stanpaul Postat Martie 8, 2015 Partajează Postat Martie 8, 2015 Am un Desktop cu urmatoarele caracteristici: Operating System Windows XP Professional 32-bit SP3 CPU Intel Pentium 4 Cores 1 Threads 2 Name Intel Pentium 4 Code Name Northwood Package Socket 478 mPGA Technology 0.13um Specification Intel Pentium 4 CPU 2.80GHz Family F Extended Family F Model 2 Extended Model 2 Stepping 5 Revision M0 Instructions MMX, SSE, SSE2 Virtualization Not supported Hyperthreading Supported, Enabled Fan Speed 3085 RPM Bus Speed 199,5 MHz Rated Bus Speed 798,0 MHz Stock Core Speed 2800 MHz Stock Bus Speed 200 MHz RAM Memory slots Total memory slots 4 Used memory slots 2 Free memory slots 2 Memory Type DDR Size 1280 MBytes Channels # Single DRAM Frequency 133,0 MHz CAS# Latency (CL) 2.5 clocks RAS# to CAS# Delay (tRCD) 3 clocks RAS# Precharge (tRP) 3 clocks Cycle Time (tRAS) 6 clocks Physical Memory Memory Usage 88 % Total Physical 1,25 GB Available Physical 142 MB Total Virtual 2,58 GB Available Virtual 1,48 GB Motherboard Manufacturer Intel Corporation Model D865GBF (J2E1) Chipset Vendor Intel Chipset Model i865P/PE/G/i848P Chipset Revision A2 Southbridge Vendor Intel Southbridge Model 82801EB (ICH5) Southbridge Revision 02 System Temperature 45 °C BIOS Brand Intel Corp. Version BF86510A.86A.0077.P25.0508040031 Date 04.08.2005 Voltage +1.5V 1,458 V CPU CORE 1,494 V ATX +3.3V 3,126 V ATX +5V 5,070 V ATX +12V 12,173 V Graphics Monitor Name Default Monitor on NVIDIA GeForce FX 5500 Current Resolution 1280x1024 pixels Work Resolution 1280x994 pixels State Enabled, Primary Monitor Width 1280 Monitor Height 1024 Monitor BPP 32 bits per pixel Monitor Frequency 60 Hz Device .DISPLAY1Monitor0 NVIDIA GeForce FX 5500 Manufacturer NVIDIA Model GeForce FX 5500 GPU NV34 Device ID 10DE-0326 Revision A2 Subvendor Undefined (0000) Current Performance Level Level 0 Technology 150 nm Transistors 47 M Release Date Mar 2004 DirectX Support 9.0 DirectX Shader Model 2.0 OpenGL Support 2.0 Bus Interface AGP AGP Aperture 16 MB AGP Rate 8x GPU Clock 270 MHz Memory Clock 266 MHz Driver version 6.14.11.7519 BIOS Version 4.34.20.69.00 ROPs 4 Shaders Vertex 4/Pixel 42 Memory Type DDR Memory 256 MB Pixel Fillrate 1,1 GPixels/s Texture Fillrate 1,1 GTexels/s Count of performance levels : 1 Level 1 - "Perf Level 0" GPU Clock 270 MHz Memory Clock 266 MHz Storage Hard drives Hitachi HDS721616PLA380 Manufacturer Hitachi Product Family Deskstar Series Prefix Standard Model Capacity For This Specific Drive 160GB Heads 16 Cylinders 19.457 Tracks 4.961.535 Sectors 312.576.705 SATA type SATA-II 3.0Gb/s Device type Fixed ATA Standard ATA/ATAPI-7 Serial Number PVF904ZF0DUGRN Firmware Version Number P22OABEA LBA Size 48-bit LBA Power On Count 4328 times Power On Time 698,5 days Features S.M.A.R.T., APM, AAM, NCQ Max. Transfer Mode SATA II 3.0Gb/s Used Transfer Mode SATA II 3.0Gb/s Interface SATA Capacity 149 GB Real size 160.040.803.840 bytes RAID Type None S.M.A.R.T Status Good Temperature 44 °C Temperature Range OK (less than 50 °C) S.M.A.R.T attributes Am urmatoarea problema:) in mare merge bine cu mai multe programe deschisee dar pe youtube imi merge foarte incet doaar pe 144p si 240p imi merge mai sus daca il pun pe calitate mai buna de ex 360 480 720p nici vorba sacadeaza se aude sacadat .Vreau sa aflu ce imi lipseste sau daca o sa mearga vreodata cel putin pe 360 fara sa sacadeze .Mentionez ca am Browserul Prestabilit Google Chrome . Link spre comentariu
