RT809H
orgasmo
Da e normal , chipurile au viteza diferita de citire - scriere , si la mine face la fel .
Unele le scrie mai repede altele mai incet iar la unele imi da senzatia ca nu mai termina de sters .
O intrebare pentru cei care au RT809H, e normal inainte de rescrierea unui flash 25Q64 programatorul sa-l stearga(Auto erasing...) de 20 de ori, acea bara de progres se duce pina la capat si iar o ia de la inceput si tot asa de 20 de ori, am vazut ca flashul NAND il sterge instant.....oare asa e normal sau windows-ul imi creeaza mie probleme?, deci dureaza mai mult la stergere(20 secunde) decit la scriere(18 secunde)........Multumesc
Raspunsul este in modul de accesare ca aici:
The Serial Peripheral Interface bus (SPI) is a synchronous serial communication interface specification used for short distance communication, primarily in embedded systems. The interface was developed by Motorola in the late 1980s and has become a de facto standard. Typical applications include Secure Digital cards and liquid crystal displays.
SPI devices communicate in full duplex mode using a master-slave architecture with a single master. The master device originates the frame for reading and writing. Multiple slave devices are supported through selection with individual slave select (SS) lines.
Sometimes SPI is called a four-wire serial bus, contrasting with three-, two-, and one-wire serial buses. The SPI may be accurately described as a synchronous serial interface,[1] but it is different from the Synchronous Serial Interface (SSI) protocol, which is also a four-wire synchronous serial communication protocol. SSI Protocol employs differential signaling and provides only a single simplex communicationchannel.
Mai intervine si modul de stergere,parca stergerea-scrierea se poate face in mai multe moduri de adresare.
Ceva legat de sector,block sau page din ce-mi amintesc
Adica poti sterge sau scrie doar anumite portiuni de ex. sector sau block,page parca doar la nand dar posibil sa fie si la astea SPI.
Daca softul face stergerea sector cu sector sau block cu block atunci posibil sa dureze mai mult sterge o bucatica,verifica,trece la urmatoarea etc.
Totusi majoritatea cred ca au si o comanda de chip erase si atunci doar o verificare daca e blank mai este necesara.
Posibil ca respectiva comanda de chip erase sa nu fie folosita din motive de compatibilitate.Poate nu toate stiu de comanda respectiva,asa ca cel ce a facut softul a preferat o metoda mai lenta dar sigura,sector cu sector sau block cu block.
Ideal ar fi ca fiecare chip sa fie definit in baza de date a programului si programul sa stie ce posibilitati are chipul respectiv.
Da este normal
  • 2 săptămâni mai târziu...
A reusit cineva sa scrie un flash s29gl512N cu RT809H ? De 3 ore stau sa il scriu si nu merge sub nici o forma. Imi arata ca scrie si ajunge pana la 99% dupa care iar o ia de la 0. In mod normal ar trebui sa termine in 10 minute maxim. Nu este bga. Am incercat si terminatiile cu N P S la sfarsit dar face acelasi lucru. Driverul presupun ca e bine instalat deoarece flashuri tsop48 am reusit sa le programez fara probleme. Daca a reusit ceneva il rog sa ma ajute. MS!
Sa ma uit pe placile defecte poate gasesc acest nand flash si sa fac o proba ca sa vad daca la mine merge sau face la fel.......in ce este acest nand in tv sau laptop?
Vezi ce spune aici....cred ca a vrut sa spuna ca merge OK pe Windows XP......
#122
#133
Editat de Vizitator
#122
#133
este in receptor satelit. Acum am reinstalat driverul pe ul ult pc si acum imi da ca termina pana la 100% dupa care scrie write error.
PC-ul ce sistem de operare avea win 7 sau win xp?
Acum mi-am adus aminte acum vre-o doi ani cumparasem de pe ebay programatorul din imagine, imi dadea o eroare la scriere, am probat pe 3 pc-uri si 2 laptop-uri si degeaba....pina la urma am probat si pe un laptop dell mai vechi, pe acesta din urma a mers perfect fara eroare sau alte figuri......
Editat de Vizitator
Am windows 10 cu licenta. Pot incerca si pe un windows 7 dar nu cred ca se rezolva problerma
