Amplificator AudioBank putere
Tomsa Cosmin
Salutare colegi,am primit un ampl de masina audiobank formulaF43
Ca finali are 8 perechi TIP36-35c
Aveti idee ce putere are avea in punte? pe 2 canale
si daca este stabil in punte in 2 ohm
Nu prea gasesc detalii despre el
Stiu ca o putere exacta fara masuratori nu se poate da, dar ma refer minimul care ar scoate.
Editat de ratza
Mutat de la Amplificatoare
  • Răspunsuri 9
  • Tomsa Cosmin
    5
  • maryuss2011
  • Dj_Dog
  • mircea888
Zile populare
atat am gasit despre el pe GOOGLE
Audio Bank F434 channel amplifieron / off switching via remote, infinitely variable high and low pass filters, bass equalizer, adjustable input sensitivity, multiple protection circuits, soft start, low-level outputs, high level input, operating indicator (green LED) and overload indicator (red LED).Technical specifications:Output Power:4 x 100 watts RMS (4 Ohm) or4 x 135 Watts RMS (2 ohms) or4 x 150 watts RMS (1 ohm) or2 x 200 watts RMS (4 Ohm) or2 x 300 Watts RMS (2 ohms)Distortion: <0.02%Input sensitivity: 0.15 to 5.0 VInput impedance 47 ohmsNoise Ratio:> 100 dBDamping factor: 200 dBSpeaker Impedance: 1 - 4 OhmAll filter settings can be separately regulated for the center front and loudspeaker pairs.Low Pass Filter: 30 Hz - 500 Hz continuously variableHigh Pass Filter: 30 Hz - 500 Hz continuously variableSubsonic filter: 10 Hz - 100 Hz continuously variableBass Boost: 0-18dB infinitely variableDimensions (L x W x H): 350 x 252 x 55 mm
Poti estima puterea de iesire dupa tensiunea de alimentare a etajului final.
Probabil puterile alea declarate in specificatii sunt valori maxime (de varf) la un nivel mare de distorsiuni (10% probabil), e tehnica de marketing.
Nu sunt in Romania si nu am cu ce sa masor tensiunea,conzi de filtraj sunt la 35 de v
Salut,In principiu,cam marea majoritate a amplificatoarelor de genul acela au o alimentare de +-27v.Puterea debitata pe fiecare canal in parte ( nu in punte ) ar fi de aprox. 50w pe 4 ohmi,vreo 80 - 90w pe 2 ohmi ,iar in punte scoate cam 170-180w pe 4 ohmi.Trebuie avut in vedere ca in punte nu va rezista la sarcini mai mici de 4 ohmi.
Multumescc
