Nu stiu ce radiator de AL sa aleg pentru puterea disipata !
Cilibiu
Pune o poza de rezolutie mare cu toate cele 4 radiatoare unul linga altul ca sa ne facem o ideie de dimensiunile lor comparative.
Pune si o rigla linga ele.
As vrea sa pun doar 4 integrate pe primul radiator.
Ce ziceti?
E mai ok?
Your Input: Parametric Values
Material: Aluminum (extruded)
Width: 300 mm
Length: 145 mm
Height: 25 mm
Base Thickness: 5,5 mm
Fin Thickness: 4 mm
Number of Fins: 30
Calculation Result: Thermal Resistance & Pressure Drop
Airflow Rate - Thermal Resistance - Pressure Drop
0.5 m/s (~100 LFM) 0.34 °C/W 1.7 Pa (0.007 inH2O)
1.0 m/s (~200 LFM) 0.25 °C/W 4.5 Pa (0.018 inH2O)
1.5 m/s (~300 LFM) 0.21 °C/W 8.2 Pa (0.033 inH2O)
2.0 m/s (~400 LFM) 0.19 °C/W 13.5 Pa (0.054 inH2O)
2.5 m/s (~500 LFM) 0.17 °C/W 19.2 Pa (0.077 inH2O)
3.0 m/s (~600 LFM) 0.16 °C/W 25.7 Pa (0.103 inH2O)
3.5 m/s (~700 LFM) 0.15 °C/W 33.0 Pa (0.132 inH2O)
4.0 m/s (~800 LFM) 0.14 °C/W 41.0 Pa (0.165 inH2O)
4.5 m/s (~900 LFM) 0.13 °C/W 49.8 Pa (0.200 inH2O)
5.0 m/s (~1,000 LFM) 0.13 °C/W 59.2 Pa (0.238 inH2O)
