Vizitator Bila Nicola Florin Sorin Postat Martie 16, 2015 Partajează Postat Martie 16, 2015 Samsung s3 i9300 & Note2 N7100 Dead boot repair solution & imei null solution only for i9300Procedure:* Download samsung s3 boot card maker Here* Extract it on desktop* Take a card reader insert memory card into the card reader nd connect it to the pc* From the extracted folder run Diskdump2.exe* Select generic storage Device. pictures below follw it * Now to write the scripts folle the below given picr Now done yu are succesfully created Dead boot memorycardTo continue further Requerments:* Z3X samsung Box or SPT Box (i used z3x)* special UART Cable (300k or 500k uartcable)* Download teraterm-4.78 From Herehere* Fully charged batteryDead boot Reapairing procedure* Download nd extract teraterm-4.78 on desktop* From extracted folder run ttermpro.exe there select serial port nd change the serial port to z3x serialport lik below givin in the picr *After Select The Serial Port Press Ok Button den Go To Setup Click Serial Port OptionSelect Baud Rate 115200 Then Press Ok Button lik below givn in the picr* Now insert the created boot card to the mobile* Connect the Uart cable via z3x box* Now Insert the battery nd wait for 5min if the procces didnt start discnnt the mobile close ttermpro agin try it.* if it run success yu vil the result below given lik this. Quote: Code pit_check_integrity: invalid pit.(0x0)pit_check_integrity: invalid pit.(0x0)update_guid_partition_table: There is no pit binary.fsd_reclaim 1283: MST is not recognized(mst.magic=0x0)fsd_reclaim 1284: MST is not recognizedfsd_reclaim 1599: Error(nErr=0x0)fsd_reclaim 1604: j4fs_rw_start is set to default value(128KB)j4fs_open 153: Error(nErr=0x40000000)j4fs_read_file_bootloader 355: j4fs panicload_j4fs_param: 'param.j4fs' does not exist, make new one..j4fs_write_file_bootloader 184: j4fs panicfailj4fs_read_file_bootloader 355: j4fs panicload_j4fs_param: debug level file does not exist..*INCORRECT!*init_fuel_gauge: battery is not detected, do not init fuelgaugeinit_microusb_ic: MUIC: CONTROL1:0x1binit_microusb_ic: MUIC: CONTROL1:0x1binit_microusb_ic: MUIC: CONTROL2:0x3binit_microusb_ic: MUIC: CONTROL2:0x3aPMIC_ID = 0x2PMIC_IRQSRC = 0x0PMIC_STATUS1 = 0x10PMIC_STATUS2 = 0x0PMIC_PWRON = 0x2PMIC_IRQ1 = 0x27PMIC_IRQ2 = 0x0s5p_check_keypad: keypad value=0x0s5p_check_reboot_mode: INFORM3 = 0 ... skips5p_check_upload: MAGIC CODE=d1b0f038microusb_get_attached_device: STATUS1:0x3c, 2:0x0s5p_check_download: update mode=0j4fs_read_file_bootloader 355: j4fs panics5p_check_tzsw: invalid tzsw type! dummy?scr_draw_image: draw 'download_error.jpg'...j4fs_read_file_bootloader 355: j4fs panicread_param_file: 'download_error.jpg' j4fs read failed!fimd_div:13, div:1, FB_SOURCE_CLOCK:800000000, FB_PIXEL_CLOCK:57153600a2, 60, 90, * if yu get this error at the end [Patch Stop] This is not Rom Code. yu cant fix yur mobile yu have to change yur emmc chip Quote: Code TN default<OK><OK>[DVFS] INT(1) : 0DRAM Type : LPDDR2 8G[DVFS] MIF(3) : 0[EPLL][VPLL][CLK_DIV] OK<OK>[LOCK SW/HW]ARM:0/0 INT:0/0 G3D:0/0 MIF:0/0 SHIFT:0/0[DVFS] ARM(0) : 5[DVFS] INT(1) : 0[DVFS] G3D(2) : 0[DVFS] MIF(3) : 0[sD_INITSDMMC_HighSpeedONE]SD_READ: 20000 20000 0x40008000 -> 668484 usec<OK>Inp32(uAddr) : 0xea00007eFW Booting[Patch Stop] This is not Rom Code. * After done this yur mobile must me n download mode or white screen if white screen manually put into download mode.* After dead boot repair mine white screen i manually put into download mode pir below * Now update your mobile with factory firmware with PIT file lik below given n the picr.Factory firmware Download Here* After update complete yur mobile may not have imei .imei null or yur mobile will not boot bcoz of dead boot repair. yur efs must be corrupted* To Fix this prob first root yur mobile Download from here (flash it through odin select as odin) * Now Download this EfS repair file nd flash it through odin select as odin yur mobile must bootbut the imei become lik this 004999010640000I9300_Repair_efs.tar.rar* if yur imei is null yu cant repair using this box so 1st yu have to repair the efs using above givn file. if yur imei bcome lik tis oly (004999010640000) yu can repair using z3x or othr samsung tool* Now follw the picr to repair imei problem.* After IMEI Repair Link spre comentariu
