Modul mp3 de panou cu telecomanda
maxente
Ce parere aveti de un astfel de modul ?
Mie imi place modulul asta http://www.aliexpress.com/item/Silver-Remote-USB-SD-FM-MP3-Player-Module-02CBT-control-DC5V-12V-parts-without-bluetooth-Free/32320132334.html?spm=2114.031010208.3.20.1wYs9K&ws_ab_test=searchweb201556_8,searchweb201527_1_71_72_73_74_75,searchweb201560_4
Am vazut ca mai sunt unele si cu bluethoot, dar ceva mai scumpe
A mai luat cineva asa ceva, sunt bune, calitatea sunetului cum este ?
Daca aveti sugestii pentru un alt tip de modul va rog sa imi spuneti
  • Răspunsuri 31
  • maxente
    8
  • Untold
  • Eugen Chirila
  • player4
Eu ma cumparat cu titlu experimenal si acest model, care este deosebit fata de toate celelalte, ti-l recomand cu incredere.
LCD 12v MP3 Player WMA WAV decoder audio board FM Radio Bluetooth Audio Receiver
post-238516-0-67304300-1444851514_thumb.gifpost-238516-0-31298600-1444851588_thumb.gifpost-238516-0-39411200-1444851656_thumb.gif
Working voltage: 7-12v
A: model
B: play the suspended
C: stop
D: circulation
E: a song on
F: the next song
Note: press mode key switch to recording mode, press play pause button on the tape again to play pause button to stop recording
The module features:
support the recording
support signal switch directly.
support Bluetooth3.0 EDR
support USB/SD/Bluetooth/FM/LINE automatic switching.
decoding chip module embedded MP3 / WMA songs.
support USB, SD, MMC card to play.
support USB/SD card switching, a song, the next song, fast forward, fast rewind, volume, EQ, play/pause, stop, single repeat, mute, shutdown and direct election.
support Bluetoot on a song, the next song, volume, EQ, play/pause, mute, turn it off.
support FAT16, FAT32 file system.
support for MP1 Layer3, MP2 Layer3, MP3 Layer3 version of the song.
support 32-320 KBPS MP3 songs.
support power off memory function: play songs and volume before memory power
Referitor la modelul prezentat de tine si cel mentionat de @player4, la calitatea sunetului, este OK, ca sensibilitate pe radio la fel, totul tine de noroc. Poti cumpara unul care sa marga bine merci fara probleme, sau sa ai norocul sa mearga o zi doua si sa crape din senin, sau sa nu ii merga o tasta sau doua, asa cum am avut eu cu primul pe care l-am cumparat, care a functionat exact 2 zile fix 48 de ore dupa care a crapat decodorul MP3 atat pe intrarea USB cat si pe intrarea microSD.
Editat de Eugen Chirila
Va multumesc pentru raspunsuri
Un prietem mi-a arata si o varianta pe negru cu bluethoot http://www.aliexpress.com/store/product/Black-New-Remote-USB-SD-MP3-Player-Module-02CBT-Remote-control-MP3-parts-with-bluetooth-3/1303249_32262355440.html
@Eugen Chirila e interesant si varianta propusa de dvs. doar ca nu are partea aia de plastic din fata si pare putin mai dificil de montat pe un panou
Imi cer scuze ca am mai deschis un subiect cand deja mai era unul deschis despre aceste module
Rog frumos un moderator sa comaseze cumva si subiectul asta daca considera ca e in plus
Editat de maxente
  • 2 săptămâni mai târziu...
Am salvat vreo doua combine audio cu patrea de CD stricata, partea optica nu mai citeste discurile
La una din combine avea intrare AUX si l-am conectat acolo
Eu le-am testat cat am surubarit la combine
Combinele sunt la casele lor si banuiesc ca daca proprietarii nu m-au contactat inseamna ca merg si acum
Mai am un modul si as cam vrea sa il pun pe panoul unui amplificator la care tot mesteresc, asta o sa mai stea la mine si il voi testa mai mult, oricum nu cred sa fie vreo problema
Modulul se alimenteaza cu maximum 5V, nu trebuie sarit peste ca se prajeste. Eu i-am pus un C.I. 7805 pe placa sa pot alimenta cu mai mult din diferite surse
Editat de maxente
A: model
C: stop
D: circulation
E: a song on
F: the next song
Am reusit sa ii fac un filmulet.
Sunetul este de foarte proasta calitate din cauza aparatului de filmat, in realitate se aude exceptional.
Azi mi-am luat un alt modul asemanator cu cel de la postul #10
E mai ieftin 17 lei , aproape la jumate de pret si nu are cipul de final audio cum are cel de sus, ambele sunt luate de la miv....rom
La radio are alt cip , QN8075 http://greyghost.mooo.com/kinter-a5/QN8075.pdf
Am observat un lucru, la iesire semnal mai mare fata de varianta de mai sus care cam necesita un preu in fata
In rest sunt surprins ca se aud mp3-urile la 320kbps foarte curat, si cel de sus e la fel de ok la sunet
Editat de maxente
  • 1 lună mai târziu...
Mi-a veni modulul mp3 de care ziceam in primul post dar pe varianta neagra si are bluethoot
E interesant la partea cu bluethoot ca in momentul in care comut sursa pe stick sau card imi pune pauza la melodia din telefon
Revine la modul de play a melodiei in momentul in care comut inapoi pe bluethoot
O alta chestie interesanta e ca la conectarea telefonului cu modulul se aud niste beep-uri in surdina chiar daca volumul e aproape de maxim. Mai vazusem o boxa portabila care avea bluethoot si la conectarea telefonului se auzea un pocnet foarte puternic si deranjant
Ca sunet mi se pare foarte ok
Posted Image    Posted Image
