Topicul meu de cumparaturi.
FLORIN IORDACHE
La 18.10.2019 la 15:45, FLORIN IORDACHE a spus:
Buna ziua,
As avea si eu nevoie de urmatoarele :
O placa mainboard pentru un, Tv Philips model - 32PF7521D/10 , chassis - LC4.31E AB , display - LC320W01(SL) (06). Pe placa scrie -  3139 123 6117.3 WK551.3 .
72779218_489142751671482_721863176437628928_n.png?_nc_cat=101&_nc_oc=AQkWD-UsqXU_hOYVy85DzN_YpUQSpJsedSqE3h3CmOlAcpT4GNy6Xln2bfrTTRKRORY&_nc_ht=scontent.fsbz1-2.fna&oh=5f687479122e4cfc282d2ef7d8ddd3b7&oe=5E2DAA51
72310696_1278253192334963_123136209865146368_n.png?_nc_cat=108&_nc_oc=AQlG_HkRaIL4SwkOaXmaFOFyrTQOJ75qCfIaNLkr-AhHbOKl7MKPhEUAF5sJRbUX5ic&_nc_ht=scontent.fsbz1-2.fna&oh=e53ab32b6c49ef7f953e96880b5c13ad&oe=5E2D7239
72810601_3000349913332956_7014715581974708224_n.png?_nc_cat=111&_nc_oc=AQm98P5piv_Jsdu1eheu8932PEXmZ852-jiRSIXJV6ziokt40X9yZdP1krhRft-1ols&_nc_ht=scontent.fsbz1-1.fna&oh=f6380841b1a770f1149c874a55596952&oe=5E25C979
72478192_2531367216984513_2947303504517005312_n.png?_nc_cat=111&_nc_oc=AQmhKwfvVpeTAZ5H9l1EFi-AmD4FRCJy-uvUOxtGQrXn8P43139vBsiWYt3IZ2_Ox1U&_nc_ht=scontent.fsbz1-1.fna&oh=286d4ddc541999d20194e1beb9ddceb0&oe=5E5C1824
O placa de baza pentru un laptop HP Pavilion DV6700 .
Procesorul este un Intel core duo, iar placa video este Nvidia
74369947_2408219242830124_6085840135830634496_n.png?_nc_cat=110&_nc_oc=AQl3h8fOTN30T1Z3oxYMlvLzb0wiaglszGwU3qODcJqzjKf23xtFEvzfpd1pDjCo1GE&_nc_ht=scontent.fsbz1-1.fna&oh=33c18f64d7f085a1e91e1d6a358f888a&oe=5E1C6685
Astept un raspuns de la dvs !
Va multumesc !
UP, UP !
Buna ziua,
Haideti sa va arat diferentele care sant intre placa domnului,iuliantv.
Uitati aceasta este placa dansului :74239296_2451530818394462_1124809590739828736_n.png?_nc_cat=103&_nc_oc=AQlebUQnshS62_wwXIHMQYGKa9jTQORcPnCBfO4qNUi3MH5EnCo36mMyVp5_hwCqzIM&_nc_ht=scontent.fsbz1-2.fna&oh=daf4c0c7a21196d60982bfa3d0123ce6&oe=5E55887A
Iar aceasta este placa mea din tv :
73333335_1278253189001630_2026964477672423424_n.png?_nc_cat=102&_nc_oc=AQlSZtwEy0dIdokiW4aOJgvK83oUG2V_eCNqis7MWgBs5DYhrWaBRFdT3w8cmKw3_y8&_nc_ht=scontent.fsbz1-1.fna&oh=adef8d223771ab8f68c608063ccb3084&oe=5E61BCDC
Asa ca eu cred ca difera si la display si s-ar putea sa difera si pe la t-con...asa cum v-am mai spus si undeva mai sus...
Asa ca caut in contiunare aceasta placa....dar atetie, sa fie identica cu a mea,iar  daca se poate sa fie si pentru acelasi display : LC320W01(SL) (06).
Asa ca astept in contiunuare vesti de la cine are aceasta placa....pentru acest tv Philips model - 32PF7521D/10 , chassis - LC4.31E AB .
Astept ! Multumesc !
Editat de FLORIN IORDACHE
Buna ziua,
Am uitat sa va spun ca ramane in continuare valabil si anuntul de mai jos.... :
Va multumesc !
Up,Up .
Buna seara ,
Va anunt ca raman in continuare valabile ultimile mele anunturi ale mele  de aici......adica placa pentru tv-u : Philips si cu placa de baza pentru laptop-ul Hp .
Va multumesc ! Astept in continuare !
La 27.10.2019 la 15:28, FLORIN IORDACHE a spus:
Buna ziua,
chior nu sant si stiu ca sant diferente,dar daca eu as fi asteptat sa gasesc exact ceea ce caut si nu ceva cat de cat apropiat,atunci ma lasam de meserie,succes in cautari eu mai am placi dar imi este greu sa le caut,asa ca doar sa dau peste ele cautand altceva si zic uite ca aveam totusi ce cautam,asa e cand ai prea multe,ganditi-va ca dimineata am postat un topic cu chassie crt cu cca 30buc,am estimat eu,urmand ca sa fac ceva poze cat de cat ,si la o numaratoare in mare am numarat cel putin 90buc,si sigur mai gasesc inca vreo 10-20buc daca caut peste tot,deci va dati seama cat de greu i-mi este si timpul liber limitat
Acum 22 ore, iuliantv a spus:
Salut !
Pai atunci ramane sa mai cautati dvs pe acolo...iar daca gasiti cea ce imi trebuie mie,atunci va rog ca sa ma contactati ! :reytre
Va multumesc ! Astept !
Buna ziua,
Va multumesc !
Up,up ... !
Astept vesti de la dvs !
La 17.11.2019 la 12:44, FLORIN IORDACHE a spus:
Up,up ... !
Valabil in continuare !
Are care-va vreun integrat MP3398A ??
Acum 4 ore, Toni Marginean a spus:
Salut! Am eu placa de care aveti nevoie.
Salut !
Placa este : 17ips62 , dar cu acest integrat : MP3398A / si nu cu MP3394 .:reytre
Dar o schema pentru aceasta sursa : 17ips62 /  cu acest integrat : MP3398A , nu aveti?
Da oricum sa-mi spuneti si un pret pentru placa dvs pe care o aveti .
Astept !
