TestPoint Postat Mai 9, 2015 Partajează Postat Mai 9, 2015 Salutari, am o placa de baza modelul GYGABITE GA-81915P Duo si vreau sa imi cumpar 4 memorii ram de cate 1gb fiecare. Cum placa nu a avut niciun tip de memorie pe ea,as vrea sa stiu care din modelele de mai jos ar fi compatibil cu placa de baza,sau ce tip de ram imi recomandati pt placa de baza. 1GB DDR2 667MHz PC2-5300 PC2-5400 DDR2 667 (240 PIN) DIMM Desktop Memoria CL 5 1GB DDR2 533MHz PC2-4200 PC2-4300 DDR2 533 (240 PIN) de memoria DIMM Link spre comentariu
gabot Postat Mai 9, 2015 Partajează Postat Mai 9, 2015 Atentie nu poti instala patru module de rami pe aceasta placa. Poti instala ori doua module ddr ori doua module ddr2. A doua varianta cred ca ar fi compatibila. http://www.gigabyte.com/products/product-page.aspx?pid=1929#sp DDR : [*]2 DDR DIMM memory slots (supports up to 2GB memory) [*]Supports 2.5V DDR DIMM [*]Supports dual channel DDR 400/333 DIMM DDR II : [*]2 DDR II DIMM memory slots (supports up to 2GB memory) [*]Supports 1.8V DDR II DIMM [*]Supports dual channel DDR II 533/400 DIMM * Mixed mode, populating DDR and DDR II memory modules simultaneously is not supported.* Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount. 1 Link spre comentariu
TestPoint Postat Mai 9, 2015 Autor Partajează Postat Mai 9, 2015 Deci suporta doar 2 gb de ram placa....ok Am sa cumpar cei care sunt de 533 MHz.. O duminica placuta. Link spre comentariu
