hotel mode lg m2262dl
adam stefan
  • Răspunsuri 5
  • iuliantv
  • adam stefan
  • stefank
  • santamihai
Zile populare
Incercati in modul urmator :
To enter Installation menu from the remote control, you need:
  • [*]Choose any TV channel (it might not work if other input is selected) [*]Press and hold MENU button on the remote control until TV's menu appears, disappears and channel info appears. [*]Quickly release MENU button, enter 1105 and press OK.
If your remote control has no MENU button, use HOME button instead.
If you have 2012 model and procedure above doesn't work then you'll need to:
  • [*]Enter InStart Service Menu [*]Press Settings button.
In the installation menu, you can change the following parameters:
  • [*]LG Hotel mode setup (setting restrictions for hotels) [*]TV Link-Loader (load/save configuration (TLL file) from/to USB drive) [*]Password Change (reset forgotten parental PIN) [*]Set ID Setup
sau :
From ir remote: push MENU button for 5 seconds, type 1105 and press OK. Now you have a special menu and you can modify the settings or disable hotel mode. Same procedure for come back and modify or enable hotel mode.
Editat de santamihai
[*]Set ID Setup
sau :
multumesc mult a functionat ok o zi buna