MaesTTro Postat Martie 8, 2015 Partajează Postat Martie 8, 2015 Daca "sacadeaza" cum ziceti dumnevoastra atunci cind priviti direct video-ul pe youtube atunci este o problema,poate sa fie chiar si in driverele video,alese gresit. Daca insa aceste efecte se manifesta cind schimbati pagina si lasati sa se ruleze in treaba lui video-ul cred ca este ceva normal. Link spre comentariu
lorik199 Postat Martie 8, 2015 Partajează Postat Martie 8, 2015 Probabil de la drivere, rulez pe un procesor din aceeasi familie numai ca e la 3,2 ghz frecventa, cu 1 gb ram video 480p pe win 7 32 bit si video integrat de 64mb, deci ar trebui sa rulezi totusi macar 480p cu hardware existent. Link spre comentariu
belasajgo Postat Martie 8, 2015 Partajează Postat Martie 8, 2015 YouTube-ul merge cu Flash Player sau HTML5? Daca merge cu Flash Player, as recomanda dezinstalarea Flash Player-ului si instalarea unei versiuni mai vechi pentru proba (de exemplu versiune de acum 3-4 ani). Am vazut calculatoare unde ultimele versiuni ale Flash Player-ului au cauzat probleme de rulare, in ciuda faptului ca aceleasi pagini de internet au functionat fara probleme cu un Flash Player mai vechi pe acelasi calculator. Sa zicem ca la 720p as intelege ca merge sacadat, dar la 480p nu ar trebui sa fie nici o problema. Link spre comentariu
The Stressmaker Postat Martie 8, 2015 Partajează Postat Martie 8, 2015 (editat) Chrome daca nu are drivere video functionale nici macar nu va incarca pagina. Trebuie sa cautati drivere pentru win 7 pentru ca am senzatia ca acum functioneaza cu cele incorporate in win 7. Mai vad un lucru la memoriile placii video, 266MHz este cam mult pentru modelul acesta fata de 200MHz cat este uzual posibil sa existe si artefacte sesizabile pe imagine sau in jocuri. Conteaza modelul placii video pentru cat se poate ridica aceasta frecventa. Daca sursa este la fel de veche nu ar strica sa testati cu alta sursa mai buna, uneori se poate vedea imbunatatirea. Testati placa video cu 3dmark sau un program asemanator si comparati rezultatul cu rezultatul pentru acel model. Daca difera mult atunci sigur exista problema cu driverul . @belasajgo: youtube cam refuza sa functioneze pe versiuni vechi, face parte din metoda lor de a zice ca este cazul de upgrade. Editat Martie 8, 2015 de The Stressmaker Link spre comentariu
stanpaul Postat Martie 8, 2015 Autor Partajează Postat Martie 8, 2015 Va multumesc cu stima am sa incerc sfaturile voastre Link spre comentariu
core Postat Martie 8, 2015 Partajează Postat Martie 8, 2015 am un sistem asemanator, p4 3ghz, 1gb ram si win xp, 720p merge sacadat si la mine, dar 480p merge ok. lucrez mai mult vara cu sistemul ala, si la vara am sa incerc o placa de retea dedicata, din cate am auzit la sisteme slabe, managementul retelei ajuta binisor daca e placa buna de retea. am gasit 3com si intel, dar nu le pot testa inca, nu am drivere si pentru win7 ca nu se mai fac, pacat, dar pentru ala vechi ar fi numai bune, ca momentan folosesc retea onboard. ce placa de retea ai? Link spre comentariu
