Echivalent MPSA13
Va salut,
Ce tranzistor pot folosi in locul tranzistorului Darlington MPSA13 ?
Mi-a fost indicat BC618, dar are terminalele dispuse altfel, iar eu il voi folosi ca superdioda; trebuie sa stea lipit cu partea dreapta de radiator.
Si inca ceva: in foile de aplicatie pentru BC618 de la ON semiconductors si cea de la NXP vad niste diferente. Terminale dispuse altfel, cat si curentul de colector.
N-am gasit in Iasi, pe stoc, MPSA14 (in premisa in care e echivalent).
Editat de norad
  • Răspunsuri 4
  • norad
  • Baditza Vasy
  • Toni Marginean
Eu am gasit lista asta cu ce poti inlocui, acum conteaza si in ce schema il folosesti
       Mat    Struct    Pc    Ucb    Uce    Ueb    Ic    Tj    Ft    Cc, pF    Hfe    Caps 1. 2N6426    Si    NPN    0.625    40    40    12    0.5    150    150    7    20000    TO92 2. 2N6427    Si    NPN    0.625    40    40    12    0.5    150    130    7    10000    TO92 3. 2N7051    Si    NPN    0.625    100    100    12    1.5    150    200        1000    TO92 4. 2N7052    Si    NPN    0.625    100    100    12    1.5    150    200        1000    TO92 5. 2SC1213AKC    Si    NPN    0.4    0    50    0    0.5                100    TO92(1) 6. 2SC1213AKD    Si    NPN    0.4    0    50    0    0.5                160    TO92(1) 7. 2SC1754    Si    NPN    0.625    40    40    12    0.5    180    150    7    30000    TO92 8. 2SC2925    Si    NPN    0.75    60    0    0    0.7    150    125        1000    TO92 9. 2SC3202    Si    NPN    0.5    35    0    0    0.5    175    300        20    TO92 10. 2SC3377    Si    NPN    0.6    40    0    0    1    150    150        45    TO92 11. 2SC3726    Si    NPN    0.9    50    0    0    2    155    150        1200    TO92 12. 2SC3940    Si    NPN    1    30    0    0    1    175    200        15    TO92 13. 2SC3940A    Si    NPN    1    60    0    0    1    175    200        50    TO92 14. 2SC4145    Si    NPN    1.2    80    0    0    2    150            200    TO92 15. 2SC4208    Si    NPN    1    30    0    0    0.5    150    150        30    TO92 16. 2SC4781    Si    NPN    0.9    30    30    10    4    150    170        0    TO92 17. 2SC6132    Si    NPN    0    0    80    0    1                100    TO92 18. 2SC6136    Si    NPN    0.5    600    285    0    0.7                0    TO92 19. 2SD1014    Si    NPN    0.9    50    50    50    2    150            150    TO92 20. 2SD1015    Si    NPN    0.9    140    50    50    2    150            150    TO92 21. 2SD1140    Si    NPN    0.9    30    30    10    1.5    150            4000    TO92 22. 2SD1146    Si    NPN    0.9    50    0    0    2    150            300    TO92 23. 2SD1209    Si    NPN    0.9    60    0    0    1    150            4000    TO92 24. 2SD1211    Si    NPN    1    120    0    0    0.5    150    200        80    TO92 25. 2SD1331    Si    NPN    0.9    40    0    0    1.5    150            45    TO92 26. 2SD1388    Si    NPN    0.7    60    0    0    1    150            250    TO92 27. 2SD1468    Si    NPN    0.4    30    0    0    1    150    150        40    TO92 28. 2SD1490    Si    NPN    0.75    70    0    0    1    150            60    TO92 29. 2SD1642    Si    NPN    0.7    100    0    0    2    150            40    TO92 30. 2SD1698    Si    NPN    0.75    100    0    0    0.8    150            10000    TO92 31. 2SD1701    Si    NPN    0.75    1700    0    0    0.8    150            10000    TO92 32. 2SD1786    Si    NPN    0.9    40    0    0    2    150            20000    TO92 33. 2SD1812    Si    NPN    0.9    160    0    0    1.5    150            25    TO92 34. 2SD1929    Si    NPN    1.2    60    0    0    2    150            5000    TO92 35. 2SD1930    Si    NPN    1.2    100    0    0    2    150            5000    TO92 36. 2SD1931    Si    NPN    1.2    60    0    0    2    150            10000    TO92 37. 2SD1934    Si    NPN    1    40    0    0    5    150            30    TO92 38. 2SD1937    Si    NPN    1    120    0    0    0.5    150            30    TO92 39. 2SD1942    Si    NPN    1.2    40    0    0    2    150            30    TO92 40. 2SD1960    Si    NPN    0.75    30    0    0    5    150            30    TO92 41. 2SD1961    Si    NPN    1.2    30    0    0    5    150            30    TO92 42. 2SD1978    Si    NPN    0.9    120    0    0    1.5    150            10000    TO92 43. 2SD1984    Si    NPN    0.9    30    0    0    1    150            1500    TO92 44. 2SD2046    Si    NPN    1    50    0    0    1.5    150            5000    TO92 45. 2SD2068    Si    NPN    1    60    0    0    1    150            18000    TO92 46. 2SD2071    Si    NPN    0.6    30    0    0    0.5    150            30    TO92 47. 