Vizitator Postat Iulie 13, 2017 Partajează Postat Iulie 13, 2017 Trebuie instalat in Tools(L) la Tool chain Menu (P) un utilitar compatibil gen: http://extremeelectronics.co.in/avr-tutorials/gui-software-for-usbasp-based-usb-avr-programmers/ sau se poate programa ISP/JTAG fara adaptor folosind functia Setting(N) la Add ISP software(I) sau Add chip partnumber(A). Multumesc! Link spre comentariu
siti Postat August 3, 2017 Partajează Postat August 3, 2017 va salut, a reusit cineva sa programeze s29gl512 bga64?eu nu reusesc... Link spre comentariu
Sorin Schiriac Postat August 3, 2017 Partajează Postat August 3, 2017 numai cu tnm5000:http://www.filedropper.com/bga561totnm5000 Link spre comentariu
siti Postat August 3, 2017 Partajează Postat August 3, 2017 pai si RT809H il are in lista,ma gindesc ca nu e scris doar de forma....am adaptor bga64 de la RT809H. Link spre comentariu
Sorin Schiriac Postat August 3, 2017 Partajează Postat August 3, 2017 incearca sa citesti pe mufa isp:https://www.youtube.com/watch?v=9UWA9Zn1HOY Link spre comentariu
siti Postat August 3, 2017 Partajează Postat August 3, 2017 flash-ul e dat jos,vreau sa il programez asa,in circuit merge doar citit nu si scris. Link spre comentariu
orgasmo Postat August 3, 2017 Autor Partajează Postat August 3, 2017 (editat) S29GL512N: http://www.dataman.com/media/datasheet/Spansion/s29gl-n_00_a9_e.pdf Pag:3 Secured Silicon Sector region — 128-word/256-byte sector for permanent, secure identification through an 8-word/16-byte random Electronic Serial Number, accessible through a command sequence — May be programmed and locked at the factory or by the customer Pag:4 Password Sector Protection prevents unauthorized write and erase operations in any combination of sectors through a user-defined 64-bit password. Editat August 3, 2017 de orgasmo Link spre comentariu
dorofteius Postat August 3, 2017 Partajează Postat August 3, 2017 Daca reusesti vecine, anunta-ma, ca am si eu un navi Ford blaupunkt cu aceeasi poveste. Spor la treaba. Link spre comentariu
siti Postat August 3, 2017 Partajează Postat August 3, 2017 Daca reusesti vecine, anunta-ma, ca am si eu un navi Ford blaupunkt cu aceeasi poveste. Spor la treaba. @dorofteius ok,sigur! am incercat cu s29gl512N tsop56,din cateva incercari am reusit sa il programez,nu merge din prima....nu am inteles de ce,contactele la pini sunt ok..... S29gl512N bga64 nu vrea nicicum sa scrie/citeasca daca setez cu terminatia N,cand schimb terminatia din N in S imi apare ca e ok,arata ca scrie,sta 3 ore la scris iar cand il citesc imi arata chip empty. 1 Link spre comentariu
dorofteius Postat August 3, 2017 Partajează Postat August 3, 2017 Daca crezi ca te ajuta, ti-l dau si pe al meu cobai. Ca si asa aduna tzarana pe dulap. 1 Link spre comentariu
siti Postat August 3, 2017 Partajează Postat August 3, 2017 mai am ceva flash-uri,de proba,daca reusesc sa le programez il facem si pe ala. Link spre comentariu
r2005rom Postat August 4, 2017 Partajează Postat August 4, 2017 salut! pentru scriere nand512w3a2cn6 detin rt809f si doresc sa achizitionez adaptorul peb-1 , cu suportul adaptor pt acest nand: a reusit cineva in aceasta configuratie sa citeasca si scrie acest nand? in lista nand la rt809f nu este asta de la micron respectiv nand512w3a2cn6! multumesc! Link spre comentariu
siti Postat August 4, 2017 Partajează Postat August 4, 2017 Merge ca uns pe pc mai vechi +xp............ @dorofteius,spune-mi part nr de la ford,sa caut un dump ok si sa il programez! Link spre comentariu
dorofteius Postat August 4, 2017 Partajează Postat August 4, 2017 8M5T 18K931 GC C7E3A054488189131 7 612 360 544 Multumesc. Link spre comentariu
Florinel TV Postat August 5, 2017 Partajează Postat August 5, 2017 salut! pentru scriere nand512w3a2cn6 detin rt809f si doresc sa achizitionez adaptorul peb-1 , cu suportul adaptor pt acest nand: a reusit cineva in aceasta configuratie sa citeasca si scrie acest nand? in lista nand la rt809f nu este asta de la micron respectiv nand512w3a2cn6! multumesc! Cu RT809F nu merge scris , citit acest nand din pacate Link spre comentariu
