Swat Cat Postat Februarie 19, 2007 Partajează Postat Februarie 19, 2007 ULTIMATE series A3 is a powerful two-channel amplifier. A true, dual mono block with separate power sources that provides power output of 2 x 150 Watts with 4 ohm stereo and 550/870 Watts with 4/2 ohm mono. The amplifier is 1 ohm stable. Built-in fan control. Built-in, variable 50-125 Hz switchable low-pass filter for subwoofers. Built-in variable 20-200 Hz. high-pass filter that can be used as a subsonic filter or high-pass filter for front systems. Dual power terminals where you can connect dual power feeds or a DLS Power Cap. Button for switching phases when you use it as a subwoofer amplifier. RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion. Mode : AB Number of channels : 2 Output power in 4 ohm : 2 x 150 watt Output power in 2 ohm : 2 x 270 Watt Output power in 1 ohm : 2 x 425 Watt Output power in 4 ohm bridge mode : 550 Watt Output power in 2 ohm bridge mode : 870 Watt Output power in 1 ohm bridge mode : 1200 watt S / N ratio, A-weighted : > 100 dB Damping factor : > 200 Input impedance : > 10 kohm Input sensitivity, variable : 0,2 - 7 V Filter, highpass, variable : 20 - 200 Hz Filter lowpass, variable : 50-125 Hz Terminal for external cooling fan : Yes Double DC-inputs : Yes Phase shift button : Yes Current draw, idle : 1,1 A Current draw, maximum : 140 A Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch) Weight : 6,2 kg ( 13,67 lb) schema completa )))))))) Link spre comentariu
Vizitator Vasile Postat Februarie 19, 2007 Partajează Postat Februarie 19, 2007 OK, se muta la scheme Link spre comentariu
Swat Cat Postat Februarie 19, 2007 Autor Partajează Postat Februarie 19, 2007 :smt006 nu m-am gandit:P Link spre comentariu
Bullix Postat Februarie 19, 2007 Partajează Postat Februarie 19, 2007 Ok, cativa echivalenti la unii tranzistori? Pare misto schema. Link spre comentariu
