transformatoare retea 5.1
vera
Anul acesta am reparat 2 sisteme 5.1.
Postez aceste date. poate intereseaza pe cineva.
Orion HT-831
1-date trecute pe carcasa:
primar 220V/50Hz;
secundar 1-2x14,5V/4A;
secundar 2-2x11,5V/0,5A;
putere consumata 175W;
2-date masurate/numarate/calculate, etc:
primar 598sp/0,45(0,5)mm (numarate), J175W=5A/mmp, J132W=3,77A/mmp;
secundar 1-2x43sp/1.0(1,05)mm (numarate), J=5A/mmp;
secundar 2-2x35sp/0,45(0,5)mm, J=3,145A/mmp;
tole cu limba centrala=28,5mm, g=0,5mm, 86E+84I, Sef=86x0,05x2,85=12,255cmp;
n=598/220=2,7(18), k=33,31, B=13552Gs;
putere secundare=2x14,5x4+2x11,5x0,5=127,5W. La ac. P randamentul este 97%. Putere primar=131,5W;
carcasa nu a fost recuperata. Am facut alta.
3-am bobinat:
primar 780sp/0,38(0,43)mmp
secundar 1-2x51sp/1,0(1,05)mm;
secundar 2-2x42sp/0,45(0,5)mm
4-masuratori:
Uop=230V/Iop=106mA;
Uo1=2x14,94V
Uo2=2x12,95V
5-schimbat 1CI care era ars si care carbonizase circuitul imprimat (am refacut traseele ac. circuit).
trafo retea nu avea siguranta termica, in loc de siguranta fuzibila avand sarma.
Genius SW-HP 5.1
CTP10311-2;
INPUT 230V/50Hz/0,54A;
OUTPUT AC 28VCT/2,4A&12V/1A&10VCT/1,2A
TEMP FUSE M33JF, FUSE 3,15A/250V.
2-date masurate/numarate/calculate, etc.
trafo era umblat, anulata siguranta termica, primarul era original, in perfecta stare, secundarele arse, carcasa lor asemenea;
secundar 1-21sp/0,45(0,48)mm;
secundar 2-2x48sp/0,6(0,635)mm;
secundar 3-32+42sp (trebuiau 2xNspire)/0,8(0,85)mm;
tole E12,5, 106E+104I, g=0,5mm, Sef=106x0,05x2,5=13,25cmp;
N230=514sp/0,45(0,5)mm (calculate), np=2,2348sp/v, B=15212Gs (f mare), k=29,61
3-am bobinat
secundar 1-31sp/0,65(0,7)mm;
secundar 2-2x47sp/0,65(0,7)mmp;
secundar 3-2x24sp/0,85(0,9)mm.
4-masuratori:
Uop=230V/Iop=156mA;
Uo1=1x13,7V(alimentare TDA7360+pre);
Uo2=2x20,5V(alimentare 1xTDA7296);
Uo3=2x10,6V (alimentare 2xTDA7269).
5-schimbat 2xTDA7269 arse, refacut trasee circuit imprimat, montat siguranta termica.
PS-am un sistem 5.1 Silver Crest, cu 2xTDA8947J, fara transformator retea. Daca are cineva datele ac. traf, il rog sa mi le comunice.
Multumesc.
Editat de vera
  • Răspunsuri 0
  • vera
Zile populare
