Transformatoare, radiatoare, difuzoare si alte componente/module recuperate
meshteru_the_best
Ultima lista valabila!
2 Carcasa amplificator Reloop ha-210b dimensiuni 425x330x62mm, pret 20 de lei!
https://postimg.org/image/mwov19tbr/
https://postimg.org/image/qb93f78ah/
https://postimg.org/image/43hmk72pv/
4 Unitate ibm defecta, dimensiuni 275x260x85mm pret 35 de lei sau 20 decat carcasa!
https://postimg.org/image/unsd7nk3t/
https://postimg.org/image/mqpmrj721/
https://postimg.org/image/kq2s55z2x/
https://postimg.org/image/f8q17lo95/
https://postimg.org/image/5zghnzpe1/
https://postimg.org/image/ok5gb6x5l/
https://postimg.org/image/q2ag64w0p/
https://postimg.org/image/q8ehmfb1r/
6 Transformator dintr un radio bucur dimensiuni ale tolelor 84x70x35 tensiuni in secundare 1x19v, 1x20.5v, 1x6.5v, 1x26.5v pret 25 de lei
https://s19.postimg....pv/bubur_01.jpg
https://s19.postimg....lr7/bucur02.jpg
https://s19.postimg....d9f/bucur03.jpg
https://s19.postimg....pyb/bucur04.jpg
7 Transformator, nu stiu din ce aparat provine, se pare ca cineva a incercat sa il desfaca dar este perfect functional. dim 85x68x44 tensiuni in secundare. albastru43v rosu15v portocaliu14v maro19v pret 15 lei
https://s19.postimg....2jjmr/image.jpg
https://s19.postimg....7kbvn/image.jpg
https://s19.postimg....0zdpf/image.jpg
Mai adaug:
9 Radiator in etajul final al magnetofonului saturn 202c-2 dim 204x80x44mm pret 5 lei
https://s19.postimg.org/pcl4nhzxf/saturn01.jpg
https://s19.postimg.org/yyep3sr37/saturn02.jpg
10 Radiator dintr un amplificator vega dim 240x84x50mm baza groasa de 2mm pret 10 lei
https://s19.postimg.org/jqypjfz8j/vega_01.jpg
https://s19.postimg.org/m9kek4kyr/vega02.jpg
https://s19.postimg.org/f7mgxxhcz/vega03.jpg
11 Difuzoare recuperate dintr un tv aristona, sunt pe 8 ohmi dimensiuni 205x82mm pret 15 lei
https://s19.postimg.org/dv9d9s9b7/16443594_1333215193419534_1298689188_n.jpg
https://s19.postimg.org/n4bjjwi77/16426710_1333215230086197_436346604_n.jpg
12 Tweetere nu stiu din ce boxe provin dim 70x70mm pret 7 lei ambele
https://s19.postimg.org/ldsiif0o3/tw01.jpg
https://s19.postimg.org/qqhcwjokj/tw02.jpg
As dori tweeterele de la pct 12
Salut. imi pare rau dar tweeterele vor ajunge la domnul GMCD. dansul a trimis primul pm. daca dansul le cedeaza sunt ale dumneavoastra!
Editat de meshteru_the_best
Punctele 5.7.8.9.11.12 au fost vandute.
Mai adaug:
13 Parte amplificare dintr un sistem 5.1 watson defect, lipsa soclul sigurantei fuzibile, un tranzistor si un mic radiator. se da cu tot cu telecomanda pret 10 lei
https://s19.postimg.org/aty7ajw2r/watson01.jpg
https://s19.postimg.org/r6890aaeb/watson02.jpg
https://s19.postimg.org/5l36codnn/watson03.jpg
https://s19.postimg.org/5z4ic9xr7/watson04.jpg
14 Doua surse hp de 365w ambele erau functionale cand le am folosit ultima data, acum le am probat alimentandule si unind firul verge cu unul negru. sunt putin mai mari ca dimensiuni decat o sursa normala atx dar cu putina dexteritate se pot monta si astea. pret 30 de lei bucata sau 50 ambele.
https://s19.postimg.org/irsmc79cz/16558541_1338953656179021_1773386635_n.jpg
https://s19.postimg.org/6rbrp7rc3/16558657_1338974989510221_67923493_n.jpg
https://s19.postimg.org/99xgpwd2b/16507086_1338975002843553_542093321_n.jpg
https://s19.postimg.org/r1934csgz/16521892_1338953676179019_1257199022_n.jpg
Ultima lista valabila:
https://s19.postimg....z8j/vega_01.jpg
https://s19.postimg....4kyr/vega02.jpg
https://s19.postimg....xhcz/vega03.jpg
https://s19.postimg....2r/watson01.jpg
https://s19.postimg....eb/watson02.jpg
https://s19.postimg....nn/watson03.jpg
https://s19.postimg....r7/watson04.jpg
https://s19.postimg....773386635_n.jpg
https://s19.postimg...._67923493_n.jpg
https://s19.postimg....542093321_n.jpg
https://s19.postimg....257199022_n.jpg
  • 2 săptămâni mai târziu...
  • 2 luni mai târziu...
Se adauga:
15 Transformator toroidal 500w fabricat de petra. diametru aprox 135x55mm primar 220v 50hz secundar 65v, sarma din secundar are diametrul aprox 1.5-1.7mm nu am cu ce sa masor. se da cu tot cu carcasa. am si capacul pret 125 de lei
https://s19.postimg.org/it2u2ue5f/petra_01.jpg
https://s19.postimg.org/nt0aasjs3/petra_02.jpg
https://s19.postimg.org/i63xdbh9f/petra_03.jpg
16 Transformator toroidal 500w diametru aprox 142x55mm primar 230v 50-60hz secundarul era la 12v bobinat cu 4 sarme in paralel, sarmele au fost desfacute si inseriate si au diam aprox 1.7-2mm pret 100 de lei
https://s19.postimg.org/5u10ztter/image.jpg
https://s19.postimg.org/jc7xc45k3/image.jpg
https://s19.postimg.org/4hjbxxvz7/image.jpg
