costelvoicu72 Postat Decembrie 20, 2015 Partajează Postat Decembrie 20, 2015 buna ziua am nevoie de un dump pentru un philips model 32HF7875/10 sasiu LC7.1HELA Link spre comentariu
leoncris Postat Decembrie 20, 2015 Partajează Postat Decembrie 20, 2015 (editat) Poftim ... http://www.filehost.ro/3171933993/24c64_bin/ Esti sigur ca'i din ... BIN? CE MANIFESTARI ARE ? Editat Decembrie 20, 2015 de leoncris Link spre comentariu
costelvoicu72 Postat Decembrie 20, 2015 Autor Partajează Postat Decembrie 20, 2015 este in mod hotel Link spre comentariu
leoncris Postat Decembrie 20, 2015 Partajează Postat Decembrie 20, 2015 Hotel Mode Before the service modes can be activated, the set needs to be switched into normal consumer mode (MTV-Mode) first. Use an ITV setup remote control (type: RC2573/01, 12nc: 3139 228 88782) and key in the code ‘024995’ directly followed by the “M” (Menu) key. The text messages “TV Is Now In MTV Mode” and “Please Do A Cold Start !” appears on the screen. Disconnect the set for a few seconds from the mains supply, reconnect the set to the mains supply again. After switching “on”, the set is in normal consumer mode (MTV-Mode). After repair, place the set into hotel mode (iTV-Mode) again. Enter the same code on the remote control as described above. The text messages “TV Is Now In ITV Mode” and “Please Do A Cold Start !” appears. Disconnect the set for a few seconds from the mains supply, reconnect the set to the mains supply again. After switching “on”, the set is in Hotel mode (iTVMode Link spre comentariu
costelvoicu72 Postat Decembrie 20, 2015 Autor Partajează Postat Decembrie 20, 2015 cand apas pe tasta MENU apare scris SORYY NO INTERACTIVITY AT THE MOMENT PLEASE TRY AGAIN LATER Link spre comentariu
leoncris Postat Decembrie 20, 2015 Partajează Postat Decembrie 20, 2015 Ai tastat codul "024995", "M" (Meniu) si nu merge ? Bin_ul si TLC sunt originale ? Link spre comentariu
costelvoicu72 Postat Decembrie 20, 2015 Autor Partajează Postat Decembrie 20, 2015 Daca tastez codul se schimba programele Link spre comentariu
costelvoicu72 Postat Decembrie 20, 2015 Autor Partajează Postat Decembrie 20, 2015 am pus un dump tvul porneste si pe ecran apare mesajul do not recoverypower tv upgrading in progress Link spre comentariu
costelvoicu72 Postat Decembrie 24, 2015 Autor Partajează Postat Decembrie 24, 2015 am pus un dump tvul porneste si pe ecran apare mesajul do not recoverypower tv upgrading in progress cat timp sal las sa se upgradeze deoarece lam lasat 2 ore Link spre comentariu
costelvoicu72 Postat Ianuarie 8, 2016 Autor Partajează Postat Ianuarie 8, 2016 buna dimineata am nevoie de schema acestui tv deoarece nu are tensiune pe placuta IR Link spre comentariu
leoncris Postat Ianuarie 8, 2016 Partajează Postat Ianuarie 8, 2016 (editat) http://www.elektroda.pl/rtvforum/topic2526979.html http://elektrotanya.com/philips_lc7.1hela_312278517150.pdf/download.html Editat Ianuarie 8, 2016 de leoncris Link spre comentariu
costelvoicu72 Postat Ianuarie 8, 2016 Autor Partajează Postat Ianuarie 8, 2016 multumesc Link spre comentariu
