Generator de secvente pentru jocuri de lumini
deejay2k1
http://goo.gl/TA6MHC
Un programete scris pentru cei care vor sa-si faca un joc de lumini cu Arduino.
capabilitati: 8 canale, 99 secvente(max)
interfata este simplista. cele 2 butoane "+sequence" si -sequence" adauga sau sterg secvente.
apasa bit-ul si se face verde. inca o data, se stinge.
PASTE si COPY permit aducerea in program sau copierea unui array (denumit myArray) care contine secventele, prin intermediul clipboard-ului din windows.
.ino genereaza in clipboard intreg sketch-ul Arduino (pentru lenesi sau ca punct de plecare, dupa dorinta).
Momentan este in beta, testat pe Win7 x32. Ar trebui sa mearga si pe restul fara nazuri.
Distractie placuta!
  • 2 săptămâni mai târziu...
  • Răspunsuri 3
  • deejay2k1
GUI version 1.2 released
Update ver 1.2: Added 8 modifiers for every sequence.
no modifier (----) just displays the sequence one (step) time
<--- move sequence to left in 8 steps
---> move sequence to right in 8 steps
<--< rotates sequence to left in 8 steps
>--> rotates sequence to right in 8 steps
invert inverts sequence in 8 steps
blink blink/strobe sequence in 8 steps (4 on, 4 off)
<-fill fills sequnce to the left with whatever value in bit b0 in 8 steps
fill-> fills sequnce to the right with whatever value in bit b7 in 8 steps
Mai am probleme cu paste-ul care trateaza tot ca fiind secvente, insa cam asta ar fi tot.
... tot pe naiba ... :limb:
Update ver 1.3: Added multiplier for every sequence (how many times it should repeat itself)
Update ver 1.4: Added new modifiers.
fill from middle (b4 and b3) outwards
fill from edges (b7 and b0) inwards
explode (shift from middle outwards)
implode (shift from edges inwards)
stack (sequence bits are not used, only the modifiers matters)
drip (same conditions as stack)
