nicnec Postat Octombrie 20, 2021 Partajează Postat Octombrie 20, 2021 (editat) Am o problema cu un nand de 4Gb cand dau read nu salveaza decat 540627 Kb si cu alt NAND de 4 G tot la fel se comporta . 142: Start reading chip...... 143: This operation has been cancelled! 144: Read error, operation aborted. 145: Please select chip partnumber. 146: Please select chip partnumber. 147: Chip pins contact is detected OK. 148: TotalPageNum: 0x100,PageNumInBlock: 64,PageSize: 0 149: Auto identified 2 ID is match with the partnumber. 150: Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box. 151: The currently selected:F59L4G81A@TSOP48, capacity: 4224Mbits, 528Mbytes. 152: Adapter model£ºRT-TSOP48-1, 0.5, 12*18, Pin to Pin 153: http://www.ifix.net.cn/thread-53859-1-2.html 154: Download device programming algorithm...... 155: Algo update OK 156: >------------------------------------OK---------------------------------------< Log Read 061: Chip pins contact is detected OK. 062: TotalPageNum: 0x40000,PageNumInBlock: 64,PageSize: 2112 063: Chip ID verification OK. 064: C:\Users\TELENYX\Documents\F59L4G81A@TSOP48_3633\F59L4G81A@TSOP48_3633 065: Start reading chip...... 066: Buffer data checksum: 16bits_0x0000 £¬32bits_0x00000000 : 067: Elapsed time: 70.94 seconds£¬average speed of 7804566 bytes/sec. 068: >------------------------------------OK---------------------------------------< Editat Octombrie 20, 2021 de nicnec Link spre comentariu
nek13 Postat Octombrie 22, 2021 Partajează Postat Octombrie 22, 2021 (editat) La 18.10.2021 la 11:05, Nykky1976 a spus: a aparut 20211012 update http://doc.ifix.net.cn/download/2017266 A reusit cineva sa descarce? eu mi am prins urechile): Editat Octombrie 22, 2021 de nek13 Link spre comentariu
GOLOGAN Postat Octombrie 22, 2021 Partajează Postat Octombrie 22, 2021 (editat) 1 oră în urmă, nek13 a spus: A reusit cineva sa descarce? eu mi am prins urechile): https://rddz2017.lanzoui.com/iu7V3v97mva Primul dreptunghi rosu din partea stanga. Editat Octombrie 22, 2021 de GOLOGAN Link spre comentariu
geoky Postat Octombrie 22, 2021 Partajează Postat Octombrie 22, 2021 Merge mai rapid cu Ordinary download, butonul rosu din dreapta. Link spre comentariu
GOLOGAN Postat Octombrie 22, 2021 Partajează Postat Octombrie 22, 2021 Acum 29 minute, geoky a spus: Merge mai rapid cu Ordinary download, butonul rosu din dreapta. Imi pare rau dar nu am ochelari de chineza la mine. Link spre comentariu
geoky Postat Octombrie 22, 2021 Partajează Postat Octombrie 22, 2021 (editat) Nici nu-ti trebue ochelarii, ca il ai pe Google translate ... Editat Octombrie 22, 2021 de geoky Link spre comentariu
nicnec Postat Octombrie 23, 2021 Partajează Postat Octombrie 23, 2021 Hai ca tot incercad mai multe nand cred ca am stricat programatorul nu mai recunoaste nici un nand. 001: https://www.facebook.com/profile.php?id=100034063062312 002: https://www.youtube.com/channel/UCzpAcvN9AlDhPu5Kk4iqGbw?view_as=subscriber 003: USB : 5.03V 004: Serial number:20180412093222-009023 ,PCB V1.80,Boot V1.00 005: >------------------------------------OK---------------------------------------< 006: Blank 007: Ö¸Áî·¢ËÍ´íÎó¡£·µ»Ø0xFA-0xAA-0xFA-0xEA-0xFA-0xAA¡£ 008: Ö¸Áî·¢ËÍ´íÎó¡£·µ»Ø0xFA-0x3-0xFA-0xCD-0xFA-0xCD¡£ 009: 010: Algorithm update error. 011: Authentication error. Link spre comentariu
Cosmin Marian Postat Octombrie 24, 2021 Partajează Postat Octombrie 24, 2021 Bună seara, încercați resetarea lui cu ajutorul butonul reset, numai bine Cosmin Link spre comentariu
nicnec Postat Octombrie 26, 2021 Partajează Postat Octombrie 26, 2021 La 24.10.2021 la 21:50, Cosmin Marian a spus: Bună seara, încercați resetarea lui cu ajutorul butonul reset, numai bine Cosmin Bun răspuns ! A mers cu reset după ce am scos o bucata de cositor din soclul nand. Dar cu cititul nand-ului mai puțin se pare ca programatorul nu știe și de alte partiții pe cip. Mulțumesc! Link spre comentariu
Cosmin Marian Postat Octombrie 26, 2021 Partajează Postat Octombrie 26, 2021 Acum 4 ore, nicnec a spus: Bun răspuns ! A mers cu reset după ce am scos o bucata de cositor din soclul nand. Dar cu cititul nand-ului mai puțin se pare ca programatorul nu știe și de alte partiții pe cip. Mulțumesc! Cu multă plăcere domnule, numai bine vă doresc. Cosmin. Link spre comentariu
traianx Postat Noiembrie 7, 2021 Partajează Postat Noiembrie 7, 2021 Postase cineva ca poate vorbi cu cei din china sa adauge suport pentru mai multe memorii. Programatorul meu este pe drum si as avea nevoie de compatibilitate pentru: MX29F1615PC-10 MX29L3211MC-10 Link spre comentariu
nek13 Postat Noiembrie 14, 2021 Partajează Postat Noiembrie 14, 2021 La 30.07.2020 la 13:30, Florinel TV a spus: Un nou Patch RT809H-20200725-Patch la care sa corectat urmatoarele Device care nu citea/scrie corect M29W512GH K9F1208U0C @ bga63 ID: EC765A3F74EC765A K9F2808U0C-YIBO TSOP48 SAMSUNG Sa adaugat GD5F1GQ4UBYIG = WSON-8 RT809H-20200725-Patch.rarIndisponibil Incearca cu noul Patch sa citesti nandul K9F1208U0C @ bga63 sa vezi cum il citeste Am pierdut de sub mana acest patch , va rog daca se poate un new upload... se multumeste! Link spre comentariu
zvasile Postat Noiembrie 15, 2021 Partajează Postat Noiembrie 15, 2021 incerc sa citesc un HY27US08281A si da o eruare, 042: Over current protect. 043: Command sending error. stie cineva care este problema? edit: rezolvat,la o verificare mai atenta am gasit 2 pini in scurt... Link spre comentariu
Costica Tv Postat Noiembrie 15, 2021 Partajează Postat Noiembrie 15, 2021 Acum 7 ore, zvasile a spus: incerc sa citesc un HY27US08281A si da o eruare, 042: Over current protect. 043: Command sending error. stie cineva care este problema? edit: rezolvat,la o verificare mai atenta am gasit 2 pini in scurt... Bine ca nu sa stricat programatorul !! Link spre comentariu
iuliantv Postat Decembrie 6, 2021 Partajează Postat Decembrie 6, 2021 La 08.11.2018 la 18:17, Rudi1982 a spus: RT809H are in lista Attiny13A dar nu-l stie ,la fel si RT809F , noroc ca am TL866 a mers din prima . Nu inteleg de ce este in lista daca nu-l stie.... pana la urma dv v-a mers attiny13a cu tl866,scris si citit? sau doar citit? in programator,nu in circuit Link spre comentariu
