Reset sau test Whirlpool cu F14
ipotexas
Stie cineva cum se porneste programul de test la o masina de spalat Whirlpool AWO/D6100 ?
Eroarea este legata de o fluctuatie a alimentarii cu energie electrica. Am gasit un condensator umflat si l/am inlocuit. Ati mai intalnit?
  • Răspunsuri 1
  • nelutuPO
  • ipotexas
Zile populare
How to Enter Test Mode Sequence
To enter the diagnostic/test mode sequence, you need to turn the dial to the DRAIN position, which is at eleven o´clock; then you must press the RESET button four times, within five seconds to enter the test mode sequence. (See video on this)
NOTE: this doesn´t always go in first time, so as soon as you turn the dial from the OFF position to theDRAIN position, you have 5 seconds to press the RESET button 4 times.
Once the machine as entered the test mode sequence you will see a series of flashing lights:
1 - The machine starts by checking if the door lock is working correctly;
2 - Then goes to a fill sequence where it will test each water valve individually – it will start filling the right hand compartment in the soap drawer, then switches over to the other water valve on the left hand compartment, after this, both water valves will be activated (fills all three compartments, including the fabric conditioner in the middle);
3 - Next it will test right hand rotation of the motor (clockwise), and left hand rotation of the motor (anticlockwise), while it´s also testing the NTC sensor and the heater element;
4 - The machine goes into empty cycle;
5 -Full test on the motor at maximum RPM
 To Exit Test Mode
 The machine will automatically exit the diagnostic/test mode sequence
After the test sequence if you find that you do need a part for your washing machine, you will need the full model number of the ID Plate, which you can normally find on the inside of the door frame or in the rear of the machine.
Sometimes you will need the 12 digit number, which is usually prefixed with 12NC in front of it, on some parts you will need both of these numbers, it might not be listed on the website because it is serial number dependent. (see picture on the left) . Succes !
