Vizitator El3ctro_Tea Postat Martie 30, 2007 Partajează Postat Martie 30, 2007 Salutare,am un sony xplode XS-LD125P5 ,parametrii sunt de pe net ,vreau sa stiu cati litrii trebuie sa aiba incinta si daca este inchisa sau bass reflex,ms. * Speaker Size (cm): 30 * Speaker Size (inch): 12 * Peak Power (W): 1400 * Rated Power (RMS, W): 400 * Impedance (ohms): 4 + 4 * Sensitivity (dB/W/m): 89 * Frequency Response (Hz): 18-2.5k * Mass (kg): 5.9 * Mass (lb/oz): 13/8 * d (mm): 250 * d (inch): 9.8 * Rdc (VC in Parallel, ohms): 1.7 * Rdc (VC in Series, ohms): 6.8 * Fs (VC in Parallel, Hz): 20.3 * Fs (VC in Series, Hz): 20.6 * Qts (VC in Parallel): 0.34 * Qts (VC in Series): 0.35 * Qes (VC in Parallel): 0.35 * Qes (VC in Series): 0.36 * Qms (VC in Parallel): 8.7 * Qms (VC in Series): 9.21 * Vas (VC in Parallel, Lit.): 79.7 * Vas (VC in Series, Lit.): 78.1 * Vas (VC in Parallel, Cu. ft.): 2.81 * Vas (VC in Series, Cu. ft.): 2.76 * Mms (VC in Parallel, g): 263.9 * Mms (VC in Series, g): 262.1 * Lvc (VC in Parallel, mH): 0.6 * Lvc (VC in Series, mH): 2.6 * Xmax (mm): 10 * Xmax (inch): 0.4 * BL (VC in Parallel, Tm): 12.6 * BL (VC in Series, Tm): 24.8 Link spre comentariu
Vizitator donpetru Postat Aprilie 1, 2007 Partajează Postat Aprilie 1, 2007 Iti recomand o incinta tip Bass reflex cu un volum de circa 65 - 70 litri. Link spre comentariu
Vizitator El3ctro_Tea Postat Aprilie 1, 2007 Partajează Postat Aprilie 1, 2007 ok , m-am gandit la un cub cu latura de 45 cm ,volum interior in jur de 68l,cu un singur port bass reflex in spate, cam ce dimensiuni ar trebui sa aiba portul? ,ar fii valabila incinta? ms. :smt001 Link spre comentariu
Vizitator donpetru Postat Aprilie 1, 2007 Partajează Postat Aprilie 1, 2007 NU iti recomand sa faci un cub Construieste o prisma paralipipedica cu urmatoarele dimensiuni (aprox.): 48X42x42 cm iar difuzorul sa-l plasezi nu in centrul axelor de simetrie de pe o fata a prismei ci putin deviat fata de origine cu vreo 4cm. Portul pt incinta bas reflex trebuie sa aiba sectiunea de circa 25% din aria membranei difuzorului, iar lungimea in jur de o treime din adancimea boxei. Inca un sfat util: dupa ce ai decupat rotundul unde plasezi difuzorul prinde-l inauntru chiar in dreptul pozitionarii difuzorului urmand ca dupa aceea sa plasezi material fonoabsorbant din jurul in prejurul lui. Astfel se mareste presiunea acustica, adica SPL-ul cu circa (1,5-1,8)dB/W/m, iar puterea acustica radiata de incinta cu circa 0,048W. Link spre comentariu
Vizitator El3ctro_Tea Postat Aprilie 1, 2007 Partajează Postat Aprilie 1, 2007 atunci va fii 48X42x42 asa ,cu difuzorul pus mai sus nu pe centru , da cum fac cu bass reflex ,unde sa pun, 1 port sau 2 ? Link spre comentariu
Vizitator donpetru Postat Aprilie 1, 2007 Partajează Postat Aprilie 1, 2007 Iti recomand doua porturi de sectiuni mai mici decat unul de sectiune mai mare. Un port se utilizeaza de obicei la difuzoare cu diametre pana in 25cm. Bineinteles, asta nu e o regula. Link spre comentariu
Vizitator El3ctro_Tea Postat Aprilie 1, 2007 Partajează Postat Aprilie 1, 2007 O sa pun 2 porturi pe partea frontala sub difuzor,ms pt ajutor ,o sa revin cu poze :smt006 Link spre comentariu
Sharky Postat Aprilie 1, 2007 Partajează Postat Aprilie 1, 2007 daca il folosesti numai ca subwoofer poti sa il faci cub, dar tare ma indoiesc ca va fi solutia cea mai buna.Daca il facipt masina vezi sa iti ocupe cat mai putin loc in portbagaj. Link spre comentariu
Vizitator El3ctro_Tea Postat Aprilie 1, 2007 Partajează Postat Aprilie 1, 2007 nu e pentru masina ,nu o sa il fac cub,am ales solutia mai buna din cate am inteles :yawinkle: Link spre comentariu
