez , e un sistem care extrage maximul de putere din panouri , cam la asta se refera.
Varianta 2) implica sa luati un controller soalr ce va incarca o baterie de 12 sau un banc de 2 legate in serie la 24v , si asta implica iarasi o investitie de vreo sa zicem asa : 500 lei baterie / bucata + controller chinezarie foarte prost ... 50 lei , foarte bun pe care-l recomand de la Victron Blue soalr MPPT 100v 30A 1050 lei ... deci mult ... in opinia mea cel putin...
Cam acestea sunt variantele pentru care puteti opta ....
Costul mediu pentru instalatie asadar variaza intre : 2000 - 3500 ron . Mult , foarte mult , e adevarat , pompa in sine nu costa foarte mult , dar ceea ce rupe de lumea asta ca pret sistemul in sine , este convertirea luminii in electricitate , care si la momentul actual este foarte scumpa ...
Acum poate intelegeti si de ce antevorbitorii mei , propun alte sisteme pentru irigare alternative la aceasta cu panouri fotovoltaice ...
Toate cele bune , si sper sa gasiti o solutie cat mai avantajoasa din punct de vedere financiar , cu ajutorul careia sa solutionati problema irigarii .
T.Sorin 24.05.2017
Editat de T.Sorin
Salut,
Multumesc pentru sfaturi.
T.Sorin: Stiu despre ce pompa (zisa ruseasca) vorbesti.
Nu am cunostiinte in calculul puterilor necesare pentru situatia mea. Am sa mai caut pe net.
Totusi, eu zic ca puterea necesara pentru a asigura o cantitate de sub un metrucub de apa pe zi,
in conditiile in care trebuie scoasa de la 3m si ridicata tot cam atat pana sus la bazin,
250-300w sunt mult peste necesar.
Bazinul se poate umple si in 5 ore sa zicem. Nu ne grabeste nimeni. (poate Cel de sus, cu soarele)
Cam cum se calculeaza necesarul de putere in astfel de cazuri?
Editat de jeltopop pop
Daca in zona aveti un pic de vint ati putea construi cu costuri mult mai mici o pompa cu dopuri actionata de vint ( in genul celor din filmele western ).
Constructia unei pompe cu dopuri este simpla si o gasiti cred si in decedatul tehnium.
Conversia lumina - energie electrica - stocare - inverter CC- CA este foarte scumpa.
Nu te contrazic cu varianta western. Nu cred ca Romania este acum la alt nivel. Poate chiar mai jos.
M-am gandit si la eoliana. Dar nu cred ca merge in regim de amator. O furtuna de vara strica toata munca.
Nu am de gand sa stochez energia. Ma gandeam la varianta: Panou solar-> un regulator de tensiune (12V) -> pompa.
Banuiesc ca nu se arde pompa daca scade tensiunea de alimentare sub 12V, cand sunt nori. sau noapte.
Si daca sunt nori, oricum nu prea trebuie udat sau este posibil sa vina ploia :)
Nu iti trebuie necesar de putere. Ai nevoie de o pompa care sa faca ce ai nevoie. Trebuie sa urce apa 3m cu un debit pe care ti-l impui. Apoi cauti pompa, vezi cat papa si gasesti solutie de alimentare. Solutia mea cred ca ar fi cea mai ieftina. O astfel de pompita costa cam 40 de lei, mai pui una ca sa o ajute si iti mai trebuie o baterie. Daca vrei sa o lasi acolo bateria iti cauti panou si regulator de incarcare. Daca ai lua acumulator de 12v7Ah, are 2-3 kg si poti sa vii cu el gata incarcat zilnic si ii dai bice, sau iti iei 2. Unul il lasi seara sa impinga pana dimineata, cu oprire cand se umple bazinul, cu al doilea vii la schimb sa il lasi pt a doua noapte. Vei gasi bazinul plin zilnic, te apuci de treaba, lasi instalatia de umplere in functiune, te asiguri ca se opreste la plin nu la terminarea bateriei si gata.
Editat de Vizitator
Vreau totusi sa incerc varianta: Panou->stabilizator tensiune-> pompa (12V sau 24V).
Poate sunt ceva sfaturi pentru aceasta varianta.
Nu vreau cu moristi de vant, acumulatori (fie ei si incarcati acasa) sau motopompe.
Te sfatuiesc sa ai si acumulator in sistemul propus de tine. Adica panou >>> regulator de incarcare >>> n-ai nevoie de stabilizator >>> acumulator >> pompa. Si inainte de pompa un element de on/off chiar programabil. E bine sa lasi ziua sa se incarce acumulatorul, seara pe la 5 sau cand vrei sa urci apa in bazin si cand uzi sa ai disponibilul gata de udare.Sau daca uzi dimineata, noaptea pompezi, ziua incarci bateria si dimineata ai stocul pregatit. Uite un exemplu de pompa la 12V, 3A , 4 metri, care se preteaza la agricultura. https://www.okazii.ro/pompa-apa-submersibila-12v-1100gph-4000-litrii-pe-ora-a182218495
E plin netul de astfel de pompe. Spun ca nu iti trebuie stabilizator pentru ca ai 12V din baterie in situatia propusa de mine. Ca e cu 1 V in plus, pt un motor nu e deloc nasol. ***baterie=acumulator in acest post
Editat de Vizitator
