leo 17 Postat August 23, 2015 Partajează Postat August 23, 2015 cer si eu ceva date despre tubul gu 59 .va multumesc anticipat Link spre comentariu
romicap Postat August 23, 2015 Partajează Postat August 23, 2015 Fa o poza ...chiar nu gasesc nimic despre tubul asta ! Sa fie gresit citit ? Link spre comentariu
leo 17 Postat August 23, 2015 Autor Partajează Postat August 23, 2015 tubul e gu 59 eu am cautat ceva date despre el si nu am gasit .. Link spre comentariu
Vizitator Postat August 23, 2015 Partajează Postat August 23, 2015 Daca tipul lampii este corect scris mai sus, atunci ar trebui sa fie aceasta http://www.qrz.ru/reference/tubes2/type3/gu59.shtml Link spre comentariu
romicap Postat August 23, 2015 Partajează Postat August 23, 2015 (editat) Made in Russian USRS 1996 Name GU59B Type triode Cathode type tugsten,carbidized,direct heating Application field oscillation and amplification RF power Brief application oscillation, amplification Envelope glass to metall Cooling method forced air Dimensions 270mmx150mm Mass 5,6kg Filament voltage 5V Filament current 62 - 72A Mutual conductance 12 to 20 Gain coefficient 11 to 19 Output power 6kW Maximum anode voltage 7kV Maximum operating frequency 155MHz Da cred ca asta este ...ditamai namila are peste 5Kg si filamentul se aprinde cu 5V/ 62-72A ! PS Daca detineti un asemenea tub si il vindeti , sunt interesat sa`l achizitionez pentru colectia mea . Editat August 23, 2015 de romicap Link spre comentariu
