Samsung seria F smart tv.
louis
fara statie de aer cald si un pic de indemanare nu rezolvi nimic ,trece locatia la profil poate un coleg prin apropriere te poate ajuta
stiu. de mult ma batea gandul sa iau si o statie..chiar si-asa o data pe an cand mai repar cate ceva din placere.
numai sa nu fie ceva stift
nu cred...la 10usd cat am dat pe el..numai fabricarea stiftului ar fi costat mult mai mult. sunt facute la comanda pentru samsung...nu prea gasesti configuratia aia de pini pe piata. :)
topicul se apropie de sfarsit...vom vedea daca am socotit bine..vinovatul.
Editat de louis
  • Răspunsuri 66
  • louis
    24
  • Gabi
    7
  • clony
  • Florinel TV
  • 1 an mai târziu...
Vizitator Gilson Novais
Hi Dear,
Did you exchange the chip (SLC1013M)? Did it works?
I have a dark strip on my TV. I have already tested everything and I believe that the problem is this chip.
Channel 4 (at the center of the 3 170V channels) is dead.
Thank you!!
I bought another power supply (used). It was not working too. :tryre It did not start, I could hear the relay close/open every 2s.
So I thought :rzb: I will change the IC SLC1013M with the other! This board that can not start should have this IC ok.
I removed the IC from the board that did not start and put it in my old board that had a channel problem (LED driver) and now it could not start! This IC is defective!! :91
I put the IC from my old board (LED Driver problem) in the board that not start and the board started. It even worked the driver defective, but then stopped.
Conclusion: Both ICs is defective! :84
I bought 2 fro UTSouce China (I am from Brazil) and after receive I post the results.
  • 10 luni mai târziu...
Buna ziua, am fost sa vad la cineva un televizor Samsung UE46F7000 (anunt de pe un site de anunturi) si are aceeasi problema: flicare o portiune orizontala din ecran in partea de jos la comutarea pe 3D. Pe 2D nu are nici o problema din ce am vazut. Aveti idee cat ar costa reparatia la un service avand in vedere posibilele probleme mentionate aici pe forum? Omul cere 1500 lei si vreau sa stiu daca se merita sa-l cumpar. Sa-i zic sa mai scada din pret? Multumesc
I se vor arde in curand benzile led , sa vezi atunci distractie
Suntem in douazeci-douzeci si tv e din 2013 = copt
La pretul asta iti iei tv nou LG sau Samsung de 50"
Editat de Tavi
Acum 13 ore, Tavi a spus:
Problema e ca eu vreau sa fie 3D si nu se mai fabrica. Cam cat ar costa reparatia cu tot cu benzile led?
Nu am idee
Eu am tv 3D luat de nou in 2013 si l-am folosit pe 3D cam 15 minute de atunci
Mi se pare o chestie inutila 3D la un televizor intr-o camera , mai mult te doare capul
De aia nici nu se mai fabrica
La fel au patit plasmele
La uzura pe care o are nu merita decat max 1000 de lei si asta doar functional 100%, numa sursa care trebuie schimbata costa 250 de lei !
https://www.okazii.ro/sursa-bn44-00632b-l46f2p_ddy-din-samsung-ue46f7000-cy-sf460dslv6b-a188023733
Editat de Costica Tv
La Samsung daca vrei 3D iti trebuie si ochelari din aia activi si foarte scumpi, ce nu cred ca se mai gasesc.  Eu nu as cumpara vechituri din 2013 nici pe 100 de lei, dar asta e doar parerea mea, tu poti sa faci ce vrei cu banii tai.
1 oră în urmă, modoran a spus:
Are toate accesoriile la el, 2 perechi de ochelari si telecomanda aia cu touch. O sa-l intreb daca il lasa la 1000 lei. Ma intreb cat m-ar costa daca l-as repara la service-ul Samsung.
Eu nu te-aş sfătui să calci pe la reprezentanţe, că dai în depresie....caută un meseriaş bun pe forum şi du-l la el.
Ideal ar fi ca meseriaşul să fie tot din Bucureşti, ca să mergeţi împreună la ăla de-l vinde şi să vadă dacă merită să-ţi rişti banii pe el.Că dacă-l iei şi costă reparaţia cât ai dat pe tv, nu ai făcut nimic....dar ca idee, la reprezentanţă cam asta te aşteaptă.Ăia nu ştiu de obicei decât să schimbe cu totul fie mainboardul, fie panelul....
Editat de validae
Acum 3 ore, Tavi a spus:
Nu am idee
Eu sunt un impatimit al filmelor 3D. Am vazut filme 3D pe un Samsung non-smart al fratelui meu pe care il are si in prezent, nu stiu ce model este, dar nu am avut nici o problema, nu m-a durut capul, absolut nimic. Iar televizorul asta pe care l-am vazut la tipul asta este exact ce imi trebuie mie si nu stiu ce sa fac. Am tot cautat pe net anunturi iar asta mi-a placut cel mai mult mai ales ca l-am si testat.
