loleksibolek Postat Septembrie 11, 2016 Partajează Postat Septembrie 11, 2016 Daca cineva se pricepe la Html si CSS si poate sa ma ajute cu alinierea afisarii temperaturilor pe o pagina ...raman dator.Pagina arata acum asa: http://i63.tinypic.com/2gwdzr5.jpg http://i64.tinypic.com/2gskcj5.jpg As vrea ca temperaturile sa fie aranjate de la stanga la dreapta gen: Temp 1 Temp2 Temp 3 Temp 4 xxx*c xxx*c xxx*c xxx*c si daca se pot distanta si casutele de sus intre ele.Codul e pentru un arduino dar ma intereseaza doar partea de asezare in pagina .Sunt bata in domeniul asta si am tot incercat dar nu-mi iese asa ca nu criticati prea mult:)).Aici e codul: client.println(F("<!DOCTYPE HTML>")); client.println(F("<head>")); client.println(F("<title>Home Automation Control</title>")); client.println(F("<head>")); client.println(F("<style type='text/css'>")); client.println(F("p {word-spacing:30px;}")); client.println(F(".label {font-size: 30px; text-align:left;}")); client.println(F("button {width: 230px; height: 70px; font-size: 20px; -webkit-appearance: none; background-color:#00FFFF;} ")); client.println(F(".label1 {font-size: 30px; text-align:left;}")); client.println(F("button1 {width: 230px; height: 70px; font-size: 30px; -webkit-appearance: none; background-color:#FFFF00;} ")); client.println(F(".label2 {font-size: 30px; text-align:left;}")); client.println(F("button2 {width: 230px; height: 70px; font-size: 30px; -webkit-appearance: none; background-color:#FF99FF;} ")); client.println(F("h1 {color: red;width: 160px; height: 70px; font-size: 20px; }")); client.println(F("h2 {color: #660033 ;width: 160px; height: 70px; font-size: 20px; }")); client.println(F("h3 {color: #0033FF ;width: 300px; height: 150px; font-size: 45px; }")); client.println(F("</style>")); client.println(F("<script type='text/javascript'>")); client.println(F("function OnButtonClicked(parm) { window.location.href="X?" + parm; }")); client.println(F("</script>")); client.println(F("</head>")); client.println(F("<body style="background-color: #FDF5E6">")); client.println(F("<div class="label;label1;label2">")); // future idea: could read a limit switch on the garage door here and tell the user if the door is currently open or closed /* if (digitalRead(DOOR_OPEN_INPUT) == HIGH) client.println("Door is Open"); else client.println("Door is Closed"); client.println("<br>"); */ // door open / close button client.println(F("<body>")); client.println(F("<br/><br/><br/>")); if (digitalRead(5)==LOW) { client.println(F("<button onclick="OnButtonClicked('1');"><h2>OPRIT</button1></h2><br/><br/>")); } if (digitalRead(5)==HIGH){ client.println(F("<button onclick="OnButtonClicked('2');"><h1>PORNIT</h1></button2><br/><br/>")); } if (digitalRead(6)==LOW) { client.println(F("<button onclick="OnButtonClicked('3');"><h2>OPRIT</button1></h2><br/><br/><br/>")); } if (digitalRead(6)==HIGH){ client.println(F("<button onclick="OnButtonClicked('4');"><h1>PORNIT</button2></h1><br/><br/>")); } if (digitalRead(7)==LOW) { client.println(F("<button onclick="OnButtonClicked('5');"><h2>OPRIT</button1></h2><br><br/><br/>")); } if (digitalRead(7)==HIGH){ client.println(F("<button onclick="OnButtonClicked('6');"><h1>PORNIT</button2></h1><br><br/><br/>")); } if (digitalRead(8)==LOW) { client.println(F("<button onclick="OnButtonClicked('7');"><h2>OPRIT</button1></h2><br/><br/><br/>")); } if (digitalRead(8)==HIGH){ client.println(F("<button onclick="OnButtonClicked('8');"><h1>PORNIT</button2></h1><br/><br/>")); } client.println(F("</div>")); client.println(F("<div>")); client.println(F("<br/><br/>")); if (digitalRead(2)==LOW) { client.println(F("<button onclick="OnButtonClicked('1');"><h1>DESCHIS</h1></button1><br/><br/>")); }if (digitalRead(2)==HIGH){ client.println(F("<button onclick="OnButtonClicked('2');">INCHIS</button2><br/><br/>")); } if (digitalRead(3)==LOW) { client.println(F("<button onclick="OnButtonClicked('1');"><h1>DESCHIS</h1></button1><br/><br/>")); } if (digitalRead(3)==HIGH){ client.println(F("<button onclick="OnButtonClicked('2');">INCHIS</button2><br/><br/>")); } if (digitalRead(4)==LOW) { client.println(F("<button onclick="OnButtonClicked('1');"><h1>DESCHIS</h1></button1><br/><br/>")); } if (digitalRead(4)==HIGH){ client.println(F("<button onclick="OnButtonClicked('2');">INCHIS</button2><br/><br/>")); } if (digitalRead(4)==LOW) { client.println(F("<button onclick="OnButtonClicked('1');"><h1>DESCHIS</h1></button1><br/><br/>")); } if (digitalRead(4)==HIGH){ client.println(F("<button onclick="OnButtonClicked('2');">INCHIS</button2><br/><br/>")); } client.println(F("</div>")); client.println(F("<div>")); client.println(F("<br/><br/>")); Serial.println(); Serial.print("Requesting temperature..."); sensors.requestTemperatures(); // Send the command to get temperatures Serial.println("DONE"); client.println("<p>"); Serial.print("Device 1 (index 0) = "); Serial.print(sensors.getTempCByIndex(0)); client.println("<li>"); client.println("<h1>Temperatura sufragerie</h1>"); client.println("<h3>"); client.println(sensors.getTempCByIndex(0)); client.println("*C"); Serial.println(" Degrees C"); client.println("</h3>"); Serial.print("Device 1 (index 0) = "); Serial.print(sensors.getTempFByIndex(0)); Serial.println(" Degrees F"); Serial.print("Device 2 (index 1) = "); Serial.print(sensors.getTempCByIndex(1)); client.println("<li>"); client.println("<h1>Temperatura bucatarie</h1>"); client.println("<h3>"); client.println(sensors.getTempCByIndex(1)); client.println("*C"); client.println("</h3>"); Serial.println(" Degrees C"); Serial.print("Device 2 (index 1) = "); Serial.print(sensors.getTempFByIndex(1)); Serial.println(" Degrees F"); Serial.print("Device 3 (index 2) = "); Serial.print(sensors.getTempCByIndex(2)); client.println("<li>"); client.println("<h1>Temperatura dormitor</h1>"); client.println("<h3>"); client.println(sensors.getTempCByIndex(2)); client.println("*C"); client.println("</h3>"); Serial.println(" Degrees C"); Serial.print("Device 2 (index 1) = "); Serial.print(sensors.getTempFByIndex(2)); Serial.println(" Degrees F"); Serial.print("Device 4 (index 3) = "); Serial.print(sensors.getTempCByIndex(3)); client.println("<li>"); client.println("<h1>Temperatura exterior</h1>"); client.println("<h3>"); client.println(sensors.getTempCByIndex(3)); client.println("*C"); client.println("</h3>"); Serial.println(" Degrees C"); Serial.print("Device 2 (index 3) = "); Serial.print(sensors.getTempFByIndex(1)); Serial.println(" Degrees F"); client.println("</p>"); client.println(F("</div>")); client.println(F("</body>")); client.println(F("</html>")); } Multumesc. Link spre comentariu
belasajgo Postat Septembrie 12, 2016 Partajează Postat Septembrie 12, 2016 Pentru distanta dintre casutele de sus am folosit margin: 5px; sus la style. Pentru alinierea temperaturilor am folosit o tabela: <table> <tr> <th>Denumire 1</th> <th>Denumire 2</th> ... </tr> <tr> <td>Valoare 1</td> <td>Valoare 2</td> ... </tr> </table> La tabela se poate modifica grosimea si culoarea chenarului in caz ca este nevoie. Nu am testat codul, l-am editat in Notepad, deci poate contine greseli! client.println(F("<!DOCTYPE HTML>"));client.println(F("<head>"));client.println(F("<title>Home Automation Control</title>"));client.println(F("<head>"));client.println(F("<style type='text/css'>"));client.println(F("p {word-spacing:30px;}"));client.println(F(".label {font-size: 30px; text-align:left;}"));client.println(F("button {width: 230px; height: 70px; font-size: 20px; margin: 5px; -webkit-appearance: none; background-color:#00FFFF;} "));client.println(F(".label1 {font-size: 30px; text-align:left;}"));client.println(F("button1 {width: 230px; height: 70px; font-size: 30px; margin: 5px; -webkit-appearance: none; background-color:#FFFF00;} "));client.println(F(".label2 {font-size: 30px; text-align:left;}"));client.println(F("button2 {width: 230px; height: 70px; font-size: 30px; margin: 5px; -webkit-appearance: none; background-color:#FF99FF;} "));client.println(F("h1 {color: red;width: 160px; height: 70px; font-size: 20px; }"));client.println(F("h2 {color: #660033 ;width: 160px; height: 70px; font-size: 20px; }"));client.println(F("h3 {color: #0033FF ;width: 300px; height: 150px; font-size: 45px; }"));client.println(F("</style>"));client.println(F("<script type='text/javascript'>"));client.println(F("function OnButtonClicked(parm) { window.location.href="X?" + parm; }"));client.println(F("</script>"));client.println(F("</head>"));client.println(F("<body style="background-color: #FDF5E6">"));client.println(F("<div class="label;label1;label2">"));// future idea: could read a limit switch on the garage door here and tell the user if the door is currently open or closed/*if (digitalRead(DOOR_OPEN_INPUT) == HIGH)client.println("Door is Open"); else client.println("Door is Closed"); client.println("<br>");*/// door open / close