Lampa proiector Toshiba TLP XD2000
blue36
Va salut.
Am luat din targ acest proiector, la pornire imi aparea avertismentul ca lampa a depasit numarul de ore de functionare, 2338 de ore, am resetat life timer-ul si nu mai am acest mesaj. Proiectorul functioneaza impecabil, am inclusiv contrast perfect.
Intrebarea mea este, daca fostul proprietar a schimbat lampa, counttimerul se reseteaza de la 0 sau imi apare in meniu la reset lamp 1 si arata in continuare numarul de ore de la lampa veche?
Inainte de resetare aveam in meniu la reset 0, acum am 1.
  • Răspunsuri 2
  • blue36
  • leoncris
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord
3. The lamp operation counter will automatically turn to zero
4. Check if the lettering "0H" appears on the lamp operation counter in the status display
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
Multumesc Leoncris, am resetat lamp time, intrabarea era, daca se schimba lampa, "total time" porneste de la zero sau imi ramane in continuare cu numarul de ore de functionare?
Ma gandesc ca fostul proprietar a schimbat lampa pentru ca functioneaza perfect. Cand l-am luat, la "lamp time" era acelasi numar de ore ca si la "total time".
Editat de blue36
