Litz Wire , IGBT-uri rapide, Diode ultrafast . . .
Vizitator K-Tronics
Vizitator K-Tronics
Litz Wire 200 x 0.2mm (≈ 6.3 mm² ) . . . 15 RON/m
- diametru exterior : ≈ 4.3 mm
- triplu izolata  (Grade 3,  Breakdown Voltage : 5kV )
- Tip email : Polyurethane P180 (se poate utiliza pana la 190 ⁰C)
- se poate cositori la 370⁰C
- izolatie exterioara suplimentara transparenta
Posted ImagePosted Image
Folie de Cu 0.1mm x 30mm (S = 3 mm²)  .  .  .  15 RON/m
Posted Image
Transformatoare de ferita complete (miez + carcasa) :
E55/28/21  .  .  .  35 RON/buc.
E65/32/27  .  .  .  50 RON/buc.
E71/33/32  .  .  .  65 RON/buc.
Miez de ferita :
U93/76/30 . . . 70 RON/buc.
 Posted Image
Transformatoare de ferita complete (miez + cleme + carcasa) :
ETD59 . . . 60 RON/buc.
ETD54 . . . 50 RON/buc.
ETD49 . . . 40 RON/buc.
ETD44 . . . 35 RON/buc.
ETD39 . . . 30 RON/buc.
ETD34 . . . 25 RON/buc.
Iron Powder Toroids :
T50-26B  .  .  . 3 RON/buc.
D=12.7mm ; d=7.7mm; h=6.35
AL = 43.5 nH/N²
T80-26B  .  .  . 4 RON/buc.
D=20.2 mm ; d=12.6mm ; h=9.53mm
AL = 71 nH/N²
T106-26B  .  .  .  8 RON/buc.
D=26.9 mm ; d=14.5mm ; h=1.5mm
AL = 124 nH/N²
Banda adeziva speciala pentru transformatoare :
Lungime rola : 66m
Grosime : 63µm
Latime : 12mm; 19mm; 25mm
Temperatura de lucru : 130°C
Grosime:
Tensiunea de strapungere : 5500V
12mm . . . 20 RON/rola
19mm . . . 30 RON/rola
25mm . . . 40 RON/rola
Posted Image
Tranzistoare IGBT rapide  :
IRGP50B60PD1 (WARP2 600V 45A la TC = 100°C)  . . . 15 RON/buc.
SGW50N60HS (600V , 50A la Tc = 110°C) . . . 15 RON/buc.
HGTG30N60A4D (60A la Tc = 110°C) . . . 20 RON/buc.
HGTG20N60A4  (600V 40A la TC = 100°C). . . 15 RON/buc.
IRG4PC50W (600V 27A la TC = 100°C) . . . 10 RON/buc.
Tranzistoare IGBT (f < 40kHz) :
IRG4PC50UDPBF . . . 10 RON/buc.
Tranzistoare MOSFET :
SPW47N60C3 (TO247, 650V, 47A (13A @ 100 °C), Rds= 0.07 Ω ) . . . 30 RON/buc.
SPP20N60C3 (TO220, 650V, 20A (13A @ 100 °C), Rds= 0.19 Ω ) . . . 10 RON/buc.
IRFP 4468 (100V/200A @ 100°C, TO247) . . . 20 RON/buc.
IRFP 4568 (150V/120A @ 100°C, TO247) . . . 23 RON/buc.
IRFP 4668 (200V/92A @ 100°C, TO247) . . . 23 RON/buc.
Diode rapide pentru SMPS:
DSEI2X121-02A (200V, 246A ( 2x 123A), trr = 35nS, SOT227B ) . . . 50 RON/buc.
150EBU04 (150A, 400V, Ultrafast Soft Recovery Diode) . . . 35 RON/buc.
STTH6003CW (Fast Recovery 2 x 30A/300V) . . . 18 RON/buc.
STTH6002CW (High efficiency ultrafast 2 x 30A/200V) . . . 10 RON/buc.
DSEP60-12A (HiPerFRED Epitaxial Diode with soft recovery ,60A/1200V , 40ns ) . . . 23 RON/buc.
STTH12R06D (Turbo 2 ultrafast 12A/600V)  .  .  .  4 RON/buc.
STTH12R06DIRG (Turbo 2 ultrafast 12A/600V - izolata) .  .  .  5 RON/buc.
Diode Schottky:
40CPQ 100 (40A/100V, TO247) . . . 6 RON/buc.
DSSK 60-015A (60A/150V,TO247) . . . 12 RON/buc.
Placa diode redresoare din invertor de sudura Telwin . . .  130 RON
4 x 150EBU04 (150A/400V)
Diode redresoare rapide SEMIKRON :
 SKN141F15(cu plusul la surub) 140A/1500V . . . 35 RON/buc.
SKR141F15(cu minusul la surub) 140A/1500V . . . 35 RON/buc.
Posted Image
4700uF/450V . . .  100 RON/buc.
Posted Image
Trimit cu Posta Romana cu plata ramburs.
Transportul este gratuit (cu Posta Romana) daca se face plata in cont (Banca Transilvania).
Componentele vor fi ambalate cu atentie astfel incat sa nu se deterioreze in timpul transportului.
                        Posted Image
  • Răspunsuri 126
