Primul amplificator pe tuburi !
Raresh Alexa
Așa cunm am promis, am comandat pentru Rareșh Alexa multitesterul:
Mega328 Transistor Tester Diode Triode Capacitance ESR Meter MOS/PNP/NPN L/C/R
linlk e-bay: http://www.ebay.com/itm/251563800953?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Mai jos aveți o scurtă prezentare:
https://www.youtube.com/watch?v=nx-CKZcBDvI
Scurtă descriere:
LCR-T3 graphical multi-function tester resistor capacitor + + + SCR + diode + transistor + mos tube inductance
LCD 12864 LCD display, with backlight , backlight color is generally yellow-green .
9v battery powering stacked . If prolonged power , you can use two 8.4v lithium battery pack consisting of .
Function:
1.Add boot voltage detection function
2.Automatic detection of NPN and PNP transistors , N -channel and P-channel MOSFET, diodes ( including dual diode ) , thyristors , transistors, resistors and capacitors and other components ,
3.Automatic test out the pin element and displayed on the LCD
4.Can be detected to determine the transistor emitter forward bias voltage of the transistor , MOSFET protection diode and the amplification factor of the base
5.Measure the gate threshold voltage and gate capacitance of the MOSFET
6.1602 lcd display uses LCD (12864 LCD with backlight )
7.High test speed , valid component test: 2 seconds ( except in the larger capacitor of large capacitance measurement also takes a long time , the measured time of one minute is normal )
8.One button operation , power-on test , get a key .
9.Power consumption off mode : less than 20 nA of
10.Auto power off function to avoid unnecessary waste , saving battery power , improved battery life.
Test ranges:
Inductors, capacitors , diodes, dual diode , mos, small transistor, SCR, the regulator, LED tube , ESR,
Resistance,Adjustable potentiometer
Resistance :0.1 ohm resolution, maximum 50M ohm
Capacitor :25pf -100,000 uf
Inductors : 0.01mh-20H
NEW Function:
1:Automatic detection of NPN and PNP transistors, n-channel and p-channel MOSFET, diode (including double diode), thyristor, transistor, resistor and capacitor and other components
2: Automatic test the pin of a component, and display on the LCD
3:Can detect the transistor, MOSFET protection diode amplification coefficient and the base to determine the emitter transistor forward biased voltage
4: Measure the gate and gate capacitance of the MOSFET threshold voltage
5:Use 12864 liquid crystal display with green backlight
Și e rezolvată treaba.
  • 3 săptămâni mai târziu...
Buna seara ! Am terminat amplificatorul push pull cu 6P6S .
Vreau sa le multumesc domnilor : Viobio pentru donatie ( tuburile electronice , socluri octale , novale , componente ) , Daniel_88 pentru ca ma ajutat cu transformatorul de alimentare al acestui amplificator , LMOlimpiu pentru ca m-a ajutat cu bobinarea transformatoarelor de iesire .
Alimentarea am facut-o pe placuta de test , din pacate nu am gasit 2 condensatori de 220uF/400V , asa ca am inseriat cate 2 condensatori de 470uF / 200V ...... in loc de soc am pus o rezistenta ....... Cand o sa gasesc condensatori de 220uF / 400V o sa ii montez in locul celor inseriati ( Sper sa nu se supere domnul Viobio .... )
Schema amplficatorului :
http://www.elforum.info/uploads/monthly_09_2015/post-176980-0-12295900-1441976106.jpg
Schema alimentarii amplificatorului :
http://www.elforum.info/uploads/monthly_09_2015/post-176980-0-34901600-1441976116.jpg
Aceste scheme apartin domnului Viobio .
Acum va prezint constructia acestui amplificator :
Transformatoarele de iesire bobinate de domnul LMOlimpiu :
http://postimg.org/image/up6ibupr9/
http://postimg.org/image/xkjliptr9/
Inceputul : http://postimg.org/image/bypceyz29/
http://postimg.org/image/6pubh3gn5/
Montarea componentelor : http://postimg.org/image/6pubh3gn5/
http://postimg.org/image/ffvzvoni9/
http://postimg.org/image/ttkwun73x/
http://postimg.org/image/88fu71ad9/
Final :
http://postimg.org/image/coxb7gxk5/
http://postimg.org/image/fwjgp02rf/
Sunetul este minunat .... zgomotul de fond este foarte mic ..... nu deranjeaza .