buttonclient.println(F("<body>"));client.println(F("<br/><br/><br/>"));if (digitalRead(5)==LOW){client.println(F("<button onclick="OnButtonClicked('1');"><h2>OPRIT</h2></button1>"));}if (digitalRead(5)==HIGH){client.println(F("<button onclick="OnButtonClicked('2');"><h1>PORNIT</h1></button2>"));}if (digitalRead(6)==LOW){client.println(F("<button onclick="OnButtonClicked('3');"><h2>OPRIT</h2></button1>"));}if (digitalRead(6)==HIGH){client.println(F("<button onclick="OnButtonClicked('4');"><h1>PORNIT</h1></button2></h1>"));}if (digitalRead(7)==LOW){client.println(F("<button onclick="OnButtonClicked('5');"><h2>OPRIT</h2></button1>"));}if (digitalRead(7)==HIGH){client.println(F("<button onclick="OnButtonClicked('6');"><h1>PORNIT</h1></button2>"));}if (digitalRead(8)==LOW){client.println(F("<button onclick="OnButtonClicked('7');"><h2>OPRIT</h2></button1>"));}if (digitalRead(8)==HIGH){client.println(F("<button onclick="OnButtonClicked('8');"><h1>PORNIT</h1></button2>"));}client.println(F("</div>"));client.println(F("<div>"));client.println(F("<br/><br/>"));if (digitalRead(2)==LOW){client.println(F("<button onclick="OnButtonClicked('1');"><h1>DESCHIS</h1></button1>"));}if (digitalRead(2)==HIGH){client.println(F("<button onclick="OnButtonClicked('2');">INCHIS</button2>"));}if (digitalRead(3)==LOW){client.println(F("<button onclick="OnButtonClicked('1');"><h1>DESCHIS</h1></button1>"));}if (digitalRead(3)==HIGH){client.println(F("<button onclick="OnButtonClicked('2');">INCHIS</button2>"));}if (digitalRead(4)==LOW){client.println(F("<button onclick="OnButtonClicked('1');"><h1>DESCHIS</h1></button1>"));}if (digitalRead(4)==HIGH){client.println(F("<button onclick="OnButtonClicked('2');">INCHIS</button2>"));}if (digitalRead(4)==LOW){client.println(F("<button onclick="OnButtonClicked('1');"><h1>DESCHIS</h1></button1>"));}if (digitalRead(4)==HIGH){client.println(F("<button onclick="OnButtonClicked('2');">INCHIS</button2>"));}client.println(F("</div>"));client.println(F("<div>"));client.println(F("<br/><br/>"));client.println("<table>");client.println("<tr>");client.println("<th><h1>Temperatura sufragerie</h1></th>");client.println("<th><h1>Temperatura bucatarie</h1></th>");client.println("<th><h1>Temperatura dormitor</h1></th>");client.println("<th><h1>Temperatura exterior</h1></th>");client.println("</tr>");client.println("<tr>");Serial.println();Serial.print("Requesting temperature...");sensors.requestTemperatures(); // Send the command to get temperaturesSerial.println("DONE");Serial.print("Device 1 (index 0) = ");Serial.print(sensors.getTempCByIndex(0));client.println("<td>");client.println("<h3>");client.println(sensors.getTempCByIndex(0));client.println("*C");client.println("</h3>");client.println("</td>");Serial.println(" Degrees C");Serial.print("Device 1 (index 0) = ");Serial.print(sensors.getTempFByIndex(0));Serial.println(" Degrees F");Serial.print("Device 2 (index 1) = ");Serial.print(sensors.getTempCByIndex(1));client.println("<td>");client.println("<h3>");client.println(sensors.getTempCByIndex(1));client.println("*C");client.println("</h3>");client.println("</td>");Serial.println(" Degrees C");Serial.print("Device 2 (index 1) = ");Serial.print(sensors.getTempFByIndex(1));Serial.println(" Degrees F");Serial.print("Device 3 (index 2) = ");Serial.print(sensors.getTempCByIndex(2));client.println("<td>");client.println("<h3>");client.println(sensors.getTempCByIndex(2));client.println("*C");client.println("</h3>");client.println("</td>");Serial.println(" Degrees C");Serial.print("Device 2 (index 1) = ");Serial.print(sensors.getTempFByIndex(2));Serial.println(" Degrees F");Serial.print("Device 4 (index 3) = ");Serial.print(sensors.getTempCByIndex(3));client.println("<td>");client.println("<h3>");client.println(sensors.getTempCByIndex(3));client.println("*C");client.println("</h3>");client.println("</td>");Serial.println(" Degrees C");Serial.print("Device 2 (index 3) = ");Serial.print(sensors.getTempFByIndex(1));Serial.println(" Degrees F");client.println("</tr>");client.println("</table>");client.println(F("</div>")); client.println(F("</body>")); client.println(F("</html>")); } Link spre comentariu
loleksibolek Postat Septembrie 12, 2016 Autor Partajează Postat Septembrie 12, 2016 Multumesc mult,rezolvasem tot cu table.O sa incerc si cu ce-ai pus tu,e putin diferit si probabil mai corect decat ce-am facut eu,sa vad cum arata.Raman dator. Link spre comentariu
