Patefon Postat Aprilie 24, 2015 Partajează Postat Aprilie 24, 2015 Va propun sa adunam modele pentru simularea circuitelor electronice cu tuburi. Am sa incep prin a va prezenta un model pentru pentoda 6J4P atat in conexiune trioda cat si in conexiune pentoda. Prin bunavointa lui @jj101, caruia ii multumesc foarte mult, am avut masuratorile facute pe lampita mentionata pentru conexiunea ca trioda si in regim de pentoda cu grila 2 la 50, 100 si 150V. Iata ce a iesit: Important pentru modele generate este convergenta modelului de pentoda la modelul de trioda atunci cand e legata ca atare: apoi sa comparam rezultatele cu graficele din datasheet: Si iata si modelele generate: ****************************************************.SUBCKT 6J4P_Ua250_triode 1 2 3; A G C;* Extract V1.998* Model created: 24-Apr-2015* NOTE: LOG(x) is base e LOG or natural logarithm.* For some Spice versions, e.g. MicroCap, this has to be changed to LN(x).X1 1 2 3 TriodeK MU= 46.12 EX=1.562 KG1= 298.8 KP= 129.3 KVB= 485. RGI=2000+ CCG=0.0P CGP=0.0P CCP=0.0P ;.ENDS****************************************************.SUBCKT TriodeK 1 2 3; A G CE1 7 0 VALUE=+{V(1,3)/KP*LOG(1+EXP(KP*(1/MU+V(2,3)/SQRT(KVB+V(1,3)*V(1,3)))))}RE1 7 0 1GG1 1 3 VALUE={0.5*(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWERC1 2 3 {CCG} ; CATHODE-GRIDC2 2 1 {CGP} ; GRID-PLATEC3 1 3 {CCP} ; CATHODE-PLATED3 5 3 DX ; FOR GRID CURRENTR1 2 5 {RGI} ; FOR GRID CURRENT.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N).ENDS TriodeK ****************************************************.SUBCKT 6J4P_UG2_150 1 2 3 4 ; A G2 G1 C;* Extract V1.998* Model created: 24-Apr-2015* NOTE: LOG(x) is base e LOG or natural logarithm.* For some Spice versions, e.g. MicroCap, this has to be changed to LN(x).X1 1 2 3 4 PenthodeD MU= 46.1 EX=1.620 kG1= 312.7 KP= 115.6 kVB = 193.3 kG2= 1171.6+ Ookg1mOokG2=.23E-02 Aokg1=.27E-12 alkg1palskg2=.23E-02 be= .19 als= 2.52 RGI=2000+ CCG1=0.0P CCG2 = 0.0p CPG1 = 0.0p CG1G2 = 0.0p CCP=0.0P ;.ENDS****************************************************.SUBCKT PenthodeD 1 2 3 4; A G2 G1 CRE1 7 0 1MEG ; DUMMY SO NODE 7 HAS 2 CONNECTIONSE1 7 0 VALUE=+{V(2,4)/KP*LOG(1+EXP(KP*(1/MU+V(3,4)/SQRT(KVB+V(2,4)*V(2,4)))))}E2 8 0 VALUE = {Ookg1mOokG2 + Aokg1*V(1,4) - alkg1palskg2/(1 + be*V(1,4))}G1 1 4 VALUE = {0.5*(PWR(V(7),EX)+PWRS(V(7),EX))*V(8)}G2 2 4 VALUE = {0.5*(PWR(V(7),EX)+PWRS(V(7),EX))/KG2 * (1+ als/(1+be*V(1,4)))}RCP 1 4 1G ; FOR CONVERGENCE A - CC1 3 4 {CCG1} ; CATHODE-GRID 1 C - G1C4 2 4 {CCG2} ; CATHODE-GRID 2 C - G2C5 2 3 {CG1G2} ; GRID 1 -GRID 2 G1 - G2C2 1 3 {CPG1} ; GRID 1-PLATE G1 - AC3 1 4 {CCP} ; CATHODE-PLATE A - CR1 3 5 {RGI} ; FOR GRID CURRENT G1 - 5D3 5 4 DX ; FOR GRID CURRENT 5 - C.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N).ENDS PenthodeD Acum o sa va rog sa ma ajutati putin cu distribuirea capacitatilor. In datasheet sunt definite 3 capacitati: dar modelul de pentoda imi cere 5. Care cum le impart? 1 Link spre comentariu
