Numarator UP-Down cu mega2560 si UTFT
Salutare.
Am acest programel care a fost modificat de mine din afisare LCD 2x16 in afisare UTFT.
Problema care ma framanta este ca nu pot sa-l fac sa numere si ce este dupa virgula.
Acesta este programul:
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t arial_bold[];
extern uint8_t Inconsola[];
extern uint8_t SevenSegNumFont[];
UTFT myGLCD(CTE32HR, 38, 39, 40, 41);
// int sw1 = A0;  // Connect pin 8 to SW1
// int sw2 = A2;  // Connect pin 9 to SW2
int count = 0.0;
void setup()
 // pinMode(10, OUTPUT);
 // pinMode(A0, INPUT); //UP button LEFT
 // pinMode(A2, INPUT); //DOWN button RIGHT
 // pinMode(A4, INPUT); //START/STOP button MOD
//  pinMode(sw1,INPUT);
//  pinMode(sw2,INPUT);
// digitalWrite(sw1,HIGH);
 // digitalWrite(sw2,HIGH);
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(Inconsola);
  myGLCD.setColor(255, 105, 0);
  myGLCD.print("Up-Down Counter", CENTER, 20);
  // myGLCD.print("             ", 220, 60);
void loop()
    if(digitalRead(A0) == LOW)   // if SW1 is pressed perform action described in loop
                                 // (!digitalRead) >> numara continu
        count++;;                    // Increment Count by 1
        if (count>=32.1) count=3.0;
        myGLCD.printNumF(count, 1, 220, 60, 46, 4, 48);
        delay(120);
  if(digitalRead(A2) == LOW)    // if SW2 is pressed perform action described in loop
       count--;                     // Decrement Count by 1
       if(count < 2.9)
       count = 32.0;
       delay(120);
I-mi este de ajutor orice sfat.
Multumesc.
  • Răspunsuri 6
  • Liviu M
  • mars01
Zile populare
int vine de la integer - numere intregi. Adica n-au decat parte intreaga, nu si zecimale.
Ca sa "numere cu zecimale":
- int count = 0.0; --> float count = 0.0
- floar pasCounter = 0.1; //pasul care-ti trebuie
- count++; --> count = count + pasCounter;
- count--; --> count = count - pasCounter;
Ai declarat variabila count ca si integer:
int count = 0.0;
Trebuia declarata ca si FLOAT:
float count = 0.0;
LE: Liviu a fost mai rapid. Si mai complet. :)
Editat de mars01
Va multumesc frumos pt raspunsuri. Am facut modificarile si functioneaza.
Exista o mica problema.
count=0.0 asa afiseaza cand restartez, dar cand actionez o tast se muta cifrele cu un digit si de aici functionarea este OK.
Am mai adaugat ceva:
#include <UTFT.h>
// Discutii pe acesta tema:
float count = 00.0;
float count1 = 22.1;
float pasCounter = 00.1; //pasul care-ti trebuie
void setup()
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.printNumF(count, 1, 220, 60);
void loop()
    if(digitalRead(A0) == LOW)   // if A0 is pressed perform action described in loop
        count = count + pasCounter;                    // Increment Count by 1
        if (count>=32.0) count=03.0;
        delay(120);
  if(digitalRead(A2) == LOW)    // if A2 is pressed perform action described in loop
       count = count - pasCounter;                     // Decrement Count by 1
       if(count < 02.9)
       count = 32.0;
       delay(120);
     if (count>=count1) { myGLCD.print("OFF" , CENTER, 120); }
    else { myGLCD.print("ON ", CENTER, 120); }
As putea sa memorez undeva in EEPROM ceea ce am tastat ultimaoara?
Editat de Vizitator
La inceput:
#include <EEPROM.h>uint8_t eeAddrCountIntregi = 0;uint8_t eeAddrCountZecimale = 1;
in setup()
float count = EEPROM.read(eeAddrCountIntregi);uint8_t zecimale = EEPROM.read(eeAddrCountZecimale);count = count + ((float)zecimale / 10.0); //zecimale de la 0 la 9
Dupa ce ai ajuns la valoarea care-ti trebuie:
uint8_t parteIntreaga = count; //pastrezi doar partea intreagauint8_t parteaZecimala = (count - parteaIntreaga) * 10;  //calculeaza partea zecimala si salveaz-o intr-un intregEEPROM.write(eeAddrCountIntregi, parteIntreaga); EEPROM.write(eeAddrCountZecimale, parteZecimala);
Daca vrei mai multe zecimale, modifici factorul cu care imparti/inmultesti.
Ai grija cat de des modifici count. EEPROMul se toceste.
He, he tocmai am descoperit ca exista functii mai destepte, EEPROM.put() & EEPROM.get() care lucreaza direct cu float si mai si verifica daca numarul de scris difera de ce e deja in eeprom.
https://www.arduino.cc/en/Reference/EEPROM
La inceput:
in setup()
Multumesc mult Liviu M.
O sa ma straduiesc si cu aceasta modificare.
Si memorarea as preferat sa se faca la un anumit interval de timp, unu, doua minute, sau la esirea din setari. Dar asta este alta tema cred.
Sau mai bine pe un EEPROM extern. O sa trag cu ochiul pe adresa postata.
