hex from .bas please
Vizitator chiar_eu
Vizitator chiar_eu
' * Title : EEPROM programmer.bas
' * Last Updated : 05.03.2006
' * Target device: At90s2313, 24C32
' * Author : http://www.avrprojects.net
' * Program code : BASCOM-AVR
' * Hardware req. :
' * Description :
' * This application reads and writes one page at a time to an 24c32 EEPROM connected to an
' * AT2313 microcontroller.
Dim D_w As Byte , D_r As Byte , Adress As Byte , E_adr As Byte , E_dat As Byte , I As Byte , Count As Byte
Dim Rw As String * 1 , Datastr As String * 32
Dim E_data(16) As Byte
Config Scl = Portb.0 'assign the SCl line to PORTD.0
Config Sda = Portb.1 'assign the SDA line to PORTD.1
'Declare Sub Byteread
'Declare Sub Bytewrite
Declare Sub Pagewrite
Declare Sub Pageread
Main:
Do
Input "®ead page / (W)rite page?" , Rw
If Rw = "R" Or Rw = "r" Then Goto Read_eeprom
If Rw = "W" Or Rw = "w" Then Goto Write_eeprom
Loop
End 'end program
Read_eeprom:
Do
Input "Read EEPROM page :" , Adress
Print Adress ; ":" ;
E_adr = Adress * 16
Call Pageread
For I = 1 To 16
Print E_data(i) ; ",";
Next I
Print
Loop
Write_eeprom:
Do
Input "Write EEPROM page :" , Adress
For I = 1 To 16
Input "Input byte ";i;" :" , E_data(i)
Next I
Print Adress ; ":"
For I = 1 To 16
Next I
E_adr = Adress * 16
Call Pagewrite
Print
Loop
'********** page write to EEPROM ***************************************************
Sub Pagewrite
I2cstart 'generate start
I2cwbyte &B1010_0000 'send device address
I2cwbyte &H00 'H adress of EEPROM
I2cwbyte &H00 'L adress of EEPROM
For I = 1 To 16
D_w = E_data(i)
I2cwbyte D_w 'data to EEPROM
Next Adress
I2cstop 'stop condition
Waitms 10
End Sub Pagewrite
'********** page read from EEPROM **************************************************
Sub Pageread
I2cwbyte &B1010_0000 'send device adsress
I2cwbyte &H00 'H address of EEPROM
I2cwbyte E_adr 'L address of EEPROM
I2cstart 'repeated start
I2cwbyte &B1010_0001 'slave address (read)
For I = 1 To 16
I2crbyte D_r , Ack 'data to EEPROM
E_data(i) = D_r
Next I
I2crbyte D_r , Nack 'read byte from EEPROM
I2cstop
End Sub Pageread 'generate stop
'********** byte write to EEPROM ***************************************************
'Sub Bytewrite
'I2cstart 'generate start
'I2cwbyte &B1010_0000 'send device address
'I2cwbyte 0 'H adress of EEPROM
'I2cwbyte 0 'L adress of EEPROM
'I2cwbyte D_w 'data to EEPROM
'I2cstop 'stop condition
'Waitms 10
'End Sub
'********** byte read from EEPROM **************************************************
'Sub Byteread
'I2cwbyte &B1010_0000 'send device adsress
'I2cwbyte &H00 'H address of EEPROM
'I2cwbyte &H00 'L address of EEPROM
'I2cstart 'repeated start
'I2cwbyte &B1010_0001 'slave address (read)
'I2crbyte D_r , Nack 'read byte from EEPROM
' I2cstop 'generate stop
'End Sub Byteread
  • Răspunsuri 7
  • sofian
Vizitator Vasile
BASCOM AVR ii zice la Programul pe care trebuie sa-l folosestiai erori in programError : 1 Line : 25 Unknown statement [MAIN]Error : 1 Line : 33 Unknown statement [READ_EEPROM]Error : 1 Line : 45 Unknown statement [WRITE_EEPROM]
Vizitator musaraf
Se pare ca problema era cu ceva spatii dupa label-uri (Main:, Read_eeprom:, Write_eeprom:), daca se sterg compileaza.Si i-am mai pus un $regfile = "2313DEF.dat" la inceput. Compilat si cu o varianta mai veche de Bascom (cu aia noua nu stiu daca alege corect chipul).HEX-urile si BAS-ul a trebuit sa le pun ca DOC, ca nu ma lasa altfel.Sper sa-ti mearga.
  • 2 săptămâni mai târziu...
Vizitator chiar_eu
am citit pedefeul de modificare de la at90s2313 la atinny2313 dar nu am brighidit care-i shmenul. Poti Vasile sa-mi compilezi aceeasi traba pentru attinny2313?Berea vine la B1 de la Iri ...varu-miu! :partyman:
softul ala nu face nimic altceva decit sa scrie si sa citeasca dintr-un eeprom 24c32 conectat la pini PORTD.0 si PORTD.1
ca sa se conecteze cu o interfata mai trebuie lucrat "putin" la soft
Vizitator chiar_eu
softul ala nu face nimic altceva decit sa scrie si sa citeasca dintr-un eeprom 24c32 conectat la pini PORTD.0 si PORTD.1ca sa se conecteze cu o interfata mai trebuie lucrat "putin" la soft
pai nu am nevoie musai de interfata aia...am inteles ca ea doar are prememorate niste linii cu cod cunoscut pe care le incarca in locul celor necunoscute...eu vreau doar sa mearga aplicatia de i2c reader writer de la avr projects, dar deocamdata nu pot accesa aplicatia lor de hyperterminal...da o eroare...This is a terminal program that you can use for serial communication with you microcontrollers. It is written in Visual Basic.Net. The program is simple to use. To use the program a file called port.dll needs to be placed in the same folder as the AVR Terminal.exe file. All the files can be downloaded at the bottom of this page. Within the program the Com ports 1 to 8 can be choosen and also the baud rate from 300 to 19200 baud. The screen is divided in 2 areas, one for the input and one for the output. If you enter text in the input area and push [ENTER] the input area will automatically be cleared.http://www.avrprojects.net/articles.php?lng=en&pg=68
