spark Postat Decembrie 11, 2015 Partajează Postat Decembrie 11, 2015 ok_am reusit _suntem cam saraci in videotutoriale despre pic-uri ok ..................................................................................................... #include <pic.h>#include <stdio.h>#include "intr.h"#include "lcd.h"#include "delay.h"#include <string.h>#include"const.h"__CONFIG(WDTDIS & INTIO & LVPDIS & MCLRDIS & PWRTEN & BOREN);enum{ready,steby,meniu,tempstby,timpstby,timpoff,buzz,templ,pwroff} stare;#define stby RA3#define cald RB0#define DWN RB1#define UP RB2#define OK RB3#define CAN RA5#define blink RA4#define buz RB4#define bkled RB5unsigned long sumaA;unsigned int valtemp,settempl,settempstby,timp,timpsteby,templucru;unsigned char nrA,ext,s[21],sv[4],se[4],sett,set2,set3;unsigned char nrlinie,secunda;bit okaf,af,bit1,facut,ok,up,dwn,can,set,set4,bitstby,bitbuzz;void main(void){ OPTION=0b10001111; INTCON=0b11100000; PIE1=0b01000000; PIR1=0; PIE2=0; PIR2=0; PCON=0b00000011; EECON1=0; OSCTUNE=0; OSCCON=0b01111100; TRISA=0b00101100; TRISB=0b00001110; PORTA=0; PORTB=0; CCP1CON=0; SSPCON=0; CMCON=7; CVRCON=0; ANSEL=0b00000100; ADCON1=0b11000000; ADCON0=0b01010001; bkled=1; stare=ready; okaf=1; buz=0; af=1; // ************************ citire parametri eeprom ************************************ di(); ee_rd(0,sett); ee_rd(1,set); if(set){settempl=sett+250;} // temperatura lucru letcon else{settempl=sett;} templucru=settempl; ee_rd(2,settempstby); // temperatura srand by letcon ee_rd(3,set2); // timp intrare in stand by if(set2<1){set2=15;} ee_rd(4,set3); // timp power off if(set3<1){set3=5;} ee_rd(5,bitbuzz); // bit buzz ON/OFF initLCD(); clrLCD; line1(); strcpy(s," SOLDERING STATION "); print(s); line2(); strcpy(s," homemade projects "); print(s); line3(); strcpy(s," by Dan Spark "); print(s); line4(); strcpy(s," starting... "); trebuia sa creez un nou proiect si am importat mainC_am dat build_si am obtinut hex-ul daca merge bine statia de lipit pun toata documentatia la sheer Link spre comentariu
Liviu M Postat Decembrie 11, 2015 Partajează Postat Decembrie 11, 2015 La cum arata pare a fi scris in picc de la hi-tech ("stramosul" lui xc8). Link spre comentariu
costy2011 Postat Decembrie 18, 2015 Autor Partajează Postat Decembrie 18, 2015 vreau sa realizez ceva in genul acesta http://www.ebay.com/itm/Handheld-Frequency-Counter-Meter-Wireless-Remote-Control-Reader-250MHz-450MHz-/151688276127?hash=item235153689f:g:LAgAAOSw3xJVXRp7 .nu am decat un freqvency meter facut de mine cu pic 628 parca, aruncat pe undeva prin dulap. m-ar ajuta sa vad exact frecventa/pwr unei telecomenzi wireless(fie si analogic) intre 250-450 mhz. poate e vreun coleg care a facut un montaj asemanator si functioneaza.multumesc. Link spre comentariu
Liviu M Postat Decembrie 18, 2015 Partajează Postat Decembrie 18, 2015 La cat costa ala din link, eu zic sa-l cumperi linistit. Cu pic nu cred sa reusesti sa faci asa ceva. Daca totusi reuseti (nu cunosc gama de controllere high end de la uChip, poate au ceva sa mearga), nu cred sa iesi mai bine la pret. Link spre comentariu
costy2011 Postat Decembrie 18, 2015 Autor Partajează Postat Decembrie 18, 2015 ai perfecta dreptate.doar ca dureaza pana ajunge si nu se stie daca functioneaza.o sa risc totusi. Link spre comentariu
Mircea Postat Decembrie 18, 2015 Partajează Postat Decembrie 18, 2015 Acel frecventmetru are un etaj de intrare RF, divizor de frecventa, ceva cunostinte conceptie PCB sunt necesare. Nu e un simplu PIC la care aplici 450MHz pe o intrare.. Are sa mearga dracia aia de pe eBay, nu-ti face griji. De banii pe care ii platesti. Depinde la ce o folosesti. Uite un exemplu: http://www.pira.cz/counter.htm. Sunt multe exemple pe Google. Link spre comentariu
costy2011 Postat Decembrie 23, 2015 Autor Partajează Postat Decembrie 23, 2015 (editat) un frecventmetru cu pic am acasa.imi trebuie receptia semnalului transmis de telecomanda si aplicat frecventmetru-ui si sa arate si corect frecventa. il folosesc la automatizari pentru a acorda telecomanda pe frecventa receptorului. o sa fa comanda pe e-bay. multumesc, SARBATORI FERICITE! Editat Decembrie 23, 2015 de costy2011 Link spre comentariu
