Black Death Postat Ianuarie 26, 2016 Partajează Postat Ianuarie 26, 2016 (editat) Buna seara,am gasit o schema de amp PP schema:http://www.jogis-roehrenbude.de/Leserbriefe/Uli-Graf-EL34-Amp/audioamp-verst.jpg dispun de:2xEL34 2xECC83 1xEF86 6x250v/A,B,C,D.F.L fiecare de 20Uf 1xTraf iesire 1xTraf alimentare 230V-400v/40v/6v/6v https://static.md/08e76c4a99db6eb417cecbaf5a41b254.jpeg https://static.md/f54e91f59bf81e76c479fff45e421b5a.jpeg https://static.md/27275831cac91634eca2a660955bb409.jpeg https://static.md/23d9fe4c44a54aea8ab9074bbc5da9c2.jpeg https://static.md/8b1c70e51d38d2ce2a49af45acdf9540.jpeg https://static.md/f82902a8fc9ac591c205a268a1355409.jpeg https://static.md/29b6862525edbab10f613a8c0d5d7b7a.jpeg https://static.md/1289c9539fac2856dafde19e86fccddc.jpeg intrebarea mea este: se merita sa il fac? e buna schema? aveti ceva idei de modificare? Editat Ianuarie 26, 2016 de Black Death Link spre comentariu
Vizitator viobio Postat Ianuarie 26, 2016 Partajează Postat Ianuarie 26, 2016 Buna seara,am gasit o schema de amp PPschema:http://www.jogis-roehrenbude.de/Leserbriefe/Uli-Graf-EL34-Amp/audioamp-verst.jpgdispun de:2xEL34 2xECC83 1xEF86 1xTraf iesire 1xTraf alimentare 230V-400v/40v/6v/6vhttps://static.md/08e76c4a99db6eb417cecbaf5a41b254.jpeghttps://static.md/f54e91f59bf81e76c479fff45e421b5a.jpeghttps://static.md/27275831cac91634eca2a660955bb409.jpeghttps://static.md/23d9fe4c44a54aea8ab9074bbc5da9c2.jpeghttps://static.md/8b1c70e51d38d2ce2a49af45acdf9540.jpeghttps://static.md/f82902a8fc9ac591c205a268a1355409.jpeghttps://static.md/29b6862525edbab10f613a8c0d5d7b7a.jpeghttps://static.md/1289c9539fac2856dafde19e86fccddc.jpegintrebarea mea este:se merita sa il fac? Dae buna schema? Daaveti ceva idei de modificare? De ce sa modifici? Ce sa modifici?Dupa intrebarile puse bag de seama ca este primul amp cu tuburi.Ce sectiune au trafurile de iesire sau de unde provin. Link spre comentariu
Black Death Postat Ianuarie 26, 2016 Autor Partajează Postat Ianuarie 26, 2016 Intrebam doar! Nu,este al doilea ,se pune daca primul l-am facut cu pcl86? A fost o statie celta, si lipseau ceva piese din ea. Schema am gasit dar nu prea inteleg ce e acolo asa ca,m-am gandit sa fac alta Link spre comentariu
Vizitator viobio Postat Ianuarie 26, 2016 Partajează Postat Ianuarie 26, 2016 Intrebam doar!Nu,este al doilea ,se pune daca primul l-am facut cu pcl86?A fost o statie celta, si lipseau ceva piese din ea.Schema am gasit dar nu prea inteleg ce e acolo asa ca,m-am gandit sa fac altaAi renuntat la schema din acest topic? Link spre comentariu
Black Death Postat Ianuarie 26, 2016 Autor Partajează Postat Ianuarie 26, 2016 (editat) aceasta schema vreau sa o realizez schema de la celta e asta http://www.elforum.info/topic/112075-amplificator-celta/?p=1313685 pe mine ma intereseaza http://www.jogis-roehrenbude.de/Leserbriefe/Uli-Graf-EL34-Amp/audioamp-verst.jpg Editat Ianuarie 26, 2016 de Black Death Link spre comentariu
