Vizitator bufferzone Postat Decembrie 20, 2016 Partajează Postat Decembrie 20, 2016 Salut, Incerc sa transmit date de la Pic la un Raspberry Pi 3 si nu reusesc sub nici o forma. Va rog spuneti-mi daca codul sursa pentru pic este ok: /*************************************************************************************************** nRF24L01+ connections**************************************************************************************************/sfr sbit RF_IRQ_TRIS at TRISB7_bit;sfr sbit RF_CS_TRIS at TRISE0_bit;sfr sbit RF_CE_TRIS at TRISE1_bit;sfr sbit SCK_TRIS at TRISC3_bit;sfr sbit SDI_TRIS at TRISC4_bit;sfr sbit SDO_TRIS at TRISC5_bit;sfr sbit IRQ_pin at RB7_bit;sfr sbit SS_pin at RE0_bit;sfr sbit CE_pin at RE1_bit;sfr sbit SCK_pin at RC3_bit;sfr sbit MISO_pin at RC4_bit; //SDI Lectura Entradasfr sbit MOSI_pin at RC5_bit; //SDO Escritura Salidasbit Led at RC1_bit;#define R_REGISTER_cmd 0x00#define W_REGISTER_cmd 0x20#define R_RX_PL_WID_cmd 0x60#define R_RX_PAYLOAD_cmd 0x61#define W_TX_PAYLOAD_cmd 0xA0#define W_ACK_PAYLOAD_cmd 0xA8#define W_TX_PAYLOAD_NO_ACK_cmd 0xB0#define FLUSH_TX_cmd 0xE1#define FLUSH_RX_cmd 0xE2#define REUSE_TX_PL_cmd 0xE3#define NOP_cmd 0xFF#define CONFIG_reg 0x00#define EN_AA_reg 0x01#define EN_RXADDR_reg 0x02#define SETUP_AW_reg 0x03#define SETUP_RETR_reg 0x04#define RF_CH_reg 0x05#define RF_SETUP_reg 0x06#define STATUS_reg 0x07#define OBSERVE_TX_reg 0x08#define RPD_reg 0x09#define RX_ADDR_P0_reg 0x0A#define RX_ADDR_P1_reg 0x0B#define RX_ADDR_P2_reg 0x0C#define RX_ADDR_P3_reg 0x0D#define RX_ADDR_P4_reg 0x0E#define RX_ADDR_P5_reg 0x0F#define TX_ADDR_reg 0x10#define RX_PW_P0_reg 0x11#define RX_PW_P1_reg 0x12#define RX_PW_P2_reg 0x13#define RX_PW_P3_reg 0x14#define RX_PW_P4_reg 0x15#define RX_PW_P5_reg 0x16#define FIFO_STATUS_reg 0x17#define DYNPD_reg 0x1C#define FEATURE_reg 0x1Dunsigned char x = 0;unsigned char nRF24L01_read(){ unsigned char s = 0; unsigned char msg = 0; for(s = 0; s < 8; s++) { msg <<= 1; SCK_pin = 1; delay_us(8); if(MISO_pin != 0) { msg |= 1; } SCK_pin = 0; delay_us(8); } return msg;}void nRF24L01_write(unsigned char d){ unsigned char s = 0; for(s = 0; s < 8; s++) { if((d & 0x80) != 0) { MOSI_pin = 1; } else { MOSI_pin = 0; } d <<= 1; SCK_pin = 1; delay_us(8); SCK_pin = 0; delay_us(8); }}void register_write(unsigned char reg, unsigned char value){ SS_pin = 0; nRF24L01_write((reg | W_REGISTER_cmd)); nRF24L01_write(value); SS_pin = 1; delay_us(8);}void write_command(unsigned char cmd){ SS_pin = 0; nRF24L01_write(cmd); SS_pin = 1; delay_us(8);}unsigned char register_read(unsigned char reg){ unsigned char value = 0; SS_pin = 0; nRF24L01_write((reg | R_REGISTER_cmd)); value = nRF24L01_read(); SS_pin = 1; delay_us(8); return value;}void set_TX_RX_address(unsigned char *addr, unsigned char bytes, unsigned char reg){ unsigned char n = 0; SS_pin = 0; nRF24L01_write((reg | W_REGISTER_cmd)); for(n = 0; n < bytes; n++) { nRF24L01_write(addr[n]); } SS_pin = 1; delay_us(8);}void flush_TX_RX(){ register_write(STATUS_reg, 0x70); write_command(FLUSH_TX_cmd); write_command(FLUSH_RX_cmd);}void send_data(unsigned char bytes, unsigned char *value){ unsigned char