PUNTE RLC ESR, merita banii?
victordascalescu54
Recent am gasit pe E-bay acest aparat de nasura la 100$ (desigur la chinezi) avind in vedere proiectul la care lucrez (necesita componente bine sortate) intreb si rog specialistii sa-si spuna parerea....desigur ca riscul ca acest aparat sa nu fie ceea ce scrie este luat in calcul. Multumesc anticipat
http://www.ebay.com/itm/111359555489?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Posted Image
Auto LCR Digital Electric Bridge Resistance Capacitance Inductance +  ESR Meter
The AD converter's words: about 1000 words, by over sampling technology, the effective resolution of about4000 words [*]Measurement methods: quasi bridge measurement, measuring principle is similar to the ratio method for measuring resistance. [*]
Fuction
Test parameters
L,C,R,D,Q,ESR
Basic accuracy
0.3%-0.5%
Equivalent circuit
Series
Range Mode
Auto
Test Speed
Fast: 2.5, medium : 2, Slow: 1 (times / sec.)
Calibration function
Auto
Test terminal configuration
The BNC test line
Display
 2004 LCD
Test signal
Test signal frequency
100Hz, 1kHz,7.831kHz
Test signal level
1.75Vrms(max)
Test Range
R
0.0002 Ω — 9.999 MΩ
C
0.1 pF — 10000uF or more
L
0.01 μH — 1000 H
D,Q
0.001 — 9999
Operating temperature and humidity
0°C-40°C,
≤90%RH
Power
voltage
 AC110V or 220v to DC 9V
Frequency
50Hz
Power consumption
≤0.45W
The main parameter display:
Cp: capacitor in parallel mode
Cs: series capacitor model
Lp: inductor in parallel mode
Ls: series inductor model
Rp: resistance in parallel mode
Rs: resistance in series model
Deputy Senate display:
The quality factor Q
D: loss factor
Theta: phase angle
Rp: equivalent parallel resistance
ESR: equivalent series resistance
Xp: equivalent shunt reactance
Posted Image
Posted Image
Editat de victordascalescu54
  • Răspunsuri 4
  • gauss
  • victordascalescu54
  • validae
Zile populare
Pare ( este ... ) interesant . Vad ca are si cablu Kelvin . Asta spune multe despre algoritmul de masurare ... La o punte pe care am achizitionat - o inainte de " mareea galbena " , numai acest cablu era mai scump decat aparatul prezentat aici . O singura chestie , pur personala : mergea si masurarea la 50kHz , sa nu zic 100 ... Ce sa zic ... eu as marsa ! Oare cat o iesi pretul final ?
P .S . - nu sant specialist ...
Editat de gauss
Am sa fac o intrebare, desi pentru mine e suficient sa-mi foloseasca in proiecte audio, multumesc pentru parere.
Ar mai fi o variantă mult mai ieftină, unii colegi de-ai noștri au la vânzare  punți RLC sau SMT (super multitester) care nu se ridică neapărat la nivelul de complexitate a punții menționate dar destul de precise  și cu mult mai ieftine, sub formă de kit. Vedeți de exemplu la colegii vcdec, taxdoru, Marele Savant....
Cred că postarea ar trebui mutată de la ,,Audio pe tuburi,, la Aparate de măsură fiindcă nu are nimic de-a face cu tuburile electronice.
Masurarea la frecvente mai ridicate e semnificativa la ESR - ul condensatoarelor . Mai putin important la audio , desi da o informatie asupra calitatii condensatorilor electrolitici recuperati , ce eventual pot fi folositi . Ca sa fac o gluma , de la audio la comutatie e doar un pas ... Comutatia " pandeste " azi peste tot , e greu sa te aperi ...
