stefank Postat August 3, 2015 Partajează Postat August 3, 2015 Buna ziua , am gasit modulul acesta care se poate adapta la diferite paneluri bineinteles respectindu-se conexiunile . Datasheetul lui prevede urmatoarele conexiuni : 1 VSEL Power Supply for Panel 2 VSEL Power Supply for Panel 3 NC NC 4 NC NC 5 GND 6 GND 7 TXO0- LVDS ODD 0- Signal 8 TXO0+ LVDS ODD O+ Signal 9 TXO1 - LVDS ODD 1- Signal 10 TXO1+ LVDS ODD 1+ Signal 11 TX02- LVDS ODD 2- Signal 12 TX02+ LVDS ODD 2+ Signal 13 GND 14 GND 15 TXOC- LVDS ODD Clock- Signal 16 TXOC+ LVDS ODD Clock+ Signal 17 TX03- LVDS ODD 3- Signal 18 TX03+ LVDS ODD 3 + Signal 19 TXE0 LVDS EVEN 0- Signal 20 TXE0+ LVDS EVEN 0 + Signal 21 TXE1- LVDS EVEN 1- Signal 22 TXE1+ LVDS EVEN 1+ Signal 23 TXE2- LVDS EVEN 2- Signal 24 TXE2+ LVDS EVEN 2+ Signal 25 GND 26 GND 27 TXEC- LVDS EVEN Clock- Signal 28 TXEC+ LVDS EVEN Clock Signal 29 TXE3 - LVDS EVEN 3 - Signal 30 TEX3 + LVDS EVEN 3 + Signal Vreau sa incerc cu un display de laptop pentru inceput , modelul este LP150E05 cu urmatoarele conexiuni in manual : 1 GND 2 VCC Power 3,3 V 3 VCC Power 3,3 V 4 V_EDID DDC 3,3 V POWER 5 NC 6 CLK_EDID DDC Clock 7 DATA_EDID DDC Data 8 RA1- Odd Channel Differential Signal 9 RA1+ Odd Channel Differential Signal 10 VSS Ground 11 RB1- Odd Channel Differential Signal 12 RB1+ Odd Channel Differential Signal 13 VSS Ground 14 RC1- Odd Channel Differential Signal 15 RC1+ Odd Channel Differential Signal 16 VSS Ground 17 RCLK1- Odd Channel Differential Signal 18 RCLK1+ Odd Channel Differential Signal 19 VSS Ground 20 RA2- Even Channel Differential Signal 21 RA2+ Even Channel Differential Signal 22 VSS Ground 23 RB2- Even Channel Differential Signal 24 RB2+ Even Channel Differential Signal 25 VSS Ground 26 RC2- Even Channel Differential Signal 27 RC2+ Even Channel Differential Signal 28 VSS Ground 29 RCLK2- Even Channel Differential Signal 30 RCKL2+ Even Channel Differential Signal Intrebarea mea ar fi cum trebuie sa conectez tinind cont ca modulul meu are Clock signal separate iar panelul vad ca nu le are separat ci in cadrul semnalului diferential ? Am vazut ceva videoclipuri cu modulul in functionare dar am observat ca cele cu EVEN nu erau conectate doar cele cu ODD . Multumesc . Link spre comentariu
stefank Postat August 4, 2015 Autor Partajează Postat August 4, 2015 Am reusit cu conectarea la mai multe tipuri de displayuri de laptop , imaginea e buna dar difera rezolutiile . La unul de 1440 x 900 de exemplu dimensiunea orizontala e mai mica cu 5 cm ( pe aceasta portiune aflata pe partea dreapta locul ramas este umplut de linii verticale colorate ) iar dimensiunea verticala este mai mare cu 3 cm , la alt display de rezolutie mai mica tot format 16:9 dimensiunea H este aproape cu o treime mai mica , cu doua benzi late negre pe partea dreapta despartite de una mai ingusta cu portiune din imagine in ea , dimensiune V cu mult mai mare ca la primul display . Treaba cu modulul este ca se incarca din usb firmware pt rezolutii diferite , chiar si 1920x1080 dar nu prea le gasesc pe net . Link spre comentariu