2STL1360    Si    NPN    0    80    60    0    3                160    TO92L 48. 2STL2580    Si    NPN    0    800    400    0    1                60    TO92MOD 49. 2STX1360    Si    NPN    0    80    60    0    3                160    TO92 50. 3TE440    Si    NPN    10    80    0    0    1.5    150    350        40    TO92 51. 3TE450    Si    NPN    5    80    0    0    0.5    150    350        40    TO92 52. 5302D    Si    NPN    25    800    400    10    2    150            10    TO252_TO92_TO126_TO251_SOT223 53. BC337-025    Si    NPN    0.625    0    45    0    0.8        210        160    TO92 54. BC337-040    Si    NPN    0.625    0    45    0    0.8        210        250    TO92 55. BC517A3    Si    NPN    0.625    40    30    10    0.5    150    220    5    10000    TO92 56. BC517S    Si    NPN    0.625    40    30    10    1    150    200        33000    TO92 57. BC617    Si    NPN    0.625    50    40    12    1    150    150    4.5    10000    TO92 58. BC618    Si    NPN    0.625    80    55    12    1    150    150    4.5    3000    TO92 59. BFQ231    Si    NPN    0.675    100    70    0    0.3    150            20    TO92 60. BFQ231A    Si    NPN    0.675    115    70    0    0.3    150            20    TO92 61. BFX152    Si    NPN    0.83    100    0    0    0.3    175    500        75    TO92 62. BTNA14A3    Si    NPN    0.625    30    30    10    0.5    150    125        20000    TO92 63. BUJ100    Si    NPN    0    0    700    0    1                14    TO92 64. BUJ100LR    Si    NPN    2.1    0    700    0    1                7.5    TO92 65. C266    Si    NPN    0.825    0    60    10    2    175            45    TO92 66. CN450    Si    NPN    0.75        45        1        150        100    TO92 67. CN451    Si    NPN    0.75        60        1        150        50    TO92 68. CSD471G    Si    NPN    0.8        30        1        130        200    TO92 69. CSD471O    Si    NPN    0.8        30        1        130        70    TO92 70. CSD471Y    Si    NPN    0.8        30        1        130        120    TO92 71. CX901    Si    NPN    0.5    45    0    0    0.5    150    200        120    TO92 72. CX906    Si    NPN    0.5    45    0    0    0.5    150    200        60    TO92 73. CX906A    Si    NPN    0.5    45    0    0    0.5    150    200        90    TO92 74. CX906B    Si    NPN    0.5    45    0    0    0.5    150    200        120    TO92 75. CX906C    Si    NPN    0.5    45    0    0    0.5    150    200        140    TO92 76. CX906D    Si    NPN    0.5    45    0    0    0.5    150    200        160    TO92 77. CX908    Si    NPN    0.625    45    0    0    1    150    150        80    TO92 78. CX908B    Si    NPN    0.625    45    0    0    1    150    150        120    TO92 79. CX908C    Si    NPN    0.625    45    0    0    1    150    150        140    TO92 80. CX908D    Si    NPN    0.625    45    0    0    1    150    150        160    TO92 81. DTD113Z    Si    NPN    0.625        50        0.5    150    200        82    TO92_SOT23_SOT323_SOT523 82. DTD143E    Si    NPN    0.625        50        0.5    150    200        47    TO92_SOT23_SOT323 83. ECG123AP    Si    NPN    0.5    75    40    0    0.8    175    300        200    TO92 84. ECG2341    Si    NPN    0.8    0    80    0    1    150            2000    TO92 85. ECG293    Si    NPN    0.75    60    50    0    1    150    200        120    TO92 86. ECG382    Si    NPN    0.9    120    100    0    1    150    140        200    TO92 87. ECG46    Si    NPN    0.625    0    100    0    0.5    150    200        10000    TO92 88. ECG85    Si    NPN    0.6    70    70    0    0.4    150    200        120    TO92 89. GES4450    Si    NPN    0.36    60    30    0    0.5    150    175    8    100    TO92 90. HBC517    Si    NPN    0.625    40    30    10    0.5    150    220    5    30000    TO92 91. HEPS0025    Si    NPN    0.35    60    40    0    0.6    150    300        100    TO92 92. HEPS0034    Si    NPN    0.625    0    60    0    0.5    150            30    TO92 93. HEPS9100    Si    NPN    0.5    30    0    0    0.3    150    200        20000    TO92 94. HIT667    Si    NPN    0.9    0    100    0    1                140    TO92Mod 95. JC337A    Si    NPN    0.8    0    60    0    1    150    200    5    40    TO92 96. KN4400    Si    NPN    0.625    0    40    0    0.6                50    TO92 97. KN4401    Si    NPN    0.625    0    40    0    0.6                100    TO92 98. KRC241    Si    NPN    0.625        50        0.8    150    200        33    TO92 99. KRC241M    Si    NPN    0.4        50        0.8    150    200        33    TO92M 100. KRC242    