Schema invertor tm5-015i-1p
Buna ziua. As avea nevoie de schema Invertorului Type TM5-015i-1P P/N : 48691-103 Imput 1 phase , 110~115v , 50/60hz , Output 3phase , 6A/9A , 0-150hz .Am tot cautat pe net dar in zadar. Invertorul este de la o banda de alergare Precor 966i. Problema este ca la apasarea butonului quick start de pe panou afiseaza error 29. Precor Error 29, Excessive AC Input CurrentProbable Cause1. The running belt and/or deck are badly worn.2. Bad lower PCA.3. Drive motor is shorted or de-magnetized causing a high power demand.Corrective ActionCheck the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.Test unit with a known good lower PCA. Replace lower PCA if necessary.Test unit with a known good drive motor. Replace drive motor if necessary.Banuiesc invertorul. Orice informatie e binevenita. Multumesc anticipat.
  • Răspunsuri 2
  • gabypyly
  • leoncris
Zile populare
