Vreau si eu un volumpt QS10P20
Vizitator cosmin1985
Ma poate sfatui cineva cum sa construiesc o incinta in forma de cub pentru difuzor Selenium QS10P20
parametri difuzorului:
Power handling: 125 watts RMS/250 watts max
*VC dia: 1-3/4"
*Nominal impedance: 8 ohms
*Re: 5.7 ohms
*Frequency response: 50- 6,000 Hz (-10dB)
*Fs: 65 Hz
*SPL: 92 dB 1W/1m
*Vas: 1.20 cu. ft.
*Qms: 5.98
*Qes: .82 *Qts: .72
*Xmax: 2 mm
*Net weight: 6.70 lbs.
*Dimensions:
Overall Diameter: 10", Cutout Diameter: 9", Mounting Depth: 4-7/16".
Resin impregnated paper cone for durability
Specially treated cloth surround
High sensitivity and power handling
High power Kapton voice coils
Extended vented pole piece for improved sensitivity and power handling
  • Răspunsuri 0
Zile populare
