Amplificator simetric simplu(darlington).
Letcon
Imi permit sa va rog ( ca tot s-a discutat de bias ) sa-mi spuneti cum se regleaza biasul daca racirea e activa! Ventilatorul, fiind unul maricel, mentine radiatoarele reci, biasul a fost reglat cu radiatoarele calde, ventilatoarele oprite.....,dar, amp-ul va functiona permanent cu ventilatoarele pornite, se vor mentine radiatoarele reci, in permanenta, ceea ce va face sa scada curentul de repaus! Multumesc!
Raspunsul pe care-l astept e logic: reglajul se face ca la carte, dar cu ventilatoarele pornite!
Editat de Darden
Setting bias
Always set the bias:
• after replacing any output or driver transistor.
• after replacing any diode or resistor in the driver/output circuitry.
• if the amplifier seems to run too hot at idle.
• if the amplifier exhibits crossover distortion.
The bias network sets the quiescent base current in the NPN and PNP driver transistors, which in turn sets the quiescent current in the output transistors. The driver transistors should both be slightly ‘‘on’’ at idle so that the transitions of the signal voltage between positive and negative are smooth and free of gaps or glitches. Too much bias current will cause the amplifier to run hotter than it should, especially at idle, while too little will cause noticeable crossover distortion, especially at low signal levels.
The amplifier circuitry must be cool, or at least within a couple degrees of ambient air temperature, and the top cover must be removed. If the driver and output transistors are significantly warmer than the ambient air, leave the amplifier off and let it cool before proceeding.
Atata cearta pentru un amarat de bias!Spuneti ca trebuie reglat o data la temperatura camerei si pe urma masurat si modificat dupa temperatura radiatorului!Acum intreaba prostul din mine:ce se intampla daca eu reglez bias-ul dupa ce incing radiatorul dar eu in cele mai multe cazuri ascult la el o putere care nu incalzeste rad peste temperatura camerei?folosind si ventilatoare!
Pai exact asta am intrebat si eu........ventilatoarele le-am lasat sa functioneze continuu, la o turatie care sa asigure o racire corespunzatoare, dar, in acelasi timp, sa fie silentioase! Multumesc!
Nu conteaza la ce putere asculti tu; aparatul poate ajunge si la altcineva. Este riscant (si tehnic nepermis) sa folosesti asta drept criteriu.
Nu va mai prostiti, ati inteles toti cum se face (reglaj la rece, apoi se verifica dupa stabilizarea termica, la nevoie se micsoreaza putin).
LE - se micsoreaza daca se incalzeste prea tare radiatorul; stabilizarea termica se face cu capacul carcasei montat. Se tine seama si de temperatura ambianta maxima vara, si ca este posibil ca aparatul sa fie montat intr-un rack pasiv.
Destul de clar.......pe mine m-a indus in eroare alt aspect, si anume refacerea reglajului dupa 15-20-30 minute de functionare a amplificatorului, sunt electronisti care recomanda acest lucru! In mod normal,dupa 30 de minute de functionare, putem spune ca radiatorul nu mai e la temperatura camerei, aici a fost nedumerirea mea! Multumesc!
Daca se modifica semnificativ dupa incalzire atunci ori mai este vre-un defect ori schema este de tot ra..ul.
Nu trebuie sa se modifice semnificativ cu incalzirea, se admite numai scaderea cu incalzirea.
Zalica, Faptul ca tu nu ai nici un argument tehnic doar poze din scheme nu insemna ca Ube prag nu variaza mult cu temperatura.
Ada tu un argument prin care Ube e constant cu temperatura si te credem. Dar spune nene, nu tine pt tine.
Lumea iti explica, tu doar o ti cu poze dupa o schema cu valori.
DAr hai sa iti spun de ce sunt valori de tensiune si nu curenti, ca nici de asta nu te prinzi. Pt ca e mult mai usor sa masori cu voltmetru decat sa inseriezi un ampermetru. Iti da niste valori orientative asa incat depanatorul de ocazie sa nu stea sa calculeze, sa masoare direct si sa compare cu ce e de dorit. Apoi vede instant cam pe unde e hiba si determina cauza.
Vorbele ti le spun direct in fata fara greturi, la cat ne-ai innebunit pe aici. Nu stiu cum va decurge si cat ma voi implica intr-o eventuala ciondaneala am trecut de varsta in care tineam sa arat cine e mai tare fara sa am ceva de castigat de urma.
Plangere pt asalt fac oricum daca e cazul. Maimutele in general stau dupa gratii, dar na, in romania totul e posibil.
Oricum mare lucru ce o sa faci? O sa te oftici? MA injuri? MA scuipi?
Ca tehnic oricum n-ai multe de zis sau cel putin nu te-ai exprimat pana acum.
Draga echipa de moderatori, ati facut subiectul praf.
Va rog eu, mutati duelul vostru intr-un alt topic. Zic si eu ca .: si ce daca zice gresit colegul Zal? Lasa-l, domnule, sa fie el in eroare. S-a zis cam tot ce era de zis despre bias, cine stie sa citeasca trage concluzia dupa cum zice majoritatea.
@Claudiu, la vremea respectiva nu am remarcat o concluzie concreta despre ce e de inteles din acel screenshot de la Quad. Cred ca o poti enunta acum acea concluzie. De la a avea informatia asta si pana la a vinde ceva de talia amplifurilor tale... e cale prea lunga ca sa te sperii. Zic si eu.
Tehnica respectiva nu e secretă , dar e confidențiala .
Au trecut vremurile cand se vărsa totul din casă ( inclusiv userilor invidioși , nerespectuoși , cu probleme de socializare etc cărora eu le doresc multă sănătate :) ) , iar la nivel de forum și nu numai , metoda lui N Pass " 26 mV " este excelentă .
Calibrarea bias-ului cu ajutorul analizei FFT nu este la îndemâna oricarui user și depășește nivelul acestui forum .
Recomand cu multă căldură metoda lui N Pass " 26 mV " .
Sper ca acum totul e cat se poate de clar cum se regleaza curentul de repaus , asa ca urez celor care au facut praf acest subiect , multa sanatate pentru ei si famillilor lor .
Evident , au mare nevoie .
Sa revenim la amplificatoare .
Nu crede că injinerii de la McIntosh, Altec, LEM şi alte firme sînt la fel de fraieri ca mine, n-ai nici o şansă să-i ajungi dacă perseverezi aşa.
Pentru cei ce cred inca in capitalismul fara scrupule si bias-ul aleator : https://www.youtube.com/watch?v=SEkJ6FSMoz8&app=desktop
Catre moderatori :
Va rog sa lasati activ acest subiect , sunt curios de comentarii ... sper sa se lamureasca toata lumea .
Multumesc anticipat !