Patefon Postat Aprilie 26, 2015 Autor Partajează Postat Aprilie 26, 2015 Cred ca nu va pot ajuta acum. O sa pot cand voi termina uTracerul. Pana atunci... rabdare. Link spre comentariu
Patefon Postat Aprilie 30, 2015 Autor Partajează Postat Aprilie 30, 2015 Am avut nevoie de un model pentru 6N3P si ce am gasit pe net nu prea a potrivit cu datasheet-ul. Asa ca inarmat cu rabdare am folosit un programel cu licenta publica (Engauge Digitizer) pentru a extrage graficele din datasheet in format numeric. Cu datele extrase am potrivit punctele culese intr-un fisier cu sintaxa lui miutracer (ca si cand ar fi fost masurate cu aparatul respectiv) si am pornit la cautarea unui model. Iata ce a iesit (ATENTIE - date din datasheet): ****************************************************.SUBCKT 6N3P_Negative 1 2 3; A G C;* Extract V1.992* Model created: 1-May-2015* NOTE: LOG(x) is base e LOG or natural logarithm.* For some Spice versions, e.g. MicroCap, this has to be changed to LN(x).X1 1 2 3 TriodeK MU= 57.83 EX=1.684 KG1= 229.0 KP= 111.0 KVB= 2271. RGI=2000+ CCG=0.0P CGP=0.0P CCP=0.0P ;.ENDS****************************************************.SUBCKT TriodeK 1 2 3; A G CE1 7 0 VALUE=+{V(1,3)/KP*LOG(1+EXP(KP*(1/MU+V(2,3)/SQRT(KVB+V(1,3)*V(1,3)))))}RE1 7 0 1GG1 1 3 VALUE={0.5*(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWERC1 2 3 {CCG} ; CATHODE-GRIDC2 2 1 {CGP} ; GRID-PLATEC3 1 3 {CCP} ; CATHODE-PLATED3 5 3 DX ; FOR GRID CURRENTR1 2 5 {RGI} ; FOR GRID CURRENT.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N).ENDS TriodeK Nu uitati sa adaugati capacitatile de manuta in interiorul modelului. P.S. - Cum impart si eu capacitatile la pentoda 6J4P ??? Link spre comentariu
Patefon Postat Mai 3, 2015 Autor Partajează Postat Mai 3, 2015 Daca tot a venit domnul Lazaroiu cu ideea de a vedea cum se compora in audio lampa numia RS1003 (vezi mesajul de aici http://www.elforum.info/topic/54841-simulari-scheme-cu-tuburi-electronice/?p=1174056 ) m-am gandit sa fac un model pentru ea. Iata rezultatul: si modelul propriuzis: ****************************************************.SUBCKT RS1003 1 2 3; A G C;* Extract V1.992* Model created: 3-May-2015* NOTE: LOG(x) is base e LOG or natural logarithm.* For some Spice versions, e.g. MicroCap, this has to be changed to LN(x).X1 1 2 3 TriodeK MU= 22.56 EX=1.412 KG1= 110.6 KP= 142.4 KVB= 4041. RGI=2000+ CCG=0.0P CGP=0.0P CCP=0.0P ;.ENDS****************************************************.SUBCKT TriodeK 1 2 3; A G CE1 7 0 VALUE=+{V(1,3)/KP*LOG(1+EXP(KP*(1/MU+V(2,3)/SQRT(KVB+V(1,3)*V(1,3)))))}RE1 7 0 1GG1 1 3 VALUE={0.5*(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWERC1 2 3 {CCG} ; CATHODE-GRIDC2 2 1 {CGP} ; GRID-PLATEC3 1 3 {CCP} ; CATHODE-PLATED3 5 3 DX ; FOR GRID CURRENTR1 2 5 {RGI} ; FOR GRID CURRENT.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N).ENDS TriodeK Evident nu am avut timp sa caut prin datasheet capacitatile aferente. Se va completa de catre fiecare doritor in parte. Link spre comentariu