Si    NPN    0.625        50        0.8    150    200        39    TO92 101. KRC242M    Si    NPN    0.4        50        0.8    150    200        39    TO92M 102. KRC243    Si    NPN    0.625        50        0.8    150    200        47    TO92 103. KRC243M    Si    NPN    0.4        50        0.8    150    200        47    TO92M 104. KRC244    Si    NPN    0.625        50        0.8    150    200        56    TO92 105. KRC244M    Si    NPN    0.4        50        0.8    150    200        56    TO92M 106. KRC245    Si    NPN    0.625        50        0.8    150    200        56    TO92 107. KRC245M    Si    NPN    0.4        50        0.8    150    200        56    TO92M 108. KRC246    Si    NPN    0.625        50        0.8    150    200        56    TO92 109. KRC246M    Si    NPN    0.4        50        0.8    150    200        56    TO92M 110. KSP13    Si    NPN    0.625    30    30    10    0.5    150    125        5000    TO92 111. KSP14    Si    NPN    0.625    30    30    10    0.5    150    125        10000    TO92 112. KSP25    Si    NPN    0.625    40    40    10    0.5    150            10000    TO92 113. KSP26    Si    NPN    0.625    50    50    10    0.5    150            10000    TO92 114. KTC1006    Si    NPN    1    0    80    0    0.8    175            100    TO92 115. KTC1020    Si    NPN    0.4    0    30    0    0.5    175            100    TO92 116. KTC1027    Si    NPN    1    0    120    0    0.8    175            80    TO92 117. KTC3202    Si    NPN    0.625    0    30    0    0.5    175            100    TO92 118. KTC3203    Si    NPN    0.625    0    30    0    0.8    175            100    TO92 119. KTC3204    Si    NPN    0.4    0    30    0    0.8    175            100    TO92 120. KTC3205    Si    NPN    1    0    30    0    2    175            100    TO92 121. KTC3227    Si    NPN    1    0    80    0    0.4    175            70    TO92 122. KTC3228    Si    NPN    1    0    160    0    1    175            60    TO92 123. KTC9013    Si    NPN    0.625    0    30    0    0.5    175            64    TO92 124. MPSA13    Si    NPN    0.33    30    30    10    0.3    150    125    10    5    TO92 125. MPSA25    Si    NPN    0.625    0    40    12    0.5    150    125        10    TO92 126. MPSA26    Si    NPN    0.625    0    50    12    0.5    150    125        10    TO92 127. MPSA28    Si    NPN    0.625    0    80    12    0.5    150    125        10    TO92 128. MPSA29    Si    NPN    0.625    0    100    12    0.5    150    125        10    TO92 129. NTE172A    Si    NPN    0.4    40    40    12    0.3                7000    TO92 130. NTE382    Si    NPN    0.9    120    100    0    1        140        200    TO92M 131. NTE46    Si    NPN    0.625    100    100    12    0.5                10000    TO92 132. NTE48    Si    NPN    1    60    50    12    1                25000    TO92 133. P2N2222A    Si    NPN    0.625    0    40    0    0.6        300        100    TO92 134. PHD13003C    Si    NPN    2.1    0    700    0    1.5                9    TO92 135. PHE13003A    Si    NPN    2.1    0    700    0    1                7.5    TO92 136. PHE13003C    Si    NPN    2.1    0    700    0    1.5                9    TO92 137. SML2182    Si    NPN    0.36    0    120    0    5    200    200        400    TO92 138. STBV32    Si    NPN    0    700    400    0    1                5    TO92 139. STBV42    Si    NPN    0    700    400    0    1                5    TO92 140. STBV45    Si    NPN    0    600    400    0    0.75                5    TO92 141. STL72    Si    NPN    0    700    400    0    1                5    TO92 142. STL73    Si    NPN    0    700    400    0    1.5                5    TO92 143. STL73D    Si    NPN    0    700    400    0    1.5                0    TO92 144. STPSA42    Si    NPN    0    300    300    0    0                40    TO92 145. STSA1805    Si    NPN    0    150    60    0    5                150    TO92 146. STSA851    Si    NPN    0    150    60    0    5                85    TO92 147. STX0560    Si    NPN    0    800    600    0    0                70    TO92 148. STX112    Si    NPN    0    100    100    0    2                1000    TO92 149. STX13003    Si    NPN    0    700    400    0    1                5    TO92 150. STX13005    Si    NPN    0    700    400    0    3                8    TO92 151. STX616    Si    NPN    0    980    500    0    1.5                0    TO92 152. STX715    Si    NPN    0    140    80    0    1                40    TO92 153. STX724    Si    NPN    0    60    30    0    3                80    TO92 154. STX83003    Si    NPN    0    700    400    0    1                16    TO92
