Rockford punch 801x
schema de la amp auto rockford* 100 watts RMS x 4 at 4 ohms* 200 watts RMS x 4 at 2 ohms* 400 watts RMS x 2 bridged output at 4 ohms* 4-ohm stable in bridged mode* 2-, 3-, or 4-channel output* Tri-way capable (Tri-Way Crossover required) * variable high-pass and low-pass crossovers (50-250 Hz, 12 dB/octave) * Punch Bass boosts bass up to 18 dB at 45 Hz* MOSFET power supply and output devices* Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability* TOPAZ ? noise-killing differential inputs that eliminate 80% of ground loop noise* Trans?ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality* NOMAD ? advanced protection circuitry for "intelligent" shutdown protection* speaker- and preamp-level inputs* 17-1/8"W x 2-3/8"H x 9-7/8"D*MADE IN THE USAamp SERIOS
  • Răspunsuri 6
  • Swat Cat
  • luc
  • zal