stanpaul Postat Martie 8, 2015 Autor Partajează Postat Martie 8, 2015 am wireless usb adaptor .si am rezolvat problema(instaland Mozilla Firefox ) Va multumesc mult. Stiam ca pcu nu e asa slab . Link spre comentariu
belasajgo Postat Martie 8, 2015 Partajează Postat Martie 8, 2015 Merge si la 720p bine? Link spre comentariu
stanpaul Postat Martie 8, 2015 Autor Partajează Postat Martie 8, 2015 Mozzila firefox mi-l seteaza automat pe 360p nu ma lasa mai mult da ii bine asa imi ajunge Link spre comentariu
belasajgo Postat Martie 8, 2015 Partajează Postat Martie 8, 2015 Cred ca pe Firefox nu este instalat Flash Player-ul automat. Se vede daca dati click drept pe campul unde ruleaza video-ul. Daca merge cu Flash Player atunci la click drept apare in meniu si optiunea About Adobe Flash Player, altfel apare ceva cu HTML5. Daca se instaleaza Flash Player-ul, ar trebui sa mearga si cu 480p. Link spre comentariu
riderinblack Postat Martie 9, 2015 Partajează Postat Martie 9, 2015 Procesoarele pe socket 4xx sunt de domeniul trecutului, nu mai fac fata cerintelor actuale. Pentru ele a ajuns vremea pensionarii.... Link spre comentariu
lorik199 Postat Martie 15, 2015 Partajează Postat Martie 15, 2015 (editat) Sistemul meu de mai sus cu P4 la 3,2 ghz cu hyperthreading, 1 gb rams is video 64mb ruleaza impecabil win 7 pe 32 bit, sunt la facultate la mine niste desktopuri all-in-one si functioneaza execrabil cu win8, chit ca au I3 si 4gb ram Pentru ce il folosesc eu in atelierul meu, adica browsing, ceva programele, filmulete pe youtube, muzica e perfect, nu il schimb decat cand pica, desi nu cred sa o faca prea curand, avand in vedere ca e un IBM brand si e extrem de solid Editat Martie 15, 2015 de lorik199 Link spre comentariu
core Postat Aprilie 6, 2015 Partajează Postat Aprilie 6, 2015 a incercat cineva combinatia FireFox + Greasemonkey + VLCTube + VLC? unii spun ca pot face si 720p sa mearga lejer si pe configuratie mai slabuta ca cea din topic. pentru test se poate incerca doar cu VLC (VideoLAN), open stream media, link youtube, play. in weekend as putea incerca eu combinatia pe un PC asemanator cu cel din topic, si revin cu detalii. Link spre comentariu
ovy83 Postat Aprilie 7, 2015 Partajează Postat Aprilie 7, 2015 Procesoarele pe socket 4xx sunt de domeniul trecutului, nu mai fac fata cerintelor actuale. Pentru ele a ajuns vremea pensionarii.... asa este! multa lume se chinuie si degeaba explicam de ce merge greu.un lucru sa nu-l uitam totusi,acela ca totul in ziua de azi se bazeaza pe marketing,adica: vrei sa te uiti pe youtube ...cumpara hardware cat mai nou.acel flash player spune despre acest lucru. daca pui o varianta mai veche,na,nu merge. la sistemele mai vechi win explorer este cel mai bun pentru a viziona videoclipuri,pentru browsing mozilla sau altele. a,inca o chestie....nu m-ai omorati pentium 4 cu win7....este ca si cum pui la camion motor de Dacie...duce ...da cum...la single core mai vechi pana si pentium 4 630 face fata greu la win 7. Link spre comentariu
