Transformator MIVAR
  • Răspunsuri 27
Dupa schema  sasiului  pare  ca-ti  trebuie  2 tensiuni   >>  B+  105  volti  si auxiliar 13  volti !!
Aha acum am inteles  , nu te complica cu sursa asta , spune la ce vrei sa alimentezi 30v . cati amperi si vei fi ajutat !!
Editat de dan-a2
alimentatorul ar trebui sa fie acesta :
<script data-pagespeed-no-defer type="text/javascript">(function(){var g=this;function h(b,d){var a=b.split("."),c=g;a[0]in c||!c.execScript||c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)a.length||void 0===d?c[e]?c=c[e]:c=c[e]={}:c[e]=d};function l(b){var d=b.length;if(0=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.g.height&&c<=b.g.width)}a&&(b.a.push(e),b.c[e]=!0)}p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});function r(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.i&&(e="&rd="+encodeURIComponent(JSON.stringify(t())),131072>=a.length+e.length&&(a+=e),d=!0);u=a;if(d){c=b.h;b=b.j;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(v){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}}function t(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("data-pagespeed-url-hash");e&&(!(e in b)&&0=b[e].o&&a.height>=b[e].m)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b}var u="";h("pagespeed.CriticalImages.getBeaconData",function(){return u});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/ngx_pagespeed_beacon','http://www.elforum.info/index.php?app=forums&module=ajax§ion=topics&do=quote&t=116457&p=1387372&md5check=ef4ee12f61efe0260bbf9609012c2179&isRte=1,xDD6_yBh4z,true,false,cUydhkS_cpk');</script>Posted Image&&0){for(var>
Eu am intrebat cum trebue sa fac transformatorul (daca ma puteti ajuta) daca nu o sa incerc si singur.
va trebui sa rebobinezi un choper,daca tii mortis sa fie un alimentator in comutatie,nu ai spus cati amperi vrei sa obtii.
 Mai bine ceri pe la colegii de forum care se ocupă cu depanarea o sursă originală recuperată., nu ai nicio șansă să faci singur traful chopper, mai ales dacă nu ai datele de bobinaj.Apoi, unele trafuri  au și un întrefier foarte critic, nu mai zic de permeabilitatea miezului original pe care nu ai de unde s-o știi.
 Trafo e HR9845,si se gaseste de cumparat.Mare branza  :95 ...
   Uite ca ti-am gasit datele de bobinaj,la pag 22 si mai incolo:https://www.google.ro/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjjgYGN0KDNAhUEXBoKHTzXApcQFggdMAA&url=http%3A%2F%2Fwww.alphacron.de%2Fdownload%2Fhardware%2FTEA2261.pdf&usg=AFQjCNGDXR68amdolHlTa1YlaM5RnZ8Krg&sig2=Ey0UZ0yutuj-5TsRHiTYSQ  .Spor la bobinat !
Editat de Andrei Tabacaru
