Sursa Digitala 0-25V 0-5A cu Atmega8-LCD-LM723
GeoMar
De aceea am postat mai repede unele poze ca sa ai o privire de ansamblu si sa-ti poti face o organizare anticipata
Alta varianta ar fi cu butoane cu revenire pushpull care sunt mai mici
Oricum cutia folosita de mine este Z-17 destul de mare ca dimensiuni dar nu prea am loc si mi-ar trebui un traf mai mare,mai puternic sa acopere cei 5A.plus cel mic.Trebuie exploatat spatiul pe verticala prin etajare
  • 2 ani mai târziu...
Vizitator radiomontaj02
All the brothers greetings I collected this circuit works fine, but in the board from the TC there is an error and the protection will not work properly until I can insert the picture but this is the area near the relay and connected to the LM358 for memory, I can be mistaken if I open my power supply I'll look and point out more precisely, all the luck.
Здесь ошибка,красным добавил дорожку был разрыв.2 вывод LM358 на сопротивление R14.Here is an error in pdf, the red track added was a gap.2 output of LM358 to resistor R14. How to insert images?
Здесь ошибка, красным добавил дорожку был разрыв.2 вывод LM358 на сопротивление R14.Это ошибка в pdf, добавленная красная дорожка была выходом.2 LM358 на резистор R14.https://imgur.com/7knM5In
Editat de radiomontaj02
The link you posted in (#96) is incomplete, so it does not appear. Try to upload again, and carefully copy only the ,,BBcode (Forums) link that appears when you click on the top-right label ,,Share links,, of the uploaded image.
validae я извиняюсь я сделал правку в # 97 так нормально,просто я еще не могу разобраться с картой сайта я из России,Кавказ.validae I'm sorry I made editing at # 97 so normal, I just can not figure out the site map I'm from Russia, the Caucasus.
Mai exista o metoda, se face highlight pe link-ul care nu se deschide, se copiaza, se pune in bara de adrese a browser-ului prin paste and go, si gata.
Editat de alcon
  • 1 an mai târziu...