Si un mic video cu acest amplificator :
https://www.youtube.com/watch?v=iV8zjUD76fc&feature=youtu.be
Frumos...chiar am urmarit cu interes acest topic, bravo! Multi incearca sau incep amplificatoare, apoi din diverse motive abandoneaza proiectele sau le vand in pierdere ca sa-si scoata macar o parte din banii investiti... In principiu pot sa ramana acele condensatoare daca sunt bune - cred ca am zarit ceva Rubycon pe acolo....dar e bine sa aiba in paralel cate 220-470k, pentru echilibrarea tensiunii pe fiecare condensator, altfel exista riscul ca unul sa primeasca tensiune mai mica si celalalt sa faca "bum!" Rezistentele alea ajuta si la descarcare, dar prin faptul ca sunt mult mai mici (sau asa ar trebui....) decat rezistenta de izolatie a condensatoarelor, distribuie in mod egal tensiunea pe cele doua condensatoare inseriate.
Eu vazusem doar pe prima pereche, e bine daca le-ai pus. 2 din 3 becuri economice ce mi-au picat in mana din cele ieftine, aveau 2 cond. de 2...4 uF inseriate....si unul din ele era "popcorn"...la care aveau rezistente in paralel sau aveau schema din aia simetrica, nu mai cedeaza condensatoarele...
Bravo  :aplauze  super a iesit...mi-a facut placere sa ajut pe cineva cu o vointa asa mare care, cum spunea si domnul @carageae, duce lucrurile la bun sfarsit.
Foarte buna ideea montarii trafurilor cu axele perpendiculare, reduce mult zgomotul indus de traful de retea.
P.S.:mai schimba si tu melodia pe care testezi amplifurile  :rade:
Succes in continuare si la cat mai multe amplificatoare pe lampi.
Asa l-am invatat si eu (sper ca asa a facut ) ................
Rares mai trebuie "lucrat" la interior deoarece componentele sunt cam "aruncate" acolo , trebuie sa se vada canalul drept si cel stang , am sa te sum maine sa vorbim .
Incet incet incepi sa " prinzi aripi " si este un lucru bun dar nu uita  de scoala , ceia ce faci tu este o pasiune care prinde bine pentru mai tarziu  .
Personal te apreciez , alti copii de varsta ta se plimba prin oras sau "omoara" calculatorul cu jocuri sau mai stiu eu ce , tu lipesti la piese sa construiesti ceva pentru sufletul tau.
Pentru mine esti un copil  pe sufletul meu si la mai multe amplificatoare.
PS . vezi ca atunci cand termini liceul am sa fiu acolo .
@Daniel_88
O sa schimb melodia , ...... momentan nu am gasit alta mai frumoasa .....  :)
Va multumesc .
@Dumitrache_s
Va spun foarte sincer , mie nu prea imi plac jocurile pe calculator ..... nu ma intereseaza nici unul .... e o pierdere de timp ( parerea mea ) , eu am colegi de clasa care sunt gameri ( joaca tot felul de jocuri video complicate .... ) mereu ii aud ca stau cate 4 / 5 ore uneori chiar si 8 ore doar ca sa castige acele nivele de la jocuri ..... Va spun foarte sincer ca nu as putea sa stau atatea ore in fata calculatorului .....
Unii colegi , de clasa , de liceu ma considera : un ciudat ... pentru ca imi place electronica .... si cheltui banii aiurea ..... asta cred ei ....
O sa incer sa Montez componentele mai frumos la viitoarele amplificatoare ..... vreau sa incerc sa montez componentele pe bareta , am vazut undeva pe forum ( nu imi mai amintesc ) , ca domnul Viobio a spus ca se poate face o pseudobareta pe cablaj ..... :)
Editat de Raresh Alexa
Il felicit si eu pe Rares,dar totusi insist sa aprofundeze si foarta multa teorie,sa nu se lase luat de val pentru ca altfel ar fi mare pacat sa se piarda,sper sa fie la fel de ambitios in tot ce face nu numai in aceste frumoase realizari in care se vede/simte ca a pus multa pasiune.
Felicitari,Rares!
@daniel_88 : atentie!!!,axele transformatoarelor in cazul de fata NU SUNT PERPENDICULARE,tocmai din acest motiv mai are un pic de brum,deci trebuie regandita amplasarea trafului de alimentare,trebuie rotit la 90*  si montat pe latura mica,sau semi-ingropat,un ecran magnetic nu face prea mult intrucat trafurile de iesire la Raa=6000ohmi si multe spire sunt foarte "receptive" la campurile magnetice parazite.
Editat de LMOlimpiu