s = 0; flush_TX_RX(); register_write(CONFIG_reg, 0x3A); SS_pin = 0; nRF24L01_write(W_TX_PAYLOAD_cmd); for(s = 0; s < bytes; s++) { nRF24L01_write(value[s]); } SS_pin = 1; delay_us(8); CE_pin = 1; delay_us(60); CE_pin = 0; register_write(CONFIG_reg, 0x38); //En modo RX se quita}void receive_data(unsigned char bytes, unsigned char *value){ unsigned char s = 0; SS_pin = 0; nRF24L01_write(R_RX_PAYLOAD_cmd); for (s = 0; s < bytes; s++) { value[s] = nRF24L01_read(); } SS_pin = 1; delay_us(8);}void nrF24L01_init_TX(){ unsigned char address[5] = {0x99, 0x99, 0x99, 0x99, 0x99}; CE_pin = 0; register_write(SETUP_RETR_reg, 0x00); register_write(SETUP_AW_reg, 0x03); register_write(RF_SETUP_reg, 0x0E); register_write(RF_CH_reg, 0x09); register_write(EN_AA_reg, 0x00); register_write(CONFIG_reg, 0x38); set_TX_RX_address(address, 5, TX_ADDR_reg); set_TX_RX_address(address, 5, RX_ADDR_P0_reg); flush_TX_RX(); CE_pin = 1;}void nrF24L01_init_RX(){ unsigned char address[5] = {0x99, 0x99, 0x99, 0x99, 0x99}; CE_pin = 0; register_write(CONFIG_reg, 0x38); register_write(SETUP_RETR_reg, 0x00); register_write(SETUP_AW_reg, 0x03); register_write(RF_SETUP_reg, 0x0E); register_write(RF_CH_reg, 0x09); register_write(EN_AA_reg, 0x00); register_write(RX_PW_P0_reg, 0x01); register_write(CONFIG_reg, 0x3B); set_TX_RX_address(address, 5, TX_ADDR_reg); set_TX_RX_address(address, 5, RX_ADDR_P0_reg); flush_TX_RX(); CE_pin = 1;}unsigned char get_Status_Reg(){ return register_read(STATUS_reg);} unsigned char val = 0;void main(){delay_ms(1000);//Enntradas con 1 y salidas 0 TRISA = 0x00; TRISB = 0x00; TRISC = 0x00; ADCON1 = 0x0F; PORTB = 0X00; PORTC = 0x00; RF_IRQ_TRIS = 1; RF_CS_TRIS = 0; RF_CE_TRIS = 0; SCK_TRIS = 0; SDI_TRIS = 1; //MISO SDO_TRIS = 0; //MOSI CE_pin = 0; SS_pin = 0; SCK_pin = 0; MOSI_pin = 0; delay_ms(1000); nrF24L01_init_TX(); delay_ms(900); while(1){ send_data(1, &x); porta = x; x++; delay_ms(1000); Led = 1; if (x == 6){ flush_TX_RX(); nrF24L01_init_RX(); delay_ms(900); porta = 0; x = 0; while(1){ if(get_Status_Reg() == 0x40) { receive_data(1, &x); porta = x; } } } }} Iar acesta este codul sursa pentru Raspberry Pi: import RPi.GPIO as GPIOfrom lib_nrf24 import NRF24import timeimport spidevGPIO.setmode(GPIO.BCM)pipes = [[0x99, 0x99, 0x99, 0x99, 0x99], [0xc2, 0xc2, 0xc2, 0xc2, 0xc2]]radio = NRF24(GPIO, spidev.SpiDev())radio.begin(0, 17)radio.setPayloadSize(32)radio.setChannel(0x05)radio.setDataRate(NRF24.BR_2MBPS)radio.setPALevel(NRF24.PA_MIN)radio.setAutoAck(True)radio.enableDynamicPayloads()radio.enableAckPayload()radio.openReadingPipe(0, pipes[1])radio.printDetails()radio.startListening()while(1): ackPL = [1] while not radio.available(0): time.sleep(1 / 100) receivedMessage = [] radio.read(receivedMessage, radio.getDynamicPayloadSize()) print("Received: {}".format(receivedMessage)) print("Translating the receivedMessage into unicode characters") string = "" for n in receivedMessage: # Decode into standard unicode set if (n >= 32 and n <= 126): string += chr(n) print(string) radio.writeAckPayload(1, ackPL, len(ackPL)) print("Loaded payload reply of {}".format(ackPL)) Multumesc mult pentru ajutor! Link spre comentariu
