Amplificator P3A - Rod Elliott. Sugestii modificari pentru un sunet cald.
Vizitator Cristian Barbu
Niste impresii de la alti constructori:
Ok, I still am in shock. I put on my test speakers to have a listen. Emi Fujita - The Rose brought tears to my eyes. Jeez! The realism of the guitar, the dynamic range of the vocals is stunning.omg !!
I just couldn't wait as usual, and I was more confident than usual of this amp's performance, as well as my soldering skills. This amp blows my mind. Hooked up to my 94dB speakers, my jaw dropped and I was in a state of shock. Smooth is the word. Super deep soundstage, though not as wide. Vocals sound extremely natural and open. The most open sound I have heard. The top end beat all my other amps. Rich and detailed, not tizzy and transistor-like. Detail retrieval is insane, instrument layering is the finest. I don't know where the bass comes from, but my guts feel it !!
Citatele sunt de aici: http://diyaudioprojects.com/Forum/viewtopic.php?f=10&t=2680
  • Răspunsuri 128
  • Marian
    18
  • hpavictor
    16
  • sk24bpo
    10
  • Haralambie
    9
Cred ca cel mai bine este sa prezinti aici textolitul si schema de traseu, daca l-ai facut tu ca nu se mentioneza asta.
Condensatorul C6 mai bine sa fie cu mica. Toleranta mica si stabile in raport cu temperatura.
Editat de Predator
Puteți oferi câteva detalii despre decuplarea sursei de alimentare ?Majoritatea problemelor semnalate de Dvoastra își au originea uneori în sursa de alimentare sau într-o cablare defectuoasă .
Eu as spune ca decuplarea nu e factorul deciziv, daca restul circuitului de amplificare este gandit pt raport de rejectie (PSSR) mare.
Editat de Predator
Am pus in simulator schema asta pentru a lamuri sau inlatura unele dubii:
Posted Image
THD1:
Posted Image
Asa cum am estimat anterior, pentru 100W la castigul din schema ar fi necesar cam 0,9Vrms, adica stiam ce spun atunci cand am zis ca amplificare de 23x este suficienta.
THD10:
Posted Image
THD20:
Posted Image
Cam mult dar n-ai ce sa-i faci, asta e limita schemei.
Dreptunghi:
Posted Image
SR:
Posted Image
Undeva pe la 10V/uS.
Limita inferioara a benzii audio ( -3db ):
Posted Image
Si aici se confirma ce am zis anterior, 4,7uF pe intrare si 100u in reactie, este suficient.
Limita superioara este de-a dreptul SF pentru simplitatea schemei:
Posted Image
Atasez poze cu amplficatorul si cablajul ( cablajul este facut de un baiat de pe Tehnium forum care si-a construit si el unul si avea cateva ramase si este facut de o firma profesionista ). De asemenea, atasez poza cu sursa de alimentare in varianta actuala de test.
Posted Image
Posted Image
Posted Image
Va rog sa imi spuneti daca observati ceva probleme in aceste poze. Va multumesc mult pentru ajutorul de pana acum
Victor sursa de alimentare consta intr-un traf -> punte redresoare -> 2x4700uF pe fiecare rail -> amplificator. Nu am condensator de decuplare, si nici nu inteleg exact conceptul in zona respectiva, ai avea 1 minut sa imi explici ? Singurul de cuplaj este C1 din schema ( cel mare si verde ) momentan, dar este pentru input
Editat de Cristian Barbu
Firma este profesionista, adica cu asta se ocupa.. Cablajul va las pe voi sa decideti eu nu am suficienta experienta, am facut doar 3 amplificatoare pana acum
Sunt lipiti pe deasupra, de aceea se vede asa de sub, si am continuitate OK, am verificat acum. Pentru decuplajul sursei de alimentare trebuia sa mai pun un condensator de valoare mica intre ramuri, inainte de amplificator ?
Daca un amplificator de audiofrecventa are performante peste nivelul surselor de semnal(excludem incintele..)atunci el va permite utilizatorului sa faca distinctie intre sursele de semnal(cd-player,calculator pick-up,etc) care vor "suna" diferit.
Daca amplificatorul este sub sursele de semnal d.p.d.v. calitativ,si e "imbogatit  cu armonici audiofile",pare , atunci distinctia se va face mai greu.
Amplificatoarele simetrice reduc din principiu anumite armonici si suna de multe ori mai curat,cristalin,cu biasul reglat corect;(vezi primele variante Leach,Ottala) ;unele firme introduc voit unele asimetrii pentru a face sunetul mai placut.
Totul depinde de gustul,nivelul de pregatire,experienta utilizatorului.
De departe cablarea si sursa de alimentare sunt... cum nu ar trebui.  In rest montajul este destul de compact, nu l-as invinovati.  Amplificatoarele audiofile de generatie mai noua nu mai pun accentul pe distorsiuni mici, ci pe anumite paternuri ale acestora. Amplificatoarele audiofile la ora actuala se judeca si se platesc dupa ureche.  Am avut eu insumi un experiment esuat in care distorsiunile extrem de mici au pus la pamant un amplificator care se si auzea excelent. Daca faci prostia sa declari ca un aparat are distorsiuni mici esec va scrie pe fruntea lui. Distorsiunile mici in lumea audiofila sunt stampila care te ajuta sa iti iei bye-bye. Hipstereala e maxima , la moda sunt lampile si pick-up-urile care suna "natural".
Eu am il am facut in 6 bucati si alimentate fiecare cu +-28V- 250W cate 3 bucati in parallel, din 2 trafuri diferite. Mie personal imi suna bine, is chiar foarte multumit !!!! Singura chestie este ca eu il folosesc cu filtre active 5.1 si e chiar superb. Asta este doar parerea mea....dar nu-s foarte pretentios.
Nu am pretentii mari si sunt toate cel 6 module facute cu, component OK, nu cele mai "petarde" dar cu siguranta nu sunt cele mai bune....pot spune mediocre.
Din cele citite mai sus, am impresia ca se doreste ceva mai mult decat poate acest amplificator.
Poti incerca cu un traf mai puternic, poate nu are sufficient "juice"....desi ma indoiesc ca asta e problema!!!
