Problema pc
stanpaul
a incercat cineva combinatia FireFox + Greasemonkey + VLCTube + VLC?
unii spun ca pot face si 720p sa mearga lejer si pe configuratie mai slabuta ca cea din topic.
pentru test se poate incerca doar cu VLC (VideoLAN), open stream media, link youtube, play.
in weekend as putea incerca eu combinatia pe un PC asemanator cu cel din topic, si revin cu detalii.
am incercat combinatia si da rezultate, vad 720p excelent! sub 50% procesor folosit.
VLC-ul, fara browser, merge cu 25-30% (functia de open stream)
in browser, merge sub 50% din procesor. Pana am updatat si Firefox-ul mergea cam cu 35%, dupa update cerea cam 45%, dar oricum e bine.
mai mult de 720p, nici nu imi apare sa pot selecta, probabil din cauza ca am un monitor de 15 inch, cu maxim 1024x768.
Deci configuratia mea mai exact e:
Windows XP SP3, sistem
Pentium 4 la 3GHz, cu HT, procesor
1Gb RAM
Radeon 9600 video
3Com 3C905C-TX retea
Creative SBLive sunet
in Chrome, merge ok 480p, iar 720p merge in 95% doar cu imagine statica, altfel sacadeaza.
asta imi arata in chrome://gpu/
Graphics Feature StatusCanvas: Software only, hardware acceleration unavailableFlash: Hardware acceleratedFlash Stage3D: Hardware acceleratedFlash Stage3D Baseline profile: Hardware acceleratedCompositing: Hardware acceleratedMultiple Raster Threads: DisabledRasterization: Hardware acceleratedThreaded Rasterization: EnabledVideo Decode: Hardware acceleratedVideo Encode: Hardware acceleratedWebGL: Hardware acceleratedDriver Bug Workaroundsclear_uniforms_before_first_program_usedisable_d3d11exit_on_context_lostscalarize_vec_and_mat_constructor_argsProblems DetectedDrivers older than 2009-01 on Windows are possibly unreliable: 72979, 89802, 315205Disabled Features: allHardware video decode is only supported in win7+: 159458Disabled Features: accelerated_video_decodeDisable GPU on all Windows versions prior to and including Vista: 315199Disabled Features: allGPU rasterization is blacklisted on non-Android: 362779Disabled Features: gpu_rasterizationSome drivers are unable to reset the D3D device in the GPU process sandboxApplied Workarounds: exit_on_context_lostDisable use of Direct3D 11 on Windows Vista and lowerApplied Workarounds: disable_d3d11Clear uniforms before first program use on all platforms: 124764, 349137Applied Workarounds: clear_uniforms_before_first_program_useDisable use of Direct3D 11 on older AMD drivers: 402134Applied Workarounds: disable_d3d11Always rewrite vec/mat constructors to be consistent: 398694Applied Workarounds: scalarize_vec_and_mat_constructor_argsRaster is using a single thread.Disabled Features: multiple_raster_threadsVersion InformationData exported	11.04.2015, 19:10:52Chrome version	Chrome/41.0.2272.118Operating system	Windows NT 5.1 SP3Software rendering list version	9.18Driver bug list version	7.16ANGLE commit id	5d9e9ab81e092D graphics backend	SkiaCommand Line Args	FilesGoogleChromeApplicationchrome.exe" --no-startup-window --flag-switches-begin --flag-switches-endPerformance InformationGraphics	0.0Gaming	0.0Overall	0.0Driver InformationInitialization time	0Sandboxed	falseGPU0	VENDOR = 0x1002, DEVICE= 0x4152GPU1	VENDOR = 0x1002, DEVICE= 0x4172Optimus	falseAMD switchable	falseDesktop compositing	noneDriver vendor	ATI Technologies Inc.Driver version	6.14.10.6462Driver date	3-23-2004Pixel shader version	Vertex shader version	Machine model name	Machine model version	GL_VENDOR	GL_RENDERER	GL_VERSION	GL_EXTENSIONS	Window system binding vendor	Window system binding version	Window system binding extensions	Direct rendering	YesReset notification strategy	0x0000GPU process crash count	0Diagnostics... loading ...Log MessagesGpuProcessHostUIShim: The GPU process exited normally. Everything is okay.[2336:3160:0411/185712:ERROR:gpu_video_decode_accelerator.cc(297)] : NOT IMPLEMENTEDHW video decode acceleration not available.[2336:3160:0411/185712:ERROR:gpu_video_decode_accelerator.cc(272)] : NOT IMPLEMENTEDHW video decode acceleration not available.[2336:3160:0411/190559:ERROR:gpu_video_decode_accelerator.cc(297)] : NOT IMPLEMENTEDHW video decode acceleration not available.[2336:3160:0411/190559:ERROR:gpu_video_decode_accelerator.cc(272)] : NOT IMPLEMENTEDHW video decode acceleration not available.
  • Răspunsuri 16
  • stanpaul
  • core
  • belasajgo
  • lorik199
exista o combinatie si pentru Chrome, Tampermonkey + VLCTube, insa nu e la fel de eficienta ca ce din Firefox, consumand cam 55-65% pe sistemul meu, in schimb are un alt avantaj, isi da seama ca nu e nevoie sa proceseze video in anumite cazuri (cum ar fi ferestra de youtube nu e vizibila), si scade procesorul pana in 25-30%, ceea ce Firefox nu pare sa faca.
